Question about Denon AVR 3808Ci Receiver
NO GUI displayed
Hi there. Hi have a denon avr-3808ci receiver. Was working fine past year. Now, all of a sudden, none of the GUI's display on the TV monitor. System works in terms of audio, but no displays on screen. All status shows correct configuration. Remember, it was working perfectly before. Now, not even the screensaver shows correctly. Why and what can I do to fix it?
I had a similar problem with my Denon 3808 after it had the protection circuit tripped. First all I would get is a blue screen with sound, then after powering the unit off I got the display back, but all of the on screen GUI menus were gone. I could tell that the menu button worked because display located physically on the recever worked. I reset/rebooted the system (follow the directions in manual) and everything came back. Be aware by resetting the system any customization you have done will be lost. Hope that helps
Posted on Aug 04, 2009
RC-1068 preset codes
My self have problem with Denon AVR 3808Ci Receiver, the HDMI is doesnt work anymore, and I can not find replacement parts because receivers is out of date, very shame
Mar 30, 2014 | Denon AVR 3808Ci Receiver
I have a denon avr 3808ci and all of a suden im not getting sound frome sub.?
I'm having the same problem. Changed the wire from LFE to LFE input to the sub... I have a velodyne which has always worked great. Connected the sub with the original wire to my sony amp and it works great so it's the output on the amp. Any suggestions
Dec 08, 2012 | Denon AVR 3808Ci Receiver
I have a Denon avr-3808ci. I have a Dish Network DVR and a Sony KDS-60A2020 tv. If I connect the HDMI cable on the DVR directly to the tv, I get picture and sound through the tv. If I connect the HDMI...
You are correct. I feel your pain. This will not work.
HDMI is a pure digital signal and the providers require the content coming over the Dish DVR to be COPY PROTECTED. So it will not work unless the HDMI cable goes directly from the DVR to the TV. This is to stop people from being able to make their own recordings of Dish shows, or making copies of your DVR recordings. If you really want to run things through your reciver, you're going to have to use the "component" or "composite" video feeds, not the HDMI. Sorry.
Sep 18, 2011 | Denon AVR 3808Ci Receiver
I cant turn off the closed caption on my avr-3808ci...???
The receiver has nothing to do with that since it doesn't actually tune the station or decode the video content.
Usually, it's the TV that deals with CC.
Feb 09, 2011 | Denon AVR 3808Ci Receiver
Digital projector is shutting down as soon as dvd
Hi make sure that in the projector menu it doesn't have an option to cancel "control" as many tv's with hdmi have the capability to receive command signals through the hdmi cable.
Also make sure that your receiver is set for hdmi signal you must designate which input you are using on the receiver and then tell it what type of signal you want it to use.
you may have just pushed a button that changed these settings somewhere along the way.
hope that helps
Dec 30, 2009 | Denon AVR 3808Ci Receiver
How do I set up outdoor speakers? I currently have them set on Surround B, but do not seem to be able to play them
Fined in owner's manual section about MULTI ZONE CONNECTION AND OPERATION. page 68. If you don't have a manual, download it from here : http://www.usa.denon.com/AVR-3808CI-OM-E_404A.pdf
Nov 08, 2009 | Denon AVR 3808Ci Receiver
Remote controls of 3808Ci do not display menu on TV screen.
ther might be somthing wrong with the button and not the remote or tv so make sure nobody has spilled anything on it or hit it to hard.
Jan 23, 2009 | Denon AVR 3808Ci Receiver
Denon AVR-3802 Front Display problem
This can be either the display itself or the display driver IC havng problems. Something as simple as poor solder connections may cause this as well. Without seeing hte unit, it is difficult to say what the real problem is. If you can solder, try resoldering all of the voltage regulator ICs in the unit. These look like transistors and will be marked 7805 or 7812. If the voltages drift too low because of bad connections, the ICs can get "confused" and not work properly.
Keep us posted.
Dan
Aug 26, 2008 | Denon AVR-3802 Receiver
On screen display does not appear
Same problem, thanks for the solution -- resetting power solved it.
Mar 02, 2008 | Denon AVR-4308CI Receiver
Denon AVR 3808Ci Receiver Logo
1,141 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
