Question about Poulan Garden
Poulan chain saw mod. SM4018 Hard to start & won't accelerate
I have to use spray assist to start the saw.The saw will then idle but dies when i try to give it gas. If i let it idle for some time (5 min.) and put on full choke i can get it to run at full speed. Any suggestions will be appreciated.
Regards GMF
  • 1,040 Answers
Your carburetor needs cleaned. It may also need a carburetor kit, depending on how old or how long it has been since service. While you have it apart, you may as well clean or replace the air filter and check fuel lines for cracks or brittleness. If you need tips on how to clean carb. or changing fuel lines, just let me know.
Jim
Posted on May 30, 2009
  • Jim Parker
    Jim Parker May 30, 2009
    Thanks for the rating jerfer. Did this solve your problem?
    If you should have any questions on drywall finishing, or know someone who does, put your questions to "Tools-Building & Power-Hand Tools at FixYa.com
    Jim
Jim, Can you let us know how to clean the carb?
Posted on Jun 21, 2009
So i've been using a poulan pro 4218 all summer, ran like a champ for me everyday all day. then the crankshaft holding the clutch and sprocket snapped.. not a problem bought the part and replaced it....
Sounds like a carb issue, the L screw on the carb adjust the fuel mixture from idle to half throttle, i would richen the L screw by unscrewing 1/4 turn, this should improve the running, however there is a special tool to adjust the screws, part no. 530035560, the screws are fuel, not air screws, increase a shade more if it is still not idling or accelerating properly.
Oct 30, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a 42 cc 18" poulan chain saw I cant get it to idle its either all or nothing. I cant start if the chain break is on and when it starts the chain runs. It dies under stress and then is a...
If the chain runs at idle, or tries to turn when cranking the saw, then there is an issue with either the clutch drum bearing or the clutch spring has become weak, to get to both of these components you need special tools, the tool to remove the clutch is part no. 530031112, and the tool to adjust the carb screws is part no. 530035560, the L screw will adjust from idle to half throttle including acceleration, the H screw will adjust the full engine speed
Apr 03, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Hi, I just cleaned my Poulan Pro. Changed out the gas, opened the carb and flushed it out with fresh gas, cleaned the fuel lines, the spark plug and air filter. I didn't replace the fuel filter though. ...
The fuel pick up or filter should be changed every year but if your saw will start and run good but just not idle then adjust the screw marked T counterclockwise slowly until chain starts to rotate without you depressing the throttle.At that point back it off about 1/16 of a turn until saw will idle but chain doesn't move.Thank you. P.S. If you want to you can go back to factory setting by turning H & L fully closed then open 1 to 1 1/4 turn and very slowly adjust for smoothest operation. Do not adjust H anymore then minimum off factory to avoid engine damage.
If you need further help I would suggest you have a trained tech.service it. Good luck.
Feb 14, 2011 | Poulan Pro Chain Saw 46cc 20"
I have a poulan pro 4018. THe chain saw will start, but it appears that the choke is on full blast. As soon as it starts, the chain is moving - unsafe at the moment - I can use it as long as I don't...
Check the fuel filter, air filter, and muffler for plugging. Check the fuel lines for decay or other damage. Turn the idle speed screw (T) CCW somewhat to prevent the chain from turning at idle. If the above doesn't allow the engine to run without the choke on, then remove the carburetor, clean the interior with spray carburetor cleaner and check the diaphragm in the lower chamber for flexibility with no holes or cracks. Hope this helps!
Jan 29, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chain won't stop when throttle pressure is released.
Start the engine and allow to warm up. Turn the idle speed screw (not the jet screws) CCW to reduce engine speed until the chain stops even hinting at running. If you get it too low, the engine will tend to die when it idles. Hope this helps!
Nov 25, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
The saw starts and runs on fast idle but dies when you use the throttle? it,s a troybilt 18in saw
It sounds like it is flooding when you use the throttle, both are connected. Turn the idle back all the way until it dies, then try turning it a 1/4 turn the other direction.
Feb 19, 2010 | Poulan Pro Chain Saw 46cc 20"
HARD TO START CAN'T ACCELERATE
Have you done any work to the carburetor?Sounds like the carb. is dirty and needs to be cleaned. you may also need a carb. kit, depending on how old it is. If you need further assistance on how to do this, feel free to ask.
Jim
May 29, 2009 | Poulan PP4218AV 18" Chain Saw
Poulan Wild Thing starts great but as soon as I try to cut it die
The carb low idle needs to be adjusted this is fairly common among the Poulan chain saws. Once you adjust the low idle from factory setting it will work
Feb 16, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
318 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
