Question about Sony Handycam DCR-TRV740 Digital Camcorder
I CAN DOWNLOAD FROM MY MEMORY STICK ,BUT,NOT VIDEOS
Can not download videos to my computer.I've tried USB cable & also a DV CABLE i ORDERED.I've downloaded PIXELA VER.1.0
    President:
  • 1,383 Answers
First check your meory stic is not virus infected.
Also check that tpye of the file which u copy fromm meory stic it is supported by media player like wav files.
First coonect your camera with usb cable to computer then u find your meory stic as removable disk in my computer
then simply copy those files which u want to copy and paste in computer.
Let me know.
Posted on Jun 04, 2009
Will the Samsung UE27D5000NW LED TV play video from external hard drive?
"Wondering if an external hard drive will draw too much power/amps thru the TV's USB."
Yes, it probably would, so you are better off using a self-powered (one that you plug in to a wall outlet) drive.
And even if you got it running, it might crash halfway through a movie or something. But, for sheets & giggles, if you have all of the data that is on the 2.5" backed up somewhere else, give the 2.5" a try.
Good luck.
Jan 17, 2018 | Microsoft Xbox Computers & Internet
How do I download my pictures from my Sony camera to the computer?
Here is one instructional video tutorial from Sony Support; also could try this procedure:
- Take off your memory stick from your camera and insert it into your memory stick adapter. Open your camera's battery case and gently push the memory stick until you hear a faint "click," then remove it from the camera. Place the memory stick inside the adapter that comes with your camera.
- Insert the adapter into your computer's memory card reader, if you have one. The adapter, which is larger than the memory stick itself, is approximately the same size as an ordinary SD memory card.
- Connect your Sony digital camera to your computer using its USB cable if you can't find or don't have a memory stick adapter. Insert the small end of the USB cable into the camera. Insert the wider, flatter end into one of your computer's USB ports.
- Click "Open Device to View Files" to open your memory stick or camera. Search for the DCIM folder and click on it. Navigate through any photo subdirectories you've created and highlight photos you want to transfer to your computer. Right-click anywhere in a given folder, then click "Copy." Go to the location where you want to store your images, then right-click within that folder. Click "Paste" to transfer your images.
Hope this helps (remember to rate and comment this answer).
Jul 03, 2011 | Cameras
My computer (HP DV 5200TX) is not reading the memory stick duo. What steps can I try?
I didn't know that HP built computers with card slots that support MS pro duo. Try getting a mini-usb cable, leaving the card in your psp, and plug the PSP into your computer. Make sure you set the PSP to connect using the USB first, though.
Feb 11, 2011 | Sony 1GB Memory Stick PRO Duo Memory Card
Camcorder on Computer
The USB cable is to download still images only. To download video, you need (1) a firewire cable, (2) a firewire port on the computer, and (3) a video editing software program used to download and edit the video.
May 21, 2010 | Canon Optura 20 Mini DV Digital Camcorder
Can i download my video's onto my MAC?
Yes you can, you can use the Usb cable or you can use a memory card reader. Good luck.
May 15, 2010 | Sony Handycam DCR-PC101E Mini DV Digital...
Dcr-pc9e handy cam with no connectors
To transfer video from your camcorder to your computer you will need a firewire cable (IEEE 1394). Only with this cable you will be able to transfer video.
Please note that you will also need a firewire port on your computer. if you don't have one then you can buy a firewire PCI card.
Please see the following link for more info and pictures.
http://en.wikipedia.org/wiki/IEEE_1394_interface
Regards,
nicolasiac
Mar 25, 2010 | Sony Handycam DCR-PC9E Mini DV Digital...
How do i copy recorded video unto my computer
Add a firewire port to your computer and get that working. Then, using a firewire cable connected to the DV port of the camcorder (not USB), you will connect to the firewire port you just installed and import the video.
USB is used only for transferring stills from the memory card or maybe using the camcorder as a web-cam.
To get the video off the miniDV tape, you need to use firewire (IEEE1394a, i.Link... all the same thing).
Mar 19, 2010 | Panasonic NV-DS65 Mini DV Digital...
I have a sony pc 100 dv cam. I am trying to find the right cable to connect it to my mac. I need what ever sony uses one one end and usb on the other.
your camcorder doesnt support usb connection.although it came with a pc serial cable,its the cable used for memory stick picture transfer, along with it comes a serial port adaptor for the memory stick and ac adaptor for serial adaptor. of course even if you lost this accessories you can still transfer pics from the ms using a memory card reader which works basically the same way. for videos on the tape you would just need a firewire or an ilink (ieee1394) cable. almost all mac computers support this connection.it's the dv in/out jack on the camcorder with an i symbol.upper most jack on the camcorder jack's location.check your mac to find out what cable you need.the unit uses a 4pin ilink port so you need a 4pin ilink cable at one end and the other end should match of course, the firewire port on your mac computer.should be a plug and play connection.you can use imovie software for video capturing.hope this helps.thanks :)
Mar 11, 2010 | Sony Handycam DCR-PC100 Mini DV Digital...
How do I transfer the footage I recorded to PC?
The USB cable is only to download still images recorded on the memory card, using the software that came with the camera. To download video, you need to connect to a computer with a Firewire cable, and have video editing software on your computer to communicate with the camera.
Mar 06, 2010 | Canon DM-XM2 Mini DV Digital Camcorder
I am trying to find that what type of cable I
depending on what connection you have on your computer. You can use usb to usb or dv to dv. If you use usb to usb it's pretty straightforward but if you go dv to dv just make sure which dv connector you have on your computer 4 or 6 pin. If you don't have a manual for your jvc , go to their website and download one. All of the info will be in there, usually towards the back of the manual. My suggestion would be if you have a dv connector on your pc you should use that setup because it is faster than usb. But if you don't have a dv connector, usb to usb is fine. Have fun.
Jun 29, 2009 | JVC GR-D270US Mini DV Digital Camcorder
Sony Handycam DCR-TRV740 Digital Camcorder Logo
67 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
