Question about Hayward H Series Electronic Ignition 250,000 Btu Pool Heater H250ped2
Leaks after a couple of weeks use
I've replaced the h series exchanger three times. i used it three weeks the first year before it developed leaks. i replaced it next season and used it for about the same length of time before it started to leak again. i've got a new one to install and i'm wondering what to do to prevent leaks? i use an inline chlorinator that only gets to the pool after the heater, not before? any suggestions? this thing has to last longer than one season or six weeks. what category??!!!
  • 990 Answers
You may need to put a hartford loop in your plumbing between your chlorinator and the heater. The chloriene will back up in the line bad when the pump is off and corrode the exchanger. A hartford loop is simpley a loop than runs low then high above the top of the heater so it can trap gasses in the line and won't let them get back in the line. If all else fails you can use a floater. Be sure to check your PH also. Good luck.
Posted on Dec 10, 2009
Rinnai tankless water heater
Calcium naturally builds up in tankless water heaters and requires a descaling at least once every 2 years. If the heat exchanger is what has leaked I would just bite the bullet and have the heat exchanger replaced. It is cheaper than a full heater replacement. Then after exchanger is replaced have descaling done in about a week and every two years after. I know it's not as good as the manufacturer paying for it but it's not overly expensive either. Heat exchangers usually run between 2-400 depending on manufacturer. The manufacturer can also direct you to a qualified service technician in your area. Also keep in mind that because you chose a thankless heater you have the ability to replace every single part in the heater and unlike tank owners you don't have to replace the whole thing if it leaks. Good Luck
Jan 09, 2014 | Water Heaters
I have a briggs & Stratton 675 series engine in a Craftsman front wheel drive rotary mower which won't start. It was fully serviced and used 3 times this season but now it won't start. It
if it has hit a object, the flywleel key is partially sheared, and needs to be replaced. they are very inexpensive,CHEAP. this will through the engine out of time just enough it wont start.
Apr 16, 2013 | Briggs & Stratton Garden
What are the warning signs, if any, when the leveler (rear air suspension) is about to go out?
If a slow air leak has developed in either an air bag or in any of the tubing (there's a lot) or in the valve at the air pump, you will hear the air pump running more often.
Eventually, the pump will be unable to raise the car to the required height (working against the leak) within the time-out period (about a minute) and then it will give up, stop pumping, and a light on the dash will come on indicating an air suspension problem (or maybe on your relatively newer car, the digital dash may show an error message - I don't know).
I've had an '88, a '91, and a '94. Both the '91 and the '94 had air suspension faults at various times, and none of them were air bag leaks. I've had the valve at the pump stick and/or/leak on both cars, and the tubing spring a leak on one as well. Apparently the air bags are pretty well made and don't fail as often as the other components (in my experience).
Oct 20, 2011 | 1998 Lincoln Town Car
I've had to replace the right front axle three times on my 1997 2.5 TL. Why??
You are flooding out, if you depress the accelerator to start the vehicle this would be one reason. The other reason would be faulty fuel injectors that are leaking fuel into the cylinder.
May 29, 2011 | 1997 Acura TL Series
My check engine light is on with the code p0420. I have a 2005 nissan maxiam with over 110,000. It has came on and went off after a couple of days 3 or 4 times in the past year and a half but this time it...
CODE PO420 CATALYST EFFICIENCY BELOW NORMAL BANK 1. POSSIBLE CAUSES. THREE WAY CATALYTIC MANIFOLD. EXHAUST TUBE.INTAKE AIR LEAKS.FUEL INJECTOR.FUEL INJECTOR LEAKS.SPARK PLUG.IMPROPER IGNITION TIMING.
May 20, 2011 | Nissan Maxima Cars & Trucks
Have a 1999 bmw has check engin light po304 camshaf sesor ciruit fault
Common problem on a car of this age. Easily replaced component. I cannot tell you how easily because you did not mention your car model. If you have a three series, it is a thumb-sized sensor that connects to the front of the valve cover, right next to the oil filter holder. all you need to do is loosen the top of the oil line for the VANOS in order to access the screw that holds the cam position sensor in place. You should replace the soft washers at the top of the oil line so you don't develop a leak there. That oil line itself is a common leak point, so you might want to look at it before you buy the sensor. Now would be a good time to replace both parts if the oil line is leaking.
Apr 04, 2011 | BMW 323 Cars & Trucks
I have replaced my radiator three times within the past 2 years on my 1996 Ford explorer. Each time the heater is turned on the radiators develop cracks. I had the last radiator changed together with the...
you may need to check/raise the quality of the parts you are buying. You dont say what engine you have? if the radiator cap is incorrect or bad, it may have too much pressure on the cooling system.
Dec 21, 2010 | 1996 Ford Explorer
I have a Hayward HD100DI pool heater (3 years old) that I'm told needs a new heat exchange. I'm told they don't make them available anymore since it's too expensive of a repair to make and you're better...
I just found the same problem after replacing my ingiter and gas valve this week. Leaks right above the new valve. I'm going to try JB Weld, which comes in alot of different applications, and you can get at most Automotive stores. It worked pretty good on an exhaust leak I had once. Good luck and I'll let you know how it works out. My heater is still heating the water but makes a knocking noise when starting and of course, the water is leaking.
May 29, 2010 | Hayward H Series Pool & Spa Heater 400k...
Hayward H Series Electronic Ignition 250,000 Btu Pool Heater  H250ped2 Logo
131 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
