Question about Refrigerators
Refrigerator not cooling
Hi when i removed the relay of the refrigerator and shake it there is like a rattling sound. Does this mean that the relay is broken and needs to be replaced
  • arquetteg
    arquetteg May 11, 2010
    How old is the refigerator- what relay is it and please state make and model.
    Older refrig's use a mechanical relay that would make noise- newer models generally are solid state and would not make any noise.
    President:
  • 1,136 Answers
HI, Was the compressor clicking on and off? You might be able to smell the relay because they are known to burn out. If you do have to chane the relay, I would advise you to change the capacitor if this model has one.
Please let me know if I can assist you further.
Vic
Posted on May 30, 2009
My refrigerator is plugged up to the wall but not cooling or freezing
Hi, You may have defective compressor / motor or thermostat. Please check it out.
Jan 23, 2011 | Roper RS22AQXKQ Side by Side Refrigerator
Maytag refrigerator PSB2151GR problem: Came home & refrigerator was humming or buzzing but entire fridge has no cooling, even freezer - everything thawed!
Greetings,
The relay may have failed...remove compressor terminal cover and remove relay...shake it...you should not hear anything, if it rattles, its bad....
Dec 14, 2010 | Refrigerators
I smelled a strong odor, like rubber burning yesterday, and heard a small beeping, like something was trying to go on but didn't and noticed this morning that the freezer is defrosting, everything is...
it sounds like the start device failed,unplug the machine so you don't cook the pins on the compressor,pull out the machine and remove the back bottom panel and on the compressor you'll see the start device,remove the clip holding it onto the compressor and when you have it out shake it,if it rattles you'll know it's bad and you'll probably be able to smell the burnt stink on it,the part number is 2304884 and it's around 40 bucks,let me know how you make out
Oct 17, 2010 | KitchenAid Superba® Architect® KSRP22FSMS...
Refrigerator stopped, power OK, no sounds coming from compressor
Really this is one of two things. The compressor is shot, or the device that starts the compressor is shot. Whirlpool uses good compressors, and finding bad ones are rare. There is a device connected to the side of the compressor. Sometimes it is held in by a clip of some sort. I would unplug the frig first, then remove the device. This is called an overload relay.
Quite often the relay is burned badly, or visually damaged. You will also be able to shake it and hear a rattle. There is not supposed to be a rattle. This means it is broken and replacing this should get your compressor started! :D
May 27, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Fridge Gr2shtx not cooling clicking noise
relay on compressor maybe bad. relay needs to be removed. shake it. if it rattles and or particles fall out of it, it is bad.
Jan 06, 2010 | Whirlpool GR2SHTX Top Freezer Refrigerator
Freezer will not cool,i.e.freeze food.Compressor is very hot.
The compressor may be overloading because of a bad relay. The relay is on the side of the compressor. Disconnect power from refrigerator then remove the cover and remove the relay. Then shake the relay and if it rattles it is bad. http://www.appliance-repair-it.com/Refrigerator-repair.html
Sep 18, 2009 | Freezers
My refrigerator is making a clicking sound and won't run
overload rleay is actually mounted to the side of the compressor, , replace if ness. symptoms will be loosing cool, if you remove it you may hear ut shake like a rattle.it starts thecompressor
Mar 17, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore side by side refrigerator is not cooling or freezing
Sure sounds like a PTC relay bad. Take the relay off and shake it to see if you can hear a rattling sound.
The clicking sound is a relay called PTC relay. You need to replace it. First be sure to unplug frig. Remove the cardboard cover that covers most backs of the frig units. Remove the plastic cover that is on the side of compressor. It is held on with a metal clip. Now you should be able to see the relay pry the relay straight off. note the wiring and position of relay. Only three prongs on compressor. Go to a parts house for appliance's and with your make and model number should be able to get a new one. Let me know if you need any more help. ken
Feb 02, 2009 | Kenmore 53642 / 53644 Side by Side...
Refrigerator and frig on side by side not cooling. Inside lights are on so power is available. Not compressor sound when I turn the cooling knob to colder. Whirlpool ED25RFXFW01
if the fan in the freezer is running go to the compressor and see if you have 120 volts ac to the compressor relay, normally a white and red wire will be connected to the relay,
if you have 120 volts to the relay, remove the relay and if it is white shake it if you hear a rattle in the relay it has a set of burnt contacts in it and will have to be replaced if you have 120 to the relay and no rattle in the relay then a compressor problem
if no 120 to the relay check the cold control, the defrost timer
I WOULD CHECK THE COMPRESSOR RELAY FIRST
Apr 19, 2008 | Refrigerators
Refrigerators Logo
74 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
