Question about Microsoft Windows Vista Ultimate Edition
Start window problem on desktop
When i start the window and then at the desktop message: could not load or run 'C:\Windows\inf\Other.exe'spcified in the registry. Make sure the file exists on your computer or remove the reference to it in the registry.
And other messege: could not load or run C:\windows\system32|config\Win.exe' Make sure the file exists on your computer or remove the reference to it in the registy.
    President:
  • 2,559 Answers
This is a virus,Open the C:windows/system32/config and delete the Win.exe and then run a full virus scan with something like Spybot search and destroy and get ride of the remaining parts of the virus,Then use registry cleaner such a Ccleaner
Posted on May 30, 2009
What is the process for cleaning autorun.inf
Method One
  • Open command line (CMD) and write the following:
del /a:rhs [driveletter]:autorun.inf
  • Simply Replace [driveletter] with your drive. If the virus is on the D drive the commad will be
del /a:rhs D:autorun.inf
  • Restart the computer & Done.
Second Method
Genreally when you refresh the windows explorer view a bounded virus process recreates this file. This file is attached to many events of windows explorer including OPEN, REFRESH, etc.
You must close opened explorer windows.
1. Open up a command prompt (i.e. cmd.exe) >> to load it go to Run, type cmd, enter.
2. Now to remove virus's attributes (in order to delete it type following line by line and execute them pressing enter.
F:
F:attrib -s -r -h *.*
If there are any malicious EXE files those are now visible so if unnecessary delete them too.
F:del autorun.inf
3. After finishing above, quickly remove the pendrive as soon as posible (just after executing del command).
4. Now your pen is without virus activation config. file. Now you can safely delete unnecessary EXE files on it.
Method Third
  • Download Flash_Disinfector.exe from here and save it to your desktop.
  • Double-click Flash_Disinfector.exe to run it and follow any prompts that may appear.
  • The utility may ask you to insert your flash drive and/or other removable drives including your mobile phone.
  • Please do so and allow the utility to clean up those drives as well.
  • Wait until it has finished scanning and then exit the program.
  • Reboot your computer when done.
By this way you can remove
Jan 28, 2011 | Computers & Internet
Tip
Windows Cannot Find "Copy.exe"
When i installed AVG Free last time it removed few virus including "copy.exe". so whenever i go to "My Computer" (win key + E) and double click on any hard drive then i find an error stating that (Windows cannot find "Copy.exe").
Solution:
Well the solution for this "copy.exe" conundrum is to get rid of a file called autorun.inf in each of the infected hard drives. here's the solution for the problem......
Make sure you or the virus scanner is run through the infected hard drives/flash drives. to make sure the virus files is gone.
Now, some forums said you could just select "Show Hidden Files" from the option and this would enable you to see "autorun.inf" file.
Also, some entries in the "autorun.inf"may be legitimate. so to check the file (even when you can't see the file) do this: Type in the infected hard drive label followed by autorun.inf for example f:\autorun.inf
This will load autorun.inf file in notepad.if the only entry is that incriminating copy.exe then this is what i did. i tried to overwrite the file with the same name autorun.inf. that din't work because autorun file was readonly. so i saved that blank file on the desktop and simply cut it and pasted it into the drive, then selecting the overwrite option. that should stop that annoying windows cannot find "copy.exe" message every time you double click into a drive. this will solve the problem!
Read more: http://comsguru.blogspot.com/2009/12/windows-cannot-find-copyexe.html#ixzz0nMpOFGpo
on May 08, 2010 | Computers & Internet
I have an eMachine T3410. When it boots, a screen
your missing the biosinfo.inf. try reinstalling the system but backup everything you need first.
Jun 09, 2009 | E-Machines eMonster 600 PC Desktop
Wmploc.dll has 11.0.6001.7004 when 11.0.6001.7004 was expected
Hi fcmx1
On Windows Vista:
  1. Reboot your system.
  2. Open cmd.exe as an administrator by selecting Start/All Programs/Accessories.
  3. Right click on Command Prompt and choose Run as administrator.
  4. Type in
    unregmp2.exe /UpdateWMPVersion
  5. Press enter.
On Windows XP and Windows 2003 and earlier:
  2. Select Start/Run and type in:
    %SystemRoot%\inf\unregmp2.exe /UpdateWMP
  3. Click Ok.
Does this help?
May 13, 2009 | HP W2007 Desktop Monitor
Troubleshooting
Restore missing Help and Support Files 1. Click Start, Run and type %windir%\INF
2. Locate the file pchealth.inf, right-click and choose Install
pchealth1.jpg There will be two files namely PCHealth.INF and PCHealth.PNF. You'll need to right-click on the INF file (identified by a text pad and Gear icon in it) and choose Install.
3. In the next step, you'll be asked for the Windows XP CD (to extract dataspec.xml and many other files). Insert your Windows XP CD and point to the i386 folder in the CD.
pchealth2.png 4. Click OK. This restores missing Help and Support files.
note: The PCHealth.INF installation routine is not complete, as it does not register Help and Support completely, nor does it create the helpsvc service and other registry keys. At this point of time, nothing may happen when you start Help and Support, or it exhibits an error message mentioning the Help and Support service is missing.
Step II - End the Help and Support services Click Start, click Run and type Taskmgr and click OK. This opens Task Manager. Click the Process tab. Terminate the following processes if running:
  • helpsvc.exe
  • helphost.exe
  • helpctr.exe
Reinstall Help and Support
Click Start, click Run and type cmd.exe, and click OK.
In Command Prompt, type the following commands one by one and press {ENTER} after each line. Alternately, you can copy the commands below to Notepad, save the file with .bat extension (e.g. helpfix.bat) and run it.
net stop helpsvc
cd /d %windir%\pchealth\helpctr\binaries
start /w helpsvc /svchost netsvcs /regserver /install
start /w helpsvc /register
start /w helpctr /regserver
Sep 21, 2008 | Microsoft Computers & Internet
Start up msg
First
Open task manager and kill process wscript.exe.
Then
Delete VirusRemoval.vbs and Autorun.inf files from all usb drives.
Delete "c:\WINDOWS\system32\userinit.exe"
Then
Go to c:\Windows\System32 and delete the file VirusRemoval.vbs. It is super hidden so first go to Folder Options and check show hidden and check boxes. Also required for the above files.
Then
go to start>run and type regedit and enter
Go to HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
On the right side look for Shell which should have value of just explorer.exe.
delete anything at right side of explorer.exe if there is anything.
Under same key Winlogon also look for Userinit which should have value of
c:\WINDOWS\system32\userinit.exe,
Delete all the **** after the comma.
Then
Go to HKCU\Software\Microsoft\Internet Explorer\Main
On the right side locate Window Title and delete its value i.e. Sujin.com.np
Under the same key locate Start Page and delete its value i.e. http://sujin.com.np/
then go to Start Menu -> Run -> msconfig -> Startup tab -> uncheck .vbs files
Restart System
Jul 23, 2008 | Computers & Internet
Iexlporer probleme
Try finding Netconn.exe in your C:\Windows directory and double-clicking it. If the error still occurs, delete Netconn.exe, and then click Start, click Run, type MSCONFIG (hit enter), click the Extract File button, type in NETCONN.EXE as the file you would like to extract, click the button labeled ‘Start’, type the path to your WinME installation files where it says ‘Restore From’ (example: D:\Win9x), and type in ‘C: \Windows’ where it says ‘Save File In’ and click OK.
Naturally, back up registry, move copy of deleted keys to desktop before removing.
Delete HKEY_LOCAL_MACHINE,System, CurrentControlSet, Services,
ICSharing (the whole thing).
In addition to removing the whole ICS Sharing folder,
HKLM\System\CurrentControlSet\Services\ICSharing (entire folder),
Remove HKLM\System\CCS\Services\RemoteAccess\LocalNameResolution (all keys)
Extract ics.inf, icshare.inf and icsharep.inf to a temp folder (like C:\ICS)
May 10, 2008 | Microsoft Office Outlook 2003 for PC
Firewall settings
This usually happens due to missing or corrupt SharedAccess reg key, which represents the Windows Firewall Service.
Resolution
Download sharedaccess.reg (for Windows XP SP2 only) and save to Desktop. Then double-click the file to merge the contents to the registry. The Services entry will be created. Restart Windows (mandatory step, otherwise the following NETSH command will display an error message).
After restarting Windows, run the following from Command Prompt (cmd.exe)
NETSH FIREWALL RESET
Launch firewall applet from Control Panel, and then configure your Windows Firewall settings.
If nothing helps, as a last-resort solution (before reinstalling Windows XP Service Pack 2), give these two commands a try. Click Start, Run and type:
rundll32 setupapi,InstallHinfSection Ndi-Steelhead 132 %windir%\inf\netrass.inf
Restart Windows, and then run this command (from Command Prompt):
Attempt to start Firewall applet. Start the Windows Firewall service if prompted.
Apr 21, 2008 | Microsoft Windows XP Professional With...
Funny UST scandal virus
first download taskiller in http://www.rsdsoft.com/task_killer/index.php4
and install it to
your computer because you cant use taskmanager to terminate the virus(the
virus automatically close taskmanager).
-run taskiller and left click it on the system tray(the one with a skull icon)
-click processes
-to close the virus, select process and click yes to the question
(process to close)
1.killer.exe
2.lsass.exe
3.smss.exe
note: close only file that have the same icon of Funny UST Scandal.avi.exe
CMD STEPS
1-now, click "start" then "run"
2-type "cmd" without quotes
3-type "cd\" without quotes
4-type "attrib -h -s smss.exe" without quotes
5-type "attrib -h -s autorun.inf" without quotes
6-type "start c:" without quotes(a new window will open)
7-select smss.exe,autorun.inf,Funny UST Scandal.avi.exe and delete it
-if theres any drive or a partition type "d:" in command prompt without quotes
"d" is the drive letter then repeat the CMD STEPS number 4-7 above.......
-now type this on the command prompt "cd windows" without quotes(na naman!)
-type "attrib -h -s smss.exe" without quotes(uli)
-type "start c:\windows" without quotes(hay naku!)
-delete the file smss.exe
-now, goto c:\documents and settings\all users\startmenu\programs\startup
-delete lsass.exe
-click "start" then "run"
-type "regedit" without quotes then delete the registry entries above....
Note:
If you have problems opening drives in My Computer open regedit find
"\smss.exe" then erase values like: "c:\smss.exe", "d:\smss.exe" etc..
Hope this helps
Jan 16, 2008 | Computer Associates eTrust PestPatrol...
Xp error message
Try the following:
  1. Click Start > Run.
  2. Type regedit
  3. Click OK.
    Note: If the registry editor fails to open the threat may have modified the registry to prevent access to the registry editor. Security Response has developed a tool to resolve this problem. Download and run this tool, and then continue with the removal.
  4. Navigate to and delete the following entries:
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc2k5" = "C:\WINDOWS\SVIQ.EXE"
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"Fun" = "C:\WINDOWS\system\Fun.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run\"dc" = "C:\WINDOWS\dc.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"run" = "C:\WINDOWS\system32\config\Win.exe"
    HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\"Shell" = "Explorer.exe C:\WINDOWS\system32\WinSit.exe"
    HKEY_CURRENT_USER\Software\Microsoft\Windows NT\CurrentVersion\Windows\"load" = "C:\WINDOWS\inf\Other.exe"
  5. Exit the Registry Editor.
Nov 10, 2007 | Microsoft Windows XP Home Edition
Microsoft Windows Vista Ultimate Edition Logo
96 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
