Question about Kenmore 46123 Stainless Steel Electric Kitchen Range
Kenmore Stove Glass top
I had a power outage yesterday.  Finally 2 hrs later, they got it on, and my stove or burners will not work. If you turn the one burner one, it will buzz, and then their are lights on the display to set the oven, but nothing will heat up?  Can you help me.?? We checked all Breakers, and fuses, and it is not that.
  • softuk Nov 13, 2007
    Kenmore glass top stove
    my stove and burners quit working while cooking If you turn a burner on, it will buzz, and then the display lights up, but nothing heats up. can you please help? we flipped the breakers and it's not that.
  • ALTHO Dec 01, 2007
    my kitchenaid convection oven does not heat up after a recent power outage. I tried cleaning it, and I've tried other modes as well. The broiler now appears to work fine in that I just burned a piece of toast. However there does not appear to be a flame for the bake mode. I time the oven in the bake mode and it went from 185*F (residual heat from the cleaning) to 220*F in 4mins. In the 4mins. after reaching 220*F the temp did not change. HELP!
I have a Kenmore glass stove, not sure what the model number is I don't have it with me right now. Yesterday, the timer started to beep and F1 started to flash in the display. The stove top is working, but the oven does not. The only way I can get the timer to stop beeping is to unplug the stove.
Any suggestions as to what is going on with this stove. It's only 4 years old.
Posted on Jul 03, 2008
Turn off the main break,them put it back on,that maybe resolve the problem.
I have thi's problem before and that's all I,did.
Posted on Nov 02, 2007
I had a power outage and now my kenmore ultra bake glass top stove, has no power to oven.only when i hold cancel button for few secs"F2EO" shows up on screen. 4 burners still work,along wif oven light
The error code E0-F2 indicates that your touchpad has a stuck key. You might try disconnecting the electricity from the range and pushing and releasing the buttons on the touchpad several times. Be aware as you push them of any button that feels different. If you notice one that is stiffer or just doesn't feel like the others, give it several more pushes. Worst case scenario, you will need to replace the touchpad.
Jan 19, 2018 | Kenmore Kitchen Ranges
I have a kenmore range # 79094152310. And when I turn on the right front burner, the top of the oven gets so hot you would get burnt if you touched it, is this normal for this stove?
no --not normal
stoves even glass top stoves are only hot in vicinity of the hot plates
if the whole top is hot , call an electrician in to check the systems
Oct 02, 2016 | Kenmore Kitchen Ranges
I have a Kenmore Elite Kitchen stove top (one with the burners underneath a glass plate). Model number: 911 99004990. I believe it was purchased close to or around March of 2000. The problem I have with...
I have the same problem with ours! Our 2 small burners don't work at all and the 2 larger ones only work bright red hot. I called Sears and they said there is no recall on my particular model, but there are tons of recalls on other models. The problem is with the venting from the oven doing damage to the wiring (shorting them out maybe?). We're trying to find someone who knows anything about this and if we can get it fixed as our stove is only 3 years old.
Nov 15, 2010 | Kenmore Kitchen Ranges
I have a kenmore ceramic top electric stove and one of the burners quit getting hot. what could be the problem
It is a kenmore glass top stove about18 years old. One of the burners stop working just wondering if I can fix it myself?
Aug 06, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
I have a kenmore electric stove. The top burner
I have the same problem, it turns out that the clock has a sensor in it to turn on the oven. If that sensor is not working, which is found in the clock, the oven does not work. I had a repair guy come out and it will cost 350.00 to repair. My stove is only six years old. It is only two months to the day off warranty. Apparently a power outage can cause the sensor to go. Hope this helps.
May 12, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 911.9562991 glass top stove-glass cracked
I have Yamaha RX-v473 can not turn on , I try tone+info+power still not working. It’s have other way to turn no power ?
Oct 23, 2017 | Kenmore Kitchen Ranges
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore propane stove (16 yrs old). Oven quit working yesterday
is ther a slight propane smell around the stove?i'm thinking your oven pilot light got blown out
Jan 31, 2010 | Kitchen Ranges
Fault code F5
Hi Marcos
Happy to help you!
But I see that this problem will be solved only by service!
A & E factory service is good and nation wide!
They answer 24/7
Thank you Neil
PS.Please do not forget to give me a problem solved rating
Aug 05, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Kenmore 46123 Stainless Steel Electric Kitchen Range Logo
2,165 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
