Juki DDL-8300 Logo
Posted on May 12, 2017
Juki ddl 8300n, can't sew close to edge of fabric, light or heavy
I purchased a Juki ddl 8300n about two weeks ago. I have had nothing but problems. The dealer that I got it from isn't any help. First, It does not want to feed the fabric from the edge. It just sets there with the feed dogs going up and down but not moving the fabric. I can't sew close to corner of fabric , like sewing a tote strap as it does the same thing.
I can be sewing down the middle of the fabric and the machine again will stop moving the fabric and just go up and down. Thank you, I hope you can help. Dianne
5 Related Answers
A
Anonymous
  • Posted on Feb 19, 2008
SOURCE: question==>JUKI dnu 1541 or ddl 8300n
Might I be so bold as to disagree with Allmakes.
Why would a manufacturer build different models of industrial. They are designed for differnt jobs. The 8300 is a high speed garment machine, the 1541 is a compund feed upholstery machine. The motor is the same HP and does not affect the ability to sew heavy. The garment machine will sew garment weight leather just fine but you will have problems getting the fabric to feed properly particularly over seams. The other issure you may find with a garment machine is it's ability to handle heavier threads. I suggest that the 1541 would be a better choice for making bags and purses.
Anonymous
  • 351 Answers
  • Posted on Mar 27, 2008
SOURCE: Juki 8300N
Dear Rosemarie,
Make sure you have threaded the machine from right to left, it sounds like the needle thread is trapped under the lower looper thread and cannot form a stitch.........start the threading over from scratch like this:
  1. Lower Looper
  2. Upper Looper
  3. Left Needle
  4. Right Needle
Is there a diagram for how to thread on the inside of the door ?
Follow that slowly and carefully to make sure you have not missed any thread guides on the way, as each one needs to be followed through to ensure correct tension and thread progression.
Cheerup and Be Happy always
Anonymous
  • 208 Answers
  • Posted on Jun 17, 2009
SOURCE: Juki Sewing machine DDL-555. After 4-5 hours use feed not moving
Sounds like as the machine builds up friction from extended use, some vital part is lacking lubrication and is seizing up. A good service person will remove ALL of the covers and thoroughly air clean and oil every moving part. Sometimes these dry points are hard to find and patience is required.
You can get a sewing machine oiler with a long applicator and put a drop of oil on anything that moves, but over oiling can be messy.
Anonymous
  • Posted on Jan 20, 2010
hi , i am looking for needles for the juki ddl 555 industrial machine , any ideas
thanks
Anonymous
  • 10319 Answers
  • Posted on Mar 31, 2010
SOURCE: i need find manual for my juki ddl 8500
Go to the website freemanuals.com They may have yours
Can the juki ddl 8300n do zig zag stitching?
Hi there, sorry, but the 8300n is just a straight stitch.
I have a JUKI DDL 8300N with a tension problem. The tension thread goes about 10 stitches and then makes a loop and then continues. I've tried rethreading, but nothing seems to work.
Not fully understanding the issue but probable uneven feed of top thread from spool. Review threading instructions.
https://www.i3detroit.org/wi/images/1/1e/JUKI_DDL-8300N_Instruction_Manual.pdf
What's your experience and history with this machine? Attach a photo of problem, if possible.
I am a swimwear designer and just got a juki ddl 8300n did I pick a good machine? How can I adjust the machine for a more stretchy stitch?! What number should my stitch dial be on to get a stretch?
Perhaps a manual would be helpful:
File JUKI DDL 8300N Instruction Manual pdf
You should probably contact the manufacturer with questions. Hopefully, you did some thorough research before purchasing this machine. From the info I found, it appears to be a straight stitch only machine. I don't know anything about this machine, but I would be hesitant to purchase a straight stitch machine for sewing swimwear. Usually, swimwear needs a stretch stitch or zig-zag capability. Just my thoughts...
Amazon com Juki DDL 8700 Industrial Straight Stitch Sewing Machine Arts...
Juki DDL 8300N Industrial Single Needle Lockstitch Sewing Machine with...
JUKI DDL 8300N Straight Stitch Industrial Sewing Machine With Table Lamp...
I have a 2011 Juki DDL-8300N. Has always worked fine but while sewing on denim it suddenly seized up and stopped sewing. The needle is in the lowest postion through the jeans. I am unable to turn the
Your needle probably bent and got jammed. clip threads top and bottom of the fabric and remove... then get in the bobbin area and look for issues.
My JUKI DDL-8300N has locked up on me can u help me fix it?
if its not mechanical the thread has bound up the hook. spray hook all over with oil and let sit for a day then use hand wheel to force hook to turn, u will not damage machine. gp back and forth.
2answers
Juki 8300N
you should try adjusting the needle hight, the tensioners, the bobbin rension, belt tensions.
Question==>JUKI dnu 1541 or ddl 8300n
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
