Question about Kitchen Ranges
Burners work on stove top but oven turns on but does not heat up but does turn on. i lost manual and cannot locate it on sears.com
  • 1 more comment
  • Michele May 30, 2009
    the make and model is Kenmore gas oven, serial no. 362.75875690 with serial number 6T229370P
    thanks a lot!!! GURU
    yes but i need the manual please, how do I get it
  • 10,515 Answers
I can help you in order to find service manual if you can tell me the make and model of the kitchen range.
However,if the oven turns on but does not heat up, it might be :-
1. Faulty broiler
2. Ignitor.
Check the same and let me know.
Thanks for using "Fixya".
Do rate the solution as "Fixya" if 100% satisfied.
Posted on May 30, 2009
  • taran_2005
    taran_2005 May 30, 2009
    Regarding the service manual, you will not get a specific for your model as most of the models are same in resemblance.
    You can purchase the service manual for repair :-
    http://www.pcappliancerepair.com/cgi-bin...
    Copy and paste it in browser and click enter.It would have a detailed instruction to solve all issues regarding Ge/Kenmore issues.
    You can also note down a link to purchase all parts for your model :-
    http://www.partselect.com/KenmoreModels....
    I hope this would really help you. Once you purchase the manual, it will help you to troubleshoot all aspects of gas range and then you can order the parts at above mentioned site.
    Do rate the solution as 'Fixya" if 100% satisfied.
2 hobs on my electric cooker are not working
Fixing Electric Stove Burners that Don't Heat Up Properly ...
? 2:34
www.youtube.com/watch?v=GfqaPcha__o
Jul 2, 2012 - Uploaded by SamuraiRepairman
Fixing Electric Stove Burners that Don't Heat Up Properly ... Coil Surface Element Test - Electric Stove Repair - Duration: 2:04. by... Temporary Repair For Electric Plug In Range Stove Surface Element Burner Not Working ...
Electric Range Stove Repair: How To Repair Burner ...
? 6:52
www.youtube.com/watch?v=ndQU7RtqfRw
Jan 31, 2012 - Uploaded by applianceassistant
How to Fix Electric Stove Burner Elements That Won't Turn On Or Won't Turn Off. ... More Range and Stove Troubleshooting, Repair Help, And ... Fixing Electric Stove Burners that Don't Heat Up Properly - Duration: 2:34. by ...
Oct 26, 2015 | Ovens
Where are the fuses for the Sears Kenmore stove to elements located on Model C880 675080L0
Most likely no fuses. Either the element or the switch that turns it on is bad. If lighat comes on when you turn on burner the switch is probably ok and the burner went bad.
Jan 02, 2015 | Kenmore Sears Electric Range Surface...
The ignition feature seems to have stopped working on the range and stove. I do ot have a manual for this unit and the exterior labeling does not indicate a model number. What steps should I take to...
as both top and oven quit at the same time
if the lighting mechanism was a clicker type you used to her a snapping noise
for the top burners ovens are normally a hot surface ignition or glow rod the first thing i would make sure the outlet has power all four burners on top use same spark module and normally oven is separate module or control each burner control provides power to module separatly when turned on and you can test voltage at spark module mormally located behind a cover on back of stove
caution modules are wired 120volt and you would need a tester follow cord from outlet to where it enters back of stove normally wiring is close to cord entry point
Dec 07, 2009 | Sears Kitchen Range
Large burner won't shut off
This stove uses a special switch that turns one way for the large burner and the other way for the smaller burner. I was not aware that this had a seperate simmer burner on it, however. I think you using the wrong term there.
This is not computer controlled--the only computer on it should be the oven switch. I would assume that you need to replace the switch for the dual-size burner. If you take your model number in to Sears, or log onto Sears dot com, you should be able to get to the PARTS DIRECT web site on the computer, and if they ever sold that model you should be able to pull up a parts breakdown with expanded drawing and part numbers and prices. You should be able to buy the part from them. The part should be virtually the same as ANY recent model Frigidaire or Kenmore stove with the same style burner. This should be a very easy repair for you to make yourself, assuming that you know a little about working with electricity--remember, this stove USES 220 VOLTS!
Check out all of the wiring coming into the switch and going from the switch to the burner to be sure that there is not a short!
If you have one of the older smooth surface stoves, where the burners are part of the ceramic top, all bets are off, but anything you bought new in the last half-dozen years, should have a separate burner underneath a glass top, and the repair should be simple. Even with the older stove, it is still likely the switch, and should be no problem.
Feb 09, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Gas stove burner/oven noises
too much air on top burner ,delayed ignition on oven ,ignitor not lined up properly or check gas presure may need regulator adjustment or replaced. gas 784
May 12, 2008 | Ovens
Kitchen Ranges Logo
67 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
