Question about Toro Lawn Mower With Toro Power Tools
The lawn mower is burning oil and engine is missing.
Tried to mow the lawn today. Found it was burning oil and engine was missing. Lots of white smoke. It worked fine the last time I used it. I did add oil before I used it this time.
  • Dwain Pippen May 11, 2010
    Is this an overhead valve engine? Better yet, what is the model and type # on the ENGINE?
  • 1,040 Answers
Sounds like you may have broke the ring around the piston. I wouldn't run it again until you get it fixed. You could cause serious damage, if you haven't already. GOOD LUCK!
Jim
Posted on May 30, 2009
  • Jim Parker
    Jim Parker Jun 04, 2009
    Did you figure out what was wrong?
    Jim
Black,dry carbon soot over lawn mower.
if the mower was tipped over oil will run into the cylinder and the carburetor. yes it sounds like oil burn off
Sep 20, 2016 | Garden
Oil is coming out of the two holes that connect to the air filter. What is wrong?
Check your oil and see if its too full. Over filling will do that and you could do damage if you run it that way as well make it impossible to start.
Mar 31, 2015 | Garden
Engine growing black smoke
Usually this is a sign of oil being in the ignition chamber. Check the oil level, if too high drain and refill to proper level. Also if you have hills or slopes in your yard make sure that you are mowing up and down not across. If you must mow across the slope make sure to do it with the oil to the downward side. Caution if you do this too often the engine will be deprived of oil all together and seize up.
Apr 18, 2013 | Craftsman 675 Series 190cc 22" Briggs ...
I have a Centura 3.5 Tecumseh lawn mower. It sat
If the oil level is too high smell the oil to see if it has gas in it. If it does the carb needs to be cleaned and the oil changed.
Jul 17, 2009 | Garden
I have a Craftsman rear engine riding lawn mower and it runs rough in fast mode. It also misses and chokes out when mowing. It has a 13.5 HP engine. I've changed the fuel filter and cleaned the carb, but...
Hi, don't burn it. Try these two other easy things that might give you some relief: First, clean the air vent on the fuel cap. Second,change the spark plug.
Best regards, --W/D--
Jul 16, 2009 | Briggs & Stratton 66set Panzer Tractor...
My lawn tractor is losing power. its smoking black smoke and the smoke burns your eyes. its did it off n on the last few cuttings. today i had to stop mowing. it almost completely quite running.
First thing to do is change the oil. This should help but does sound like the mower is burning oil do to worn oil piston rings
Jul 10, 2009 | Garden
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
White smoke
White smoke is most likely cause there is to much in the engine.. Only takes about half quart.. Clean with degreaser and garden hose on the outside..
Jul 04, 2009 | Garden
Craftman Lawn mower continues to burn oil at a fast rate
Are you getting a lot of smoke? If so the oil is getting past the rings and burning.
Jun 23, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Toro Lawn Mower With Toro Power Tools Logo
788 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
