Cd wont work keeps coming up error 4 I have just purchased a 2004 Landrover Freelander SE (Face-Lift Model) and tried to enter a cd, keeps saying "Cd Err 1".
Won't let me put a cd in and won't eject or load, when I press my cd button just says (above).
Why is there not a list of fault helps anywhere online or in their manuals/handbooks??
Have a 2005 Freelander and the battery died. When I re-charged the battery, the CD changer had a CD ERR 1 message. Could not eject or load a CD and the radio worked. I turned off the radio and pulled off the cover on top of the CD changer. I removed the two screws that hold the frame around the CD changer. I turned the CD back on and the CD went through a test on each CD. I know this solution might not work for everyone, but it worked for me
error code on the cd means that cd is damaged, try another cd
if all your other three windows work - replace the fuse - it is situated by the glove box... to the left of it is a thin strip cover .. will be the fourth fuse .. diagram is also on the fuse cover ..... good luck ...Vinny Singh
I please could someone help me out I am trying to obtain a Key code for my Landrover Visteon CD Player. Visteon Model: 6500 CD-EUROPE Part: 2CFF-18C838-AB Serial: M065510 Any help would be much appreciated Thanks
Go to carhelpsite.com it is free as long as you click on 2 of the ads at the website then your questions will be answered by an ASE certified mechanic,you don't have to buy or fill out anything on the ads,so help keep the site free.
Have a look on ebay in car parts landrover section and click onto freelander there is sometimes the cd workshop manual under rave, which is excellant and full of info
ok error code 1, look for this error code on your owners manual, toyota cd players give 3 error codes, this mean error code 1, error code 2, and error code 3, they all have different meaning please check owners manuel to see what does error 1 mean i will try looking for you
The radio is faulty due to water coming out of the air vents due to condensation.See if a radio shop can repair the radio otherwise you need to replace this.Check the pollen filter in the footwell and change if it's dirty.
