Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet problem with door lock
Load and close door, control on
at any/all settings
push start-hold
I hear a small click(not a normal door lock sound, which is much louder)
in a few seconds the display shows dL then F
this happens and then goes away-no single reset reason
had a tech replace connection/part
unplugged/replugged sometimes this works
nothing seams to solve the problem
coach104@aol.com
  • peanut1022 Jun 01, 2008
    hold start button makes claking noice then dl then f flash mac wont run
  • ltengle Nov 07, 2008
    This is the same problem that I have the solution below does not work.
I've had this same exact problem and that's why I'm at this site.   I have had success with holding the start button and hitting the door right over the place where the switch is on the other side.  That worked good until today so I've called a service tech to come out later this week.  Give that a try and maybe it will work for you.
Posted on Oct 23, 2007
How to fix door on Samsung Washer model wf210anw. It makes 3 very hard clicks prior to starting.
Has the sound changed? The door lock assemble can be loud and sound like its faulty. If the washer completes cycles, then door lock is working correctly. One thing to check is the strike on the door. Look for anything that is odd or doesn't look right. A damaged strike can create extra noise. Good luck!
Jan 29, 2016 | Samsung WF210ANW 3.5 Cu. Ft. White Front...
Why is it that i push control on and it comes on but when i push start it does nothing will not start
Do you hear sound of click to lock the door when you press start? If not, the door switch is not locking for some reason. Board or switch on the door catch is most likely cause of this
Sep 08, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Washer Duet Control Locked, cannot do anythink, tried the advice but nothing when I push on ON & Cancell I see three bars --- in red, thats all,
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Press options and select for 10 secs till LOC is no longer displayed
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer, door locked light on door open no other lights on unable to set control
The control can be locked to keep the buttons from activating during external cleaning or to help from small children starting the machine.
To activate or deactivate press and hold the "end of cycle signal" button for 3 seconds.
Jun 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F/dl code comes on - machine doesn't run
failed door lock error, i would first unplug the unit for about 5 minutes this will reset the board. if that doesnt work you may have a bad door latch. .inspect latch that the piece on the door that when you close door piece on the door makes contact with the latch. hope this helps
Sep 16, 2009 | Kenmore Elite 45986 Front Load Washer
Cannot start
the problem you maybe having is your choosing the cyc first which is ok but I have not seen even with the newer models that have a self closing door push the door closed and latch catches then push start on some newer models you have to push and hold the start button 2-3 secs
Sep 09, 2009 | Frigidaire Dishwashers
I have a zanussi turbo dry built-in washer/dryer built-in 1200, Mod zjd . 125, and I do not know how to use it. HELP! Thanks, Cindy
Hey, Just load the washer but do not over load. These combo washer dryers are strictly for smaller loads. You should have a drawer to the left that you place the soap and softer and bleach. Set to the washer to washer. The door should lock automatically. Then set your dryer setting to the the Heat temperature that you want. 100 degrees is ok to start with. then it will adjust itself as it goes through the cycles you have set. Enjoy the machine should work. If it does not look to make sure that the door is closed all the way. Sometimes you have to open the door and reset it and shut the door or while it is closed gently push on it till you hear a small clicking noise. ENJOY YOUR WASHER DRYER COMBO
Aug 28, 2009 | Washing Machines
Whirlpool duet sport washer power button problem. I have to push power button a 10-15 times and the power will be on. Please help.
pushing the button that many time is not the problem on this type of unit you push the start and hold of about 5 sec's then you'll hear the unit start door lock and oper through a normal cyc a word of advice don't close the door very hard push into place these things are plastic and will break the latch assy then will cost $$$ for parts good luck
Aug 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
396 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
