Question about Coleman 5040-761 Open Flame Patio Heater
Coleman Patio Heater wiring
Heater tipped over and head came off. Nothing broke but wires were pulled off ignitor / pilot assembly, I have 3 white and one black disconnected wires. Coleman will not provide any help. Anybody there with a similar Coleman heater? Diagram or just a picture of any series 5040 product would help.
  • miraculix48 Jun 01, 2009
    There is one ignitor which has four terminals, one of which seems to be just a dummy, no lead.
    Two white wires (gauges 16 or 18?) are connected on one end to what I assume are the electrodes near the lamp burners. The loose ends do not have anything attached. The third wire, black, heavier gauge, goes to the heater but I cannot see where the other end is attached. The fourth wire, white, also heavier gauge, seems to have come off an electric component which still has one wire soldered to one of its two terminals.
    The ignitor had one broken off "**** connector" on the pin type terminals. These are not the standard car electric system connectors but made from thin copper. I couldn't find any lead on where to find these.
  • Ned C Cook
    Ned C Cook May 11, 2010
    On the connected ends, what are thy attached to? and how many ignitors are in the head?
    President:
  • 3,433 Answers
This must be a top secret heater design. Coleman is dwfinately of no help. The whites go to the ignitors or the output of the spark generator. The black is generaly a ground. Good luck.
Posted on Jun 01, 2009
Pilot light lights but goes out when I let up on it.
This can be caused by a worn thermocouple, these are consumable itmes that can last 1 to 5 years and will need to be changed. Sometimes it can also be a faulty tilt switch and worth shorting out the tilt switch first. Just place a wire between the leads on the small black box to short it and try lighting. Found this site very helpful patio heater top repair tips.
Jan 21, 2011 | Coleman (5040B750) Patio Heater
My coleman patio heater pilot lights but when I turn the knob to on position the flame goes out.
Check the tip over senser,,, it is a plastic senser located under the screen, usually near the knob. It has 2 wires running to it, jumper them together and try it,, then order a new senser from the manufature.
Good Luck
Apr 03, 2010 | Coleman (5040B750) Patio Heater
Sunjoy L-PH018PSS Patio Heater Replacement Parts
What is likely happening is that the pilot flame cannot reach the thermocoupler. This is usually caused by corrosion or other blockage of the gas to the area where the pilot lights. Thus resulting in a small flame or no flame on the side the thermocoupler is located. Fix this by cleaning out the corrosion or other blockage in the pilot assembly. I have found that small spiders like to make their homes here which causes the blockage of the gas for the pilot. The pilot assembly has three parts to it. The ignitor electrode, the pilot light tower, and the thermocoupler. The ignitor electrode has a wire that goes from it to the push button ignitor. The pilot tower is located in the middle and has a gas line going to it from the gas valve (control knob). The thermocoupler stands next to and on the opposite side of the ignitor electrode. It also has a copper line from it to the gas valve.
Unfortunately, the Sunjoy you have, which is the same model of two I have to keep running, is difficult to service. Parts are not readily available either so be careful when you take it apart. They do not sell the individual smaller parts in this model and therefore make you buy complete assemblies.
To clean and service the pilot assembly, remove the screws holding the front plate on where your control knob is. Once that is removed you can see the back of the ignitor, it is black and has one wire coming from it leading up to the ignitor electrode. You will also be able to see the small gas line from the gas valve going up to the pilot tower and the small copper line from the gas valve to the thermocoupler. That assembly is what you need to get to, to clean.
You do that by removing the top canopy by removing the three screws holding it down. Once that is removed, remove the center nut on the heat exchanger (the part that heats up with all of the little holes). It is located on the top and in the center of the heat exhanger. Then remove the three screws that are located around the bottom of the heat exchanger that connects the collar to it. You should be able to remove the heat exchanger now. Tilt the whole heater down and prop the neck on something so you can work on it.
If you look in the top you will be able to see small metal box covering the pilot assembly. This is held onto the pilot assembly with two screws. Remove those screws and carefully remove the box. Now remove the two screws that holds the pilot assembly to the collar (located on the outside of the collar). The gas and copper lines will hold it up. If you look at the pilot assembly from the top you will see one screw holding the ignitor electrode to the pilot assembly bracket. Remove that screw, unplug the wire from the ignitor and remove the ignitor electrode from the assembly. Be careful not to break this and I am having you remove it so that you do not break it.
Now remove the nut that holds the thermocoupler onto the pilot assembly bracket and pull it out of the bracket. The copper line will hold it up and be careful not to kink the copper line. Take a piece of sandpaper and clean the outside surface of the thermocoupler. Corrosion on the thermocoupler could cause it to fail which will cause the pilot not to stay lit. I have not had one do that yet but it could happen.
Now, remove the gas line from the bottom of the pilot tower so that the tower and bracket are in your hands. Put it down and put the heater back up straight. Hook up your gas and turn the gas on. Now, press the control knob on the pilot setting to make sure you have gas coming out of the gas line that feeds the pilot. You should be able to hear, feel and smell it. If not you have a regulator problem or an empty tank. Turn off your gas, remove it from the heater and tilt the heater back down.
Take your pilot assembly, you will see a circular top to the pilot tower that is held down with really small metal ears. Carefully bend the ears back so that you can bend the top of the tower back. Only bend it back far enough to clean the inside of it with a bent wire and compressed air or something. If you look on the lower side of the bracket, above where the gas line is threaded on you will see a hole that goes all the way through the assembly. This hole regulates the pilot gas pressure and allows the gas to mix with the air before it burns. Make sure that hole is clear of debris and take wire or something and thread it through the hole up through the top side of the tower.
When you have it clean, reconnect the gas line, thermocoupler and ignitor electrode. Once reconnected and before screwing the assembly back to the collar, I set the heater back up right and reconnect the gas. I then light the pilot to make certain you have a good strong pilot light generously touching the thermocoupler. The pilot should stay lit haver holding the button in for a few seconds. Do not turn the heater on past the pilot area without the heat exchanger on or you might singe your hair. If the pilot works the way it is supposed to, turn it off, disconnect your gas, tilt the heater back down and reassemble it following the intructions in the opposite manner.
The ignitor problem:
It is probably corroded in the cap (which is also the switch) or inside the ignitor where the battery goes at the spring. Spray these areas out with WD40 which will clean the corrosion out and try it again with a new battery. If it does not go click click click when you press the button you may have to take the ignitor out. Unscrew the cap and then the little black plastic collar which secures the ignitor to the collar. This should allow you to remove the ignitor by turning and maneuvering it out of the collar past the gas valve. Put the battery back in and replace the cap. Press the button to see if it works. Be careful it may shock you causing you to squeal, cuss and likely drop the ignitor.
I just had one do this to me. For some reason the little black collar that secures the ignitor to the heater collar would not screw all the way in. This would not allow cap to fully screw on and therefore would not allow contact with the battery to the contact inside the ignitor near the spring. Tighten it up as best you can so that contact can be made when you press the button. I believe this is one part you can order from Sunjoy separately if you cannot get yours to work....Good Luck
Jan 09, 2010 | Uniflame 200209 Open Flame Patio Heater
My sunstar patio heater fell over in the wind and now I cannot get it to turn on. Where is the safety shut off and how do I reset it?
I went through the parts diagram and could not find a saftey shut off in the parts list. It may be that when it fell over, the electrode got knocked out of place. If you get gas to the pilot, but the ignitor will not light the pilot you have to take apart the head and see if the electrode gap is to big for the spark to ark across. If you aren't getting gas then there may be a blockage in the pilot assembly and you have to take the head apart for that also. You can replace the regulator, easy to do and not very expensive first.
Oct 25, 2009 | Sunstar Patio Heater
It will not ignite. What can I do.
If you are getting spark when you hit the ignitor, it is most likely a blockabe in the pilot assembly. You will have to take apart the head to get to the pilot assembly and clear the blockage. If you are not comfortable with this, hire a service tech.
Aug 01, 2009 | Endless Summer 2009 Open Flame Patio...
Coleman 5040 Patio Heater w/ Light - Light works, Heater does not
BE VERY CAREFUL sticking matches in any propane appliance! With the gas OFF see if you can physically see the spark when you push the ignitor, if yes, the problem may be the regulator or bottle pressure the only test i am aware of for the regulator is replacement.
Jul 13, 2009 | Coleman (5040B750) Patio Heater
GAS is to getting to ignitor for my patio heater model # 385.001
I assume you meant gas is not getting to the ignitor, take apart the head, if you are comfortable with it, and check for a blockage in the pilot assembly. If this does not fix the problem, try replacing the regulator.
Jun 24, 2009 | Rta International Patio Heater
Charmglow gas patio heater
Your thermocoupler seems at fault. The thermocoupler is that probe that sits in the pilot flame. It controls the main fuel valve. Make sure that probe is in the pilot flame, better at the tip of the flame and hold the button down for a minute or so after lighting the pilot. If pilot extinguishes, the coupler is faulty. If pilot stays on the heater should fire up when you let up on the pilot button.. Good luck
May 30, 2009 | Coleman (5040B750) Patio Heater
Coleman Presidential II Heater won't come on
You should have 3 wires going to the gas valve - MV(mainvalve), PV(pilot valve) and MV/PV (or Common). Make sure all of these are properly wired and tight.
You also may have a dirty FLAME SENSOR on your pilot/ignitor assembly. You may need to remove the pilot tube and the pilot assembly to clean the sensor with sandpaper.
Be careful not to damage any parts while cleaning them. Be careful not to crossthread the gas line when re-installing it.
Jan 03, 2009 | Coleman Propane Forced Air Heater...
Patio Heater pilot lights won't stay lit
crappy pilot flame (not properly heating the thermocouple), bad thermocouple, thermocouple loose where it screws into the pilot safety valve, bad safety valve magnet.
One or more of those is the problem.
Oh...there is also a saftey switch...in case it tips over. It will also cause the pilot to not stay lit (if the switch or wires that go to i are faulty)
May 30, 2008 | Coleman (5040B750) Patio Heater
Heating & Cooling Logo
105 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
