Question about Lexmark X5495 Printer
Lexmark X5495 Will Not Power On.
All of a sudden, I go to use my printer and it doesn't come on. I checked the voltage of the AC outlet, and the output of the printer power supply. They are both perfect. Has anyone else had this problem.
    Guru:
  • 224 Answers
Connect the printer directly to the wall outlet without using the surge protector if it still does not work then either your power cable is spoilt or your printer has died.
Posted on May 30, 2009
How can I fix printing hesitation on my lexmark x5495
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/hsBChY. Select your operating system, download and execute the file.
Feb 16, 2012 | Lexmark X5495 Printer
Error 931
In most cases this error has something to do with the printers LVPS (Low Voltage Power Supply ).
If the printer is connected to power surge, try to connect it to an outlet from the wall. Do an An AC power check - check the AC line voltage at the end of the AC line cord. If the Ac line cord is incorrect, replace the cord.
Also check if the cord is in good condition. if not, replace the cord. If you still get the same errror, you may need to replace the printers' LVPS.
For further assistance assistance please contact Lexmark Technical Support.
Feb 09, 2012 | Lexmark C750 Laser Printer
My printer wont turn on
If you are encountering power problems with your printer, please go through the following checklist:
  • Make sure the power cord is plugged in securely and directly to the power outlet. Power surge protectors can draw power away from the printer.
  • Disconnect the power cord from the power outlet and the back of the printer and then reconnect it.
  • Check the power supply box (if there is one) to see if it is warm or cold, as there could be a defective power supply issue.
  • If there is access to a voltmeter, test the power supply to ensure that it registering the correct amount of voltage (most Lexmark printers have a 30Volt output).
  • Make sure the correct power supply is connected to the printer.
Jan 22, 2012 | Lexmark X5495 Printer
My printer doesnt work it doenst switch on at all
If printer doesn't work and it doesn't switch on, I assumed that there is no power at all on the printer. Check the AC line voltage if it is correct.
Unplug the printer. Remove the LVPS/HVPS, and check the fuses for continuity.
• If open, then replace the LVPS/HVPS.
• If not open, then check the switch continuity across its conductors with the switch on.
Turn the switch off. Plug the AC line into the LVPS/HVPS, and switch unit on.
Please try reseat power cable. If this does not resolve the issue, you may need to replace the LVPS (Low voltage power supply) on your printer.
For further assistance, please contact Lexmark Technical Support
Feb 07, 2011 | Lexmark E260 Laser Printer
There is power on the adapter but when i plug in the printer nothing happens, even when i press power button, the printer seem to be dead please help.
Good move on checking the power on the adapter and pressing the power button when it still didn't power on. Try these as well:
  • Plug the printer straight to the power outlet in the wall.
  • Bypass any surge devices or power strips, if you have, as they tend to draw away power from the printer.
  • Properly secure the power adapter on the back of the printer. Make sure it's correctly inserted/positioned in the slot.
If problem continues, contact Lexmark technical support.
Sep 22, 2010 | Lexmark X5495 Printer
Unit will not come on-power ok ac to dc adapter ok
Great job on checking the power from AC to DC adapter. Also, make sure to plug the printer straight to the power outlet in the wall, bypass any surge device or power strip. Unplug and replug the power adapter in the printer, make sure it's properly secured and in the right position in the slot. Press the power button if needed. If this doesn't help at all, I strongly suggest you contact Lexmark Technical Support to further investigate the problem. I hope I can assist you more on this matter.
Jul 01, 2010 | Lexmark X5495 Printer
It wont turn on i plug everything the printer just dont work please help
Check your power source, make sure that the outlet has got power, if it has, then it might be that your power supply is faulty
May 25, 2009 | Lexmark X5495 All-in-One &USB...
Lexmark x5495 won't power on, i have checked cord and outlet.
replace the mother board of the printer and that is the only way your printer can work very well again
May 10, 2009 | Lexmark X5495 Printer
Refilling Ink Cartrdige failer!
I have a Lexmark X5495 printer and I had it refilled a couple of weeks ago, suddenly i have a message that goes "Order new ink" or something and i check the cartridge but it is still full. I try restarting the printer and even the computer but the printer STILL won't let me print.
Oct 11, 2008 | Lexmark X5495 Printer
Lexmark X5495 Printer Logo
126 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
