Question about Kenmore Elite 45986 Front Load Washer
I get a message F dl from my front load washing machine.
It makes a noise like it wants to work but just cannot connect. It is only 4 years old. I have been able to get it to start. It comes and goes.
    President:
  • 331 Answers
Epoc,
Your drain trap (or pump) is clogged and it won't drain out fast enough for the computer to recognize it. The drain has to be cleared, OK?
Here's how to do it...first look at the lower panel. You'll see three screws down there.
What I do is lift the front of the washer a bit and slide in my pair of hammer handles under the legs like this... (this gives me some work room under the lower panel)
See where it says "Pump Trap"? (also notice that I have my shop vac at the ready) Unscrew the trap JUST far enough so you get some water leaking from it. Then fire up the shop vac and make sure as much of the water that drains from there doesn't get on the floor.
After you get all the water out (without completely removing the trap... this could take 30 minutes, be patient) then unscrew the trap completely and remove it. (You won't believe the stuff that's in there!) Clean everything, OK?
After that all you have to do is rebuild it all and you washer will be happy.
There ya go! Don't forget to show me somew FixYa Love I get a message F dl from my front load washing ma - 897292b.jpge, OK? Cool!
SG
Posted on May 30, 2009
Machine making loud noises w6863 front loader
could be that the wights are coming loose on the drum turn the drum by hand and see if you can feel any movement in the drum if yes get them looked at also try some oil on parts
Oct 12, 2014 | Washing Machines
My kenmore e-4 front loader is not starting. It makes the clicking noise but then flashes f then dL. How do I fix this?
'dl' stands for 'Door Lock' and 'f' for fault. There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Aug 30, 2011 | Kenmore Elite 45986 Front Load Washer
Front load duet whirlpool makes loud roar when it spins - no error code. Machine is only about 1 year old and just started making this noise recently
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Machine not draining
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 04, 2010 | Whirlpool AWM5145/2 Front Load Washer
F dL code message
Hi, this is a failed door lock alert. the FdL code represents this malfunction in the door lock mechanism. the unit will not operate if the door lock cant engage the latch. replace the door lock mechanism asap. this will fix the issue.
Jun 05, 2009 | Kenmore Elite 45986 Front Load Washer
Error message of f dl on kenmore washer model he 4t
does your washer stop on spin cycle some time. your is 4/5 years old?. f dl means door lock system is bad but i don't think so. do you have other error code beside f dl if yes then i think your washer need new main control board.
May 24, 2009 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Our wash machine will not spin after draining the water.
if this is really the old 9150 version then f21 is a ccu communication error with user interface. likely ccu is bad. 5d is not a error code.
bearings will make noise when out. unplug wait 1 min the reconnect power. If this doesnt work open top cover and check connections on ccu in rear. (unplug and replug). then buy new control. if your machine is newer duet (wfwxxxx) then f21 is different. (pressure sw) tech sheet on bottom front cover.
Apr 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our Kenmore front loading washing machine HE3t has never had a problem until this morning. We tried to start a load and the machine is showing an error message ''dL'' followed by an ''F''. In the booklet,...
i replaced to door lock, and while I was at it the hinges and door lock latch.
this solved the problem. i found it had worked loose by leaning on the door.
you can find the parts at various vendors on the internet if you are handy to replace them yourselves. or call in a tech. i think the parts were under a $100 in total.
Apr 05, 2009 | Kenmore Elite 45986 Front Load Washer
Knocking
you can remove the lower acess panel (3 screws across the bottom of machine)i would then check to make sure all 4 of the suspension supports are still connected, if so perhaps you can run with panel off to get a better understanding as to where the knock is coming from.(topp panel can be removed (3 screws across the top back) toalso look from atop for source of noise.
Oct 28, 2008 | Kenmore Elite 45986 Front Load Washer
My GE WDSR2080G makes a metallic rubbing noise during agitation
Take front off and watch while it agitating useing a good light and see if you can tell where the noise is coming from 52c26ee.jpg
Oct 21, 2007 | GE WDSR2080D Top Load Washer
Kenmore Elite 45986 Front Load Washer Logo
124 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
