Question about LaCie Design by F. A. Porsche 160 GB Hard Drive
Usb port on lacie has become detached and fallen inside
The usb  connector port on my LaCie has become disconnected from in side and the metal connector that the usb cable connects to has fallen inside the box and I need to recover the data.
Can I dismantle the box?
  • quasimime Jan 13, 2009
    This is the best and most detailed description I've seen about how to dismantle the LaCie drive. I was wondering, can I apply the same instructions to my LaCie mini Hard Drive & Hub (USB/FireWire.
    Novelist:
    Champion:
  • 382 Answers
This procedure is to extract the drive from the case..
1. The case is useless, dispose of it when you've extracted the drive. Attempting to reuse is pointless and could only cause more damage.
2. Make sure you disconnect ALL cables to the drive before you begin this.
3. You will need to be gentle as and shock or impact to the hard drive may render it useless, which would be unfortunate, considering it sounds as if the case is the issue, not the drive.
4. When choosing a new enclosure, go aluminum, and with no internal fan or psu. This just makes the environment hot and severe.
They cost slightly more than what is on the consumer market, but i use and recommend
Wiebetech TT4 or TTXE models, depending on whether the drive is PATA or SATA.
So to answer your question...
Yes, with a flat head screwdriver ( like a jeweler's ) and the drive on a book on its topside down. You can gently pry the bottom housing off about and inch from each corner. Upon prying up, you'l see the little slotted hole. There should be 4 metal fingers on both sides of the drive, screw in 2 on each side. Then remove the plastic contact guards, and gently pull up at the led light ( the power cable for the light should be running down the middle and is usually red or green. Once youve removed that, gentley put your hand on the drive, and with your other hand, flip the entire enclosure over. The drive should lightly fall out of the enclosure and into your hand......minimizing shock or movment of the drive, these things should be handled like babies..never shake.From here grasp the drive itself, and you will notice 2 cables binding the drive to the enclosure.The first is the data cable know as IDE or PATA and looks like a ribbon- more often yellow- second is the power cable known as MOLEX. The molex cable should be 4 wires..2 black, 1 yellow, 1 red. Ofcourse, be gentle when removing both Cables, as to not exert to much force so that it goes flying when its released. Once youve separated the 2, youll see that case for all its glory, or not. It's really a soda can with the cheapest components internally. Once the weight of the drive is out, there nothing to the box.
If you have any hesitation or addition questions before you begin, please ask here.
Posted on Oct 22, 2007
Hi My hard drive lacie minimus super speed usb 3.0 1Tb is recognized by windows 7 then after a few minutes it disconnects. Donato
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
May 20, 2011 | LaCie 2TB MINIMUS HD USB 30 301967 USB 20...
Hi there, the metal connector for the usb cable has become detatched and is loose inside the HD. can anything be done to fix it?? thanx tony
Do you want to mean the connector of the firewire cable? As I checked specifications this hard drive is not equiped with USB connection. Every external hard drive's case can be disassembled, you can take a look here for an example. Anyway, if a metal part is inside the case you should somehow remove it to avoid a potential shortcircuit.
If this is the solution for your problem, please rate my post, otherwise give us more details.
Regards,
Andras
Sep 07, 2010 | LaCie Design by F. A. Porsche 160 GB Hard...
Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Jul 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
XP doesn't recognize 500GB external Lacie after almost 2 years
try it on different usb ports on your system
try replacing the cable which connects the hard drive with the usb port
if this does not works the problem lies in the portable hard drive and i think it would be under warranty period so get it checked
Jul 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
I have lost my power cord to my LaCie DVD+RW Dual Layer....
Here is the PDF Users Manual for the LaCie DVD+RW 301230U
external optical drive,
http://www.lacie.com/download/manual/portable_dvd_sh_en.pdf
(Give it at least 10 seconds to download)
Should the direct link above not work for you, you can download the Users Manual from here,
http://www.generalmanual.com/Disc-Burners/LaCie-301230U-Portable-DVD-RW.htm
Go down to the bottom of the page, and under the green -> Download Now <- heading, click on -> User Manual
The reason I posted the link to the User Manual, is that you can use a USB to USB cable for power. You plug one end of the USB cable, into an available USB port on your computer, and the other end, into the LaCie DVD+RW external optical drive. (You need two available USB ports on your computer. One for power, and one to connect the LaCie external optical drive. This USB cable, is called an Interface cable)
The USB end, that goes into your computer, (Laptop or Desktop computer), is the USB A style end. (Male) This is what it looks like,
http://en.wikipedia.org/wiki/File:USB_TypeA_Plug.JPG
The USB end, that plugs into the Lacie optical burner drive, is a USB Mini-B style end. (Male) It looks like this,
http://en.wikipedia.org/wiki/File:USB_types_2.jpg
It is the second one from the left side.
Where I'm at, we have Walmart stores. At Walmart they sell a USB adapter kit, made by Philips. This kit has a USB A to USB A cable, that both ends are Male. This cable is on a little retractable reel. The reel is about the size of a USA fifty cent piece. In the kit are five different styles of USB adapter ends. They just plug on that USB A to USB A style cable. (On the small reel) One of those adapter ends is a Mini-B USB male end. It has a Female USB A socket on one side, and a Male USB MIni-B end, on the other side. The kit sells for about $12 dollars.
Should you find that somehow, this USB power cable does not give enough power to your LaCie external optical burner drive, then here is LaCie.com, Products, Support & Downloads, and the Power Supply, for your LaCie DVD+RW 301230U external optical drive,
http://www.lacie.com/us/products/product.htm?pid=10715
May 15, 2009 | LaCie (300776EK) DVD±RW Dual Layer...
LaCie icon won't show up on my mac desktop
1. A. Yes.
2. A No.
3. A. Replace the LaCie
Apr 24, 2009 | LaCie Computers & Internet
Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Jan 03, 2009 | LaCie (300728U) 250 GB Hard Drive
Computer will not boot with Lacie Desktop Hard Disk connected.
You can enter the bios on bootup by pressing a special key to force your computer to go into BIOS mode. What key this is varies by computer, often it is F8, F10, sometines F11. Anyway, use the key for your computer, and change to boot modus to not first boot from USB.
Dec 15, 2008 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie 80GB
Is this a USB based HDD? It may not be getting enough power.
I have a LaCie 100GB HDD that has 2 USB connectors. One is for data and yes, the other is for power. The 2nd connector is needed because some USB ports do not provide enough power by themselves. I have to use both connectors when I plug my drive into a USB 1.1 port. USB 2.0 ports seem to have enough power.
Try connecting your drive into a USB 2.0 port. If you have 2 connectors, try plugging both in. If this doesn't work you may need a replacement power supply or you may need to replace the HDD.
Binary Bob
Nov 25, 2007 | LaCie (301074) 80 GB Hard Drive
LaCie Design by F. A. Porsche 160 GB Hard Drive Logo
336 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
