Question about Alpine Type-R SWR-1042D Car Subwoofer
Sound is coming out but no bass
I have a 4 ohm alpine R type sub hooked up to a sony amp. I can hear sound coming out of the sub but there is no bass. I think the problem is I have a 8 gauge wire going to it instead of a 4 gauge but I don't want to spend more money on wires if I don't have too. What's the problem?
    Novelist:
  • 149 Answers
Make sure that the rca cables that you have coming out of the deck to the amp arent switched to highpass(no bass) and check the amp and make sure that the crossover is set to lowpass(LP) see if that helps
Posted on May 30, 2009
What amp would be better to use with what speakers/sub? I have a KAC-7202 kenwood 920W maximum power (150wX2 RMS, 4ohms) (230wX2 RMS 2ohms) and then the other amp I have is a Alpine MRP-M500 mono power...
I'm using that Alpine right now for 2-12" subs and I have compared it to 6 or 7 other amps this month and most were 4 channel 150Watt/Channel Bridged to 300Watts x 2 and found the Alpine to be superior in both sound quality and loudness. The Alpine has also not turned off even with full volume for hours at a time, Very solid amp I was very surprised due to it's size!
Apr 04, 2013 | Kenwood Car Audio & Video
I have 4/3/2 ch. alpine f-240 amp- i want to hook up four 6x8 3-way and one 12''sub. the amp has bass EQ on ch. 3. how would i hook it up and get the most power. can i put the 4 6x8 bridged all together...
run two 6x8s on each of the front channels of the amp. then depending on the sub you can bridge it on the rear channels.only if its a single four ohm. if its a dual 2 ohm sub run each coil on each channel. 1 coil-1channel. the other coil-the other channel. amp should run fine may run a little hot since it will be doing all it can do at a safe ohm load. just make sure it is mounted in a well vented area. should be safe.
Dec 25, 2009 | Alpine MRP-F240 Car Audio Amplifier
I just need to know the best way to hook my amp and subs together. i like a lot of bass. i just bought the subs and yhey dont really sound any diffrent. should i get a new amp.
Hello hembreegerry,
If you like a lot of bass, you definitely need to consider another amp. The SP2X-300 is only rated at 170 watts RMS into 4 ohms mono. That would barely be enough to power one small sub. You do not specify what brand and model your subs are, their impedance, or their power handling capacity. But for any subs, your best power solution is to add together the individual RMS power handling capacity and select a monoblock amp that provides close to the maximum at the impedance they will be wired to present. For example, if your subs are 4 ohms and have a maximum RMS of 250 watts, you would want an amp that outputs abour 500 watts into 2 ohms (2 4 ohm subs wired in parallel = 2 ohm load). An ideal amp in that example would be the Alpine MRP-M500 which outputs 500 watts RMS into 2 ohms.
Hope this helps.
Sep 10, 2009 | Power Acoustik Sapphire SP2X-300 Car Audio...
Hello i just recently bought alpine speakers for my eclipse 2003
mostly because the subs in the back are probley using more amps than the ones in the front in the front should be used mostly for vocals and your bass in the trun so maybe trying to unhook the ones in the front from the sub and just leave then hooked up to the cd player where you can hear the vocals really good and leave your subs in the back hooked up to the amp
Jul 27, 2009 | Alpine SWS-1223D Car Speaker
Subs have almost no sound coming from them
Hello meow_mix_666,
If you have tried different amps and different subs with the same result, I'd definitely suspect that you are not getting enough of an output signal from the head unit. Checking the RCA's and perhaps using a different set of preamp outs would be a good idea.
One other possibility that you may not have considered is to check the phasing. I've run into speakers that had the markings reversed and running the subs out-of-phase on a 4-channel bridged would make a huge difference in the bass.
Hope this helps.
May 10, 2009 | Alpine MRP-F300 Car Audio Amplifier
When volume turned up subs pop then immediatly produce no sound
u might have to turned your amp so u can play both subs your amp might be to small to run both subs at the same time an u gotta play around with the settings on your cd player so when u blasted your subs it has that nice bass to it not that poping sound.
Apr 04, 2009 | Jl Audio 13W7 Car Subwoofer
SWR-1242D wired at 4ohms
Hi!
Having to much power for a subwoofer is a veeeery good thing, it will provide a lot of control and quality sound to your sub.
But this sub is a dual voice coil at 2 x 4ohm so if you want to hook it up at 4 ohm u need a 2 channel amplifier running mono mode.
i dont recomend that you hook up in 4 ohm, its better to take some time adjusting the levels on the amp and the headunit.
This system has the potential to create a realy good bass sound if u tune it the right way.
Feb 10, 2009 | Alpine Type-R SWR-1242D Car Subwoofer
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Protection light
You cannot parallel two subs AND run them on the Bridge. You must have at LEAST a 4 ohm load on the bridge, and 2 4 ohm subs in parallel equals TWO OHMS. BAD!!! Move each sub to it's own channel or your amp will soon fry.
Sep 10, 2007 | Sony XM-2002GTR Car Audio Amplifier
No Sound Comming from Amp
mitco39,ihave a hifonics 1206 brutes for my subs @ 2 ohms in parallel and it sound great no problems.accept on my highs and mids still.
Mar 25, 2007 | Clarion APA2001 Car Audio Amplifier
Alpine Type-R SWR-1042D Car Subwoofer Logo
131 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
