Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
GE PS123 MGNA CC Ice Auger
The plastic ice auger in this GE model fractures every 12-15 months. Since taking ownership, I've replaced this auger assembly twice and the bucket/auger assembly once. The design is no feat of engineering mastery. Is there a stainless steel alternative to the OEM plastic? I have a GE Profile Side By Side, which also has an issue with the Metal 'Auger' and a broken plastic ring. I'm not sure of the correct terminology, as I don't have any schematics. I have the plastic rectangular/square Ice bucket, which has the metal screw, which dispenses/drops ice at one end, as well as dispensing the crushed ice. On the other end, is a plastic, circular part. I'm assuming this is the auger. Or it might be called something else. The plastic part is approximately 1.5 inches in diameter at the small end, where the screw goes through it. The backend of the plastic part is approximately 3 inches in diameter. I've been trying for a few hours to figure out how to remove the screw unit. I've removed the 4 screws underneath the unit, as well as the one screw that holds the metal rod for dispensing/crushing... I've tried to insert two flat head screwdrivers in the side, to disengage the plastic tabs.. i can't figure out how to get the head of the auger/screw to be loose enough so it can be removed from the housing... Any thoughts/comments, or pointers to actual diagrams would be greatly appreciated... Thanks -bruce
2 Suggested Answers
  • 5 Answers
SOURCE: GE PS123 MGNA CC Ice Auger
I just finished replacing the ice auger in my GE HSS25GFPA side-by-side and offer some suggestions/hints.
The auger (WR17X11705) was available locally (Appliance Parts Co., $28.97). This fits many other refrigerators. The replacement took a little under 2 hours. I estimate these hints may cut the time by one-half.
There are only 4 screws in the entire ice drawer assembly. It possibly was not necessary to remove the control rod. The other 3 screws hold the front cover. There are also 2 tabs holding the top of the cover.
The most difficult part of the repair was removal of the plastic assembly housing the crusher blades and the front bearing of the auger. This is held in place by only 2 large square tabs on the sides. There is enough space to get ONE side to release BUT to get both released required careful prying with thin-bladed screwdrivers (and prayer). These "tabs" don't push in, rather the drawer flexes out. Once released, the unit slides up and angles to allow removal of the auger/crusher. Re-assembly could not be easier. Stainless sheet metal screws would probably work if you do break something.
Remove the clear inside cover of the crusher assembly and the "C" clip on the threaded end of the auger shaft to separate the auger from the crusher.
And now for my PRIMARY reason for sharing my experience - the %#$@ plastic nut/bearing is a LEFT-HAND THREAD. I only realized this when trying to bend my make-shift split screwdrive back and the SOB loosened right up!
Carefully note the locations and orientations of the blades and spacers as you move them from the old to the new auger.
Posted on May 01, 2009
Amana side x side ARS2464B circa 2000. ice maker issue - during ice dispensing mode the auger will occasionally bind up and ultimately pop the auger off track from the rear driving side and i have to keep...
I am having the exact same issue -- how did you get the auger to slip back inside the drive gear? I've been trying & trying, and my hand hurts yet no progress. Thanks.
Jan 05, 2011 | Amana ARS2464B Side by Side Refrigerator
GE refrigerator model GSS22 WGMD ice maker motor
If you cant manually turn your auger motor, it may be bad. Does it dispense solid ice or no ice at all? Another thing may be your control panel. That could be bad too, it's the one sending juice to both your solenoid and auger motor.
Jul 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice will not come out of the door. The auger is not turning
take the ice bin completely out and run water in it until all the ice is clear from the auger
Mar 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice dispenser auger does not work.
Hi, On GE refrigerators the motor is not quiet. Open your freezer, remove the ice bin, press the door switch, make sure it turns off the light, and then press the ice dispenser lever. The solenoid will click, which also opens the ice door and the auger motor will turn on and you can definitely hear it. If the motor runs then inspect the auger connection on the rear of the ice bin, its plastic and they break. On some models, like my GE Adora there is a switch just for the ice maker behind the ice bin. If you need more help let me know as with all long distance troubleshooting we try with the information we have. Thanks and Good Luck!
Feb 15, 2009 | GE Refrigerators
The auger on my ice dispenser is broken
you should be able to get it in metal mine is in metal check with your apliance parts dealer in your area thanks from gilles
Feb 04, 2009 | GE GSS20IEP Side by Side Refrigerator
that is not true you can buy the parts seperately if you want to I will get the part # tomorrow for you just please rate me
Jan 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker will not dispense ice.
ON THE AUGER MOTOR IS A COUPLER THAT SLIDES INTO THE AUGER WHEN THE BIN IS INSTALLED. SOMETIMES, THE COUPLER WILL ROUND OUT THE FLAT SIDE OF THE CENTER HOLE. THIS WILL CAUSE THE MOTOR TO CONTINUE TO TURN, BUT THE COUPLER WILL REMAIN STILL DUE TO THE RESISTANCE OF THE BIN AUGER. ALSO, BE SURE THE ICE IN THE BIN HASN'T MELTED TOGETHER BINDING UP THE AUGER. IF NECESSARY, REMOVE THE ICE AND START OVER WITH FRESH ICE. YOU MAY NEED TO REPLCAE THE COUPLER OR AUGER MOTOR.
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Nov 22, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice Dispenser not working on PSS26SGPA Stainless Side by Side
This is a common problem with this GE and "lookalike" models. The dispensers first break the front plastic drum that holds to the auger and eventually cracks the rear circular sleeve as well. Pieces from the drum usually fall off and are even dispensed with ice ... eventually the drum is damaged enough that the auger no longer operates. The motors on these units, however, continue to operate.
You can receive the replacement parts needed to make the ice maker auger operate again by visiting the GE parts website. A usual repair will run $40-60. Unfortunately, the design of the replacement drum has not changed, so be prepared for this to happen again.
Best of Luck.
Apr 24, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
102 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
