Ricoh Aficio 550 printing very light
The copies are all coming out very light, changing the darkness has no effect.  The toner tube seems to have plenty of toner in it.  I read that the toner tubes have to be able to hold a "charge" and sometime they can't even if they have plenty of toner.  Is it possible a new toner tube would fix the problem?  I'd like to explore the simple posibilities before calling out a service person.  Are there other simple solutions to try to fix a copier that is printing out very light?
  • 26 Answers
Your machine will need to be serviced by a tech guy, the charge you spoke about on the toner is only when it is in the dveloper or in a magnetical toner which isn't in this machine, it is in other small laser machines like faxes and printers an also canon copiers, it is called mono component toner, you probably will have to change the developer or drum or both s well as check the coroners, if you are changing the drum you may as well change the blade as well because i
Posted on Nov 03, 2007
  • 3 Answers
Iit is almost certainly the toner sensor on the toner hopper. remove it and listen to it, it should squeak a little, if it does not it is broken and will need replacing
Posted on Oct 24, 2007
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,362 Answers
The toner is only charged when it leaves the tube and goes into a seperate container called the developper.
Try this : open top and make a copy of the ceiling.
a black sheet will come out. is it very light ? try adjusting the darkness does it change?
What I'm going to tell you may be a little technical, so if you do not feel comfortable doing these test, then you will have to call a service tech.
The problems could be coming from these areas, none of which are quick fixes.
1-developper not transfering enough toner, take it out and see if it has a dark coat of toner or can you see the actual roller.
2-drum is worn and is losing it's charge
3-transfer rolller a wire needs to be replaced.
My bet would be on the drum.
Posted on Oct 23, 2007
SOURCE:
I know how to replace it But Where can I find the waste toner bottle in Aficio MP 8001
In the manual (free download) here: Aficio MP 6001 6001 SP 7001 7001 SP 8001 8001 SP 9001 9001 SP download page I can't find any entry about waste toner, only the waste toner can't be reused, but no entry where to find the container. Sorry
Feb 09, 2015 | Ricoh Aficio Mp 8001 Copier - 910k Copies...
Print copy white
If the copies is whitw possible causes:
toner empty,not toner
developer drive transmission mechanism failure
image transfer current terminal poor intact
Feb 09, 2013 | Ricoh Aficio 2035 Copier
How repair error sc 590 in ricoh aficio 550
SC590: Toner collection motor error
-Definition- [B]
The toner collection motor sensor output does not change for 3 seconds while
the toner collection motor is on.
- Possible causes -
· Toner collection motor defective
· Too much load on the drive mechanism
· Poor toner collection motor connector connection
· IOB defective
· Toner collection motor sensor defective
Sep 06, 2010 | Ricoh Aficio 1224C Black and White Copier
Ricoh Aficio 550/650 prints so light that you can barely see anything on copies. Have changed toner and have tried image density; nothing helps. Ideas
Verify TD sensor, you change the develop and Performs the TD sensor initial setting.
1) Press the following keys in sequence.
Total clear yellow key, 1 0 7 and
Hold the clear stop key (orange key) for more than 3 seconds, to enter at service mode.
Enter 2801 and execute...
This SP mode controls the voltage applied tothe TD sensor to make the TD sensoroutput about 2.5 V. After finishing this, theTD sensor output voltage is displayed. It must show a value near 10 Try use original toner.
If this does not solve the problem, replaces the cylinder, and perform id sensor.
Feb 24, 2010 | Ricoh Office Equipment & Supplies
Tonner and cartridge clogged wont print dark
Why do you say it's the toner? Likely the PCU (photoconductor) needs replacing, or laser optics, etc.
If it's not a 'blinking toner light' that won't go away, but rather light copies for no apparent reason, then replacing the PCU is the most likely cure.
May 15, 2009 | Ricoh Aficio 3025 All-In-One Laser Printer
Replacing toner
Check the developer.
Jun 17, 2008 | Ricoh Aficio 250 Copier
237 people viewed this question
k24674
Marvin
Marvin
