Question about Philips 42PF9966 42 in. HD-Ready Plasma Television
Bad power supply and regulator circuit
I have a Philips 42" Plasma, 42PF9966/37 that after being on will shut down and blink red with a clicking sounds like it is trying to come back on. Took it in and they said I need to have the power supply and regulator circuit. I have pulled the back off as suggested and do not see any issues with any caps. Is it a bad power supply board and if so, where can I get one? Thank you!
  • jlafave Jun 25, 2009
    I actually replace the main power supply board. Based on what the TV repair shop said, that would solve the issue. They were wrong. When the new one was in it worked for about 3 hours so I shut the TV off and put it back on the wall mount. When I turned it on again, the problem started all over again. It is a huge pain that I changed the supposed problem but my tv is still not fixed and doing the same thing as before. To make things worse, there are no other repair shops in the area. Any other quick things to check?
    Scholar:
  • 44 Answers
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung. Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Is a Link to a photo of the PCB. Make a note of the locations of all cable connections then unplug them all. Un-install PCB, Check all Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. Look to see if the Caps are deformed and or split at the top. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
Posted on Jun 25, 2009
  • 80 Answers
Look for and replace any 3300uf capacitors on the board. Even if they do not appear defective visualy, they are probably bad.
Posted on Jun 01, 2009
Blinking red light and tv will not turn on.
problem on power supply , u may have 2 bAD capacitor
Apr 14, 2010 | Philips 42PF9631D 42 in. Plasma Television
I have a 42" philips plasma with 8 red blinks
90% of the time this is capacitor related in the power supply, Remove the back and check for capacitors that are domed shaped on top, Replace these and all should be ok.
Mar 05, 2010 | Dell W2600 26 in. LCD Television
Blinking red light no picture or sound
Either the power supply has failed, or a component such as one of the backlight inverter boards has failed. The blinking light is the TV's protection circuit which will not apply full-power to the system unless no obvious short-circuits or open-circuits are found. Some TVs do this test when the power-cord is plugged into the wall. Philips has a bad reputation with respect to power supplies, so the power-supply board is the most likely culprit. The failure in these power supplies tend to be bad capacitors.
Oct 19, 2009 | Philips 42PF9630A 42 in. Plasma Television
No power to my Phillips 42 inch Plasma 42pf7321d/37, just a red blinking light
Most likely it going to be a power supply related problem. The red blinking light is a code for a TV tech to diagnose the problem on the power supply board itself or the board that regulates the power for the screen. Some manufactures call it a Backlight Inverter Board. A TV repair shop should be able to look at it for you and tell you which board is bad.
Replacement boards can be found at a good price at Shopjimmy.com
Sep 05, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42pf9630/37a, Blink red LED 7 times, No Picture No Sound
7 blinks indicates a bad buffer board, usually I replaced the Y board and the buffer/s about $500-600 in parts. but before you buy anything open the set and look at the power supply if you see two capacitors that look swollen , bulging on top they need to be changed and may solve the issue. the power supply is middle top . If you are not wanting to repair it yourself then know that you do have some circuit board repairs needed.
thanks
Eric
Aug 17, 2009 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Philips 42PF7320A/37 blinking red light
hello, amigo if the all the caps are godd then you have to replace the power supply board. don't try to fix it this is not an easy task. you are looking at almost $200.00 with tax an shipping. just go to google and type your tv model # and ask for the power supply board or just look for the part# on the board itself. good luck
Jul 29, 2009 | Philips 42PFP5332D 42 in. Plasma...
Red light flashes & times
7 blink error is 8.6 volt error usually tied to y main board. would advise to disconnect y main from power supply and verify vs voltage. if vs is present replace y main and general protocol is to replace y upper and lower buffers as well as they complete circuit
Aug 10, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
NO PICTURE
7 blink error on that model is 8.6 volt error and generally caused by y main board. disconnect y main from power supply and if tv does not shut down and vs voltage comes up (test point on power supply) replace y main and both y upper and lower buffer boards as replacing one without other two could cause additional failures
Jun 26, 2008 | Philips 42PF9630A 42 in. Plasma Television
Phillips plasma
Five blinks is a severe hardware failure supplys not working. Viper is down. You have atleast a bad power supply board could have taken out your sustain boards. If you are good with a meter you can measure voltages and see if just your power supply is dead. If you have never handled a multimeter you will need a tech and a power supply is not cheap..Power supply is about a 600 dollar board.
Feb 05, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42 in. Plasma shut down
did u cheak the input cables does it do it on dvd input as well as others ?
Feb 01, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Philips 42PF9966 42 in. HD-Ready Plasma Television Logo
1,251 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
