Leaking from the bottom
This machine is leaking from the bottom . could it be the pump ? if so how do i check it
  • dewey1 May 30, 2009
    the model # is 110.26722693
    Hi, It turned out to be the drain line that was leaking, it has a hole in it.
    thanks for the help
    Dewey
    President:
  • 1,136 Answers
Hi, Please get me a model # so I can see the exact machine you have. I can help you through this.
Thanks
Vic
Posted on May 29, 2009
  • Victor
    Victor May 30, 2009
    Thanks
    Pull the washer away from the wall about two feet and tip it back against the wall. The pump is located right behind the front panel attached to the motor. With the washer tipped back, you should be able to see if water is dripping from the pump. The pump is attached to the motor with two spring clips. Please let me know if this helps you and let me know if I can assist you further.
    Vic
  • Victor
    Victor May 30, 2009
    You are welcome. please feel free to rate my response so that others as well as myself know how I am doing
    Thanks
Maytag Clothes Washer Top Loading LAT2500AAE - The tub leaks when it is full and filling and when draining.
check your water pump and hoses underneath. because if it's the tub actually leaking, you might as well look for a replacement
Oct 20, 2013 | Washing Machines
The smart drive washing machine leaks when in use what can I do? Thanks
if it is leaking from bottom check pump if it looks like rusty looking then its been leaking for a while replace pump if you keep operating washer with it leaking from pump it can also short out control board
May 13, 2011 | Fisher and Paykel Washing Machines
My wahing machine is leaking for he bottom
Please check the bottom side of the washer and see if there is leak on the drain valve/pump or the hose of the outlet. The most important is the first hand information from your observation.
There can also be a leak from overflowing or a leak from the tub.
Once confirmed then the leak can be confirmed by replacement of the valve/pump or the hose.
If not the estimation must be thought of before you proceed.
Feb 02, 2011 | Amana Washing Machines
Leaking from the bottom back
Hi, If not a hose leak, check for leakage around the water pump. On our top-load Kenmore, the leak showed up at the front right of the machine. Water was leaking where the pump slides onto the motor shaft. Replacement of pump consists of: (1) unplug power cord and then remove 2 screws at corners of the dial/control panel to tilt it back, (2) unplug wiring harness, (3) remove two spring clips holding white metal console to the frame then tilt console forward and remove, (4)pump was in front of machine with two black hoses attached via hose clamps - remove the spring clips at top & bottom of pump and remove the two hose clamps, (5) slide new pump onto shaft and reassemble in reverse order.
Take care
Jun 13, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
GWL11 Washer. Leaking from bottom. Doesn't appear to leak during wash cycle.
Have you checked the pump on the bottom of the washer? You may have to empty the water out of the unit by hand. Then tilt the machine backward. The pump is on the bottom and no tools are needed to remove it. If the pump is wet or rusted then that should be your problem. Another way to check the pump is to remove the 2 screw ib the back of the machine on the top, and remove the electronic controlls. inside the machine is instructions to turn the pump on.
Jun 18, 2009 | Fisher and Paykel GWL11 Top Load Washer
Leaking from the bottom of maytag washing machine
a good possibility that the front door seal is leaking check for tears or any small holes if it is that it it is hard to do
Jun 07, 2009 | Maytag Neptune MAH6500A Front Load Washer
There is a leak in the bottom of our washing machine
If the leak is from the front, you will need a pump. If in the rear check the water valve and the inlet hoses. Also if a lg leak check the hose from the pump to the drain grommet. They sometimes split.
Apr 07, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer is leaking...
Open the rear panel on the washer. Check the 3 rubber hoses connected to the pump. Make sure there are no splits, or a **** in any of them. Also look at the pump and make sure the casing is not cracked and dripping (if coins enter the pump they can crack the casing, causing a leak). If there is a leak in a hose, replace that particular hose. If the pump casing is cracked, replace the pump.
Apr 11, 2008 | GE Spacemaker WSLP1100D Top Load Washer
Leaky machine
check the pump and your hoses
Mar 31, 2008 | Washing Machines
Kenmore Washing Machine
Open up behind, after taking off the wall power plug. Check to see it the hose from underneath the tub is loose, tighten. Or replace hose if damaged.
Oct 07, 2007 | Washing Machines
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
