Question about Yamaha 5.1-Ch. Surround Sound Home Theater Speaker System
Chain Surround sounds?
Is there a way to chain say multiple 5.1 surround sound systems? Like having two 5.1 systems playing the same thing at the same time?
    Problem Solver:
  • 19 Answers
Yes, the simplest way is to feed the signal from whatever you want to listen to into both systems, either by using a "splitter" which takes the output from the signal source and "splits" it in to multiple outputs which you can feed to the 5.1 systems. Please rate my answer, thanks.
Posted on Jun 18, 2009
Unable to set surround sound to work
The media you are playing must have surround sound recorded or encoded on it in order for surround sound to play or occur. Get a DVD or CD that has surround sound stated on the label - otherwise the system defaults to stereo playback.
Oct 31, 2010 | Nakamichi AV-10 Receiver
Tip
How to make a connection to an iPod and Sony SS2300
<p>The SS2300 is a Sony digital surround sound system with a Blu-ray player. This gives you the ability to play high-definition video, while experiencing the content in full surround sound audio. However, the speaker system audio inputs, so you can connect external devices, including Apple iPods. Although no direct connection to iPod, you can use a single cable to the signal from the iPod surround sound system. <br /> <p><br /> <p>1. Insert the end of 3.5 mm to 3.5 mm to RCA splitter in the headphone port on top of Apple's iPod. <br /> <p><br /> <p>2. Connect the RCA cables into one of the "Audio In" ports on the back of the Sony SS2300. Multiple connections exist and you better take note of the connection you use. This makes it easier later on if the connection to the iPod. <br /> <p><br /> <p>3. Power on the Apple iPod and Sony SS2300 receiver. Press the "Input" and select the connection to the iPod is connected. <br /> <p><br /> <p>4. Press the "Play" button on the iPod and play audio content through the Sony surround sound system. <br />
on Aug 09, 2011 | Apple iPod touch
I'm having trouble with sound when i try and install a surround sound system. This is the second system I've had that my lg would not play sound
Firstly you must have the remote typically to set the speakers up or there is a combination of keys to do this but usually some functions cannot be changed without the remote.
Second, the surround sound playback can only be played if the sound that you are listening to has the surround sound track, otherwise you may not hear hardly anything when your device is set to the wrong function.
The speakers must also match the surround sound system otherwise you may not hear anything at all.
Remember: A 5.1 System is 5-speakers,   A 7.1 system is 7 speakers!
The speakers should be marked for which place they belong LF= Left,Front...etc.
Jun 12, 2010 | Audio Players & Recorders
Digital audio cable does nothing?
You need to look at the two sources that don't work for why they're not providing surround.
HINT: It is the rare TV that can provide surround. Video is a TV's strong suit, not Audio. TV's are usually at the end of the audio chain, not the beginning.
TV-related audio always come from somewhere else than the TV, so get it from the source, not the TV.
May 03, 2010 | Samsung HT-TQ85 System
Trying to make the sound go to the surround sound
how are you conecting the tv to dvd surround
phono plugs or scart /ero plug? best results are to conect from tv audio out to input on surround i have an older sony and it wont work though the start lead DONT FORGET TO SELECT SOURCE
Mar 04, 2010 | Sony DAV-C770 System
Not good surround sound Is the bose lifestyle 5 support 5.1 surround sound?
The Bose Lifestyle 5 is not a 5.1 surround sound system. It is a 2.1 sound system, meaning it is stereo with a subwoofer/bass unit. Having two speakers that can be angled in different directions, the Bose Lifestyle 5 employs Bose direct/reflecting technology,providing greater audio presence. Still, it is definitely not a surround sound system.
Jan 24, 2010 | Bose LifeStyle 5 Series-III CD Shelf...
Model wd-60735 sound will go up and down
I usually do not give short answers but here I will you what I would try first:
Connect a DVD unit or something else to one of the unused video inputs--make sure you have the speakers in the set turned ON and the surround sound system OFF.
If you do not have the problem when doing this it is very unlikely the problem is in the set--it is possible but I would put the % at about 5.
If it does the same thing with the surround system out of play it is a sound problem inside the set.
I would bet it will work that way---FYI if you are using a cable or Satellite box---it could also cause the problem if it is supplying audio signal to the surround system.
If this has helped you rate this solution as I do it here for free.
SD TECH
Dec 09, 2009 | Televison & Video
No sound through surround
this is because the home theater receives 5.1 channel... change it it will work...
May 17, 2009 | LG 1000W XM-Ready 5.1-Ch. Home Theater...
Surround sound hookup
Hook your satelite receiver to your TV. Then run from your TV audio out to your surround sound system. This should make your surround sound system work with anything your TV is playing.
Jan 04, 2009 | JVC TH-S5 System
Cannot TV to play throught JVC TH-C50
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=9f8aca666be88c19dfe7c8b7d3504340&q=JVC+TH-C50
Dec 24, 2007 | JVC TH-C50 System
Yamaha 5.1-Ch. Surround Sound Home Theater Speaker System Logo
137 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
