Hi I have a Philips 42 " 42pf5321d/37 bought 11.06 . My av went dead cant bring up menu or anything on the screen. I unplug the set, plug it in and the green light comes on , theres a few seconds and something inside doubleclicks like it's shutting down but the light remains green. except it looks a little funny. Not as bright as usual.
I tried to reload firmware and the memory device blinks like its being read but still no nothing. Appreciate help. I have a TV guy looking at it but is there an inline fuse that may be causing this? Any help appreciated. Dave R. same thing
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung, Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H. 2nd more of a long turn approach to your system.You might look at a Power conditioner to ensure constant clean Voltage & current to your Set,Price I know running about $150 to $200,but this will protect your set from a Spike and under voltage swings from the 110V plug.Surge protectors only help the Spikes on the 110v Line not the Drops.Hope this helps
Philipps 42 i have with screen going blank, mounted a quiet fan on back cover and it solved the problem! take off cover and run a house fan aimed at back, see if it works!!!!!!!!!!!!!!!
Picture will not turn on. The sound goes on and off and then a red light starts flashing. flashing...
(More)
Picture will not turn on. The sound goes on and off and then a red light starts flashing. flashing red light, 6 slow flashes and then 3 quick ones, repeatedly. The receiver is working, as the external sound system has perfect sound.
The picture just goes off but the sound is still on. If you turn it off for a few minutes it...
(More)
The picture just goes off but the sound is still on. If you turn it off for a few minutes it corrects itself - any thoughts? We previously had problems with the TV getting "stuck" on non-programmed channels - you would have to completely unplug to reset - this appears to be different
