Question about Sharper Image Ionic Breeze 3.0 Air Purifier
Blue light keeps blinking. no air coming out - Sharper Image Ionic Breeze 3.0 Air Purifier
  • 3 more comments
  • smith50951 May 30, 2009
    yes that is the model. sharper image ionic breeze. can you tell me how to fix the blinking blue light with no air coming out?
  • smith50951 May 31, 2009
    i have a sharper image quadra model S1867 blue light keeps blinking i've took it apart and cleaned it thoroughly. hope you can figure out why the blue light keeps blinking thanks , mary
  • smith50951 Jun 05, 2009
    blue light keeps blinking no air coming out have cleaned it thoroughly model #S1867 sharper image guadra
    the unit still doesn't work my husband checked everthing thoroughly i even cleaned it again still blue light blinking
    sharper image quadra ionic air cleaner blue light keeps flashing have done everything can think of to fix it your the 3rd person have asked to figure it out hope you can help
    Genius:
  • 1,239 Answers
Hi friend,
It is nothing but User friendly warning sensor
blue light keeps blinking. no - spacer.gifDonot install it sideways, under furniture or with its bottom air inletsor top outlets blocked, preventing air flowing undisturbed verticallyup. If any of these occurs, the thermo-dynamic sterilizing ceramic corewill be disconnected and the unit will not work properly. Under thesecircumstances after about one minute the anti-stress blue light willstart blinking indicating improper installation and eventualmalfunction. This warning sign prompts the user to install. Airfreeproperly. Once correctly installed after a few seconds the anti-stresslight will stop blinking.
Posted on Jun 05, 2009
  • ABHISHEK.C
    ABHISHEK.C Jun 05, 2009
    Cause 1
    Airfree
    incorporates an automatic energy-saving feature by automatically
    shutting off the ceramic core when it has reached a temperature range
    to facilitate air convection (air in the room is drawn into the machine
    to destroy impurities, contaminants and odors). The ceramic core shuts
    down for a few minutes, the indicator light turns off, and the top
    light emitting diode (L.E.D.) blinks. Airfree continues to sterilize
    the air during this time. This indicates the conservation of electric
    power consumption and the preservation of the ceramic core.
    Cause 2
    Another
    contributory factor to Airfree's blinking occurrence is the ambient air
    (air in the environment). When the ambient air reaches 95 degrees F (35
    degrees Celsius), Airfree auto-regulates itself with the ceramic core
    “shut off” for a few minutes but still continues with its sterilizing
    activity (the blinking of the top light signals this occurrence). In
    this process energy is conserved and Airfree's safety mechanism is
    enhanced.
    Cause 3
    Airfree
    incorporates state of the art electronics detecting any improper
    placementor device malfunctioning. If the top blue light does not stop
    blinking, please ensure that your Airfree unit is in the upright
    position. If the top and bottom air inlets are free of blockage, the
    blinking may be due to a faulty electrical outlet. Please plug it in
    into a proper outlet. If in the next 10 minutes the top light continues
    blinking and your Airfree unit is correctly installed, this indicates
    that the device may be malfunctioning. Please promptly contact your
    dealer in such case.
  • 1,959 Answers
Several things to check; .
One thing to check is its very important to tip the unit upside down several times after cleaning. This often forgetten step clears the ion wires of dust and debris and restores their ability to magnetize and pull dust and debris into the unit.
It's also very possible that one of the plastic grates has somehow become dislodged. The unit is designed to only run when the fins are completely in place and the outter grates are also properly seated.
Also, It's always very important to remember that after cleaning, it's important to let the fins (my word not theirs) completely dry. Placing them back in the unit even partially wet will ruin the unit. If this is the case, you may smell smoke.
Lastly, depending on the age and use of the unit, it's possible the unit is broken. This is less likely since there really aren't a lot of moving parts but possible all the same.
Best of luck with your Ionic Breeze. Try all of the above and I'm sure your unit will function properly again.
Greg
  • Greg Margossian
    Greg Margossian Jun 05, 2009
    If you press the blue light will it turn green or continue to flash blue?
  • Greg Margossian
    My apologies; a blinking blue light is an overheating indicator; the machine needs to be unplugged until it cools down at which time it will work temporarily until it heats up again and will again blink blue. Unfortunately, Sharper Image went bankrupt last year and all of their stores closed, making all those with the units (myself included) out of luck as far as the warranty goes. Sorry to be the bearer of bad news.
    Greg
  • 13,433 Answers
Can you send me the model, I think I got the brand already, sharper image ionic breeze?
Posted on May 29, 2009
  • 1 more comment
  • Ekse May 30, 2009
    could you get me the model from it, it reads on it somewhere, for example SI397
  • Ekse May 30, 2009
    I still need the model from your unit.
    also have a look into this:
    http://www.fixya.com/support/r772663-sha...
  • Ekse May 31, 2009
    I'm sorry unfortunately I can't help you, I don't have any documents for that model and sharper image is bankrupt. just press on the button / link on this page that says something to the direction of repost / i need the help of other experts / request another expert / and to that direction, you have the link/button somewhere there, just press on it and another expert should post you another solution within minutes.
Why does the blue light flash off and on continuosly"?"
Wayne,
I have attached a copy of the owner's manual. Page 6 in Safety section discusses why the light blinks. I hope it solves your blinking blue light issue.
PEACE http://www.sylvane.com/media/documents/products/airfree-onix-3000-air-purifier-owners-manual.pdf
May 24, 2014 | AirFree Onix 3000 Air Purifier
My oreck magnesium keeps turning off. Blue. Light keeps blinking
THE PROBLEM SEAMS TO BE WITH THE THICKNESS OF THE CARPET AND THE PAD-ALL VACUUMS NEED TO BE ABLE TO BREATHE IF THE PAD AND THE CARPET ARE THICK THE VACUUM WILL PULL ITSELF TOWARD THE FLOOR SLOW DOWN THE BRUSHROLL ENOUGH TO TRIGGER THE AUTO SHUTDOWN ON THE MAGNESIUM BECAUSE THE VACUUM CANT BREATHE. TAKE IT TO YOUR LOCAL ORECK AND THEY CAN PUT A FEW HOLES IN YOUR SOLEPLATE AND THIS WILL TAKE CARE OF THE ISSUE.
Apr 02, 2013 | Oreck Magnesium Upright Vacuum Cleaner
The blue light blinks
I believe that a blue blinking light indicates that the stainless steel collection blades need to be wiped clean. The unit uses these blades instead of a replaceable filter. Simply wipe them clean with a damp cloth and you should be ready to go!
Jun 24, 2010 | Sharper Image Ionic Breeze 3.0 Air...
Red light keeps blinking
I take mine apart when red light comes on and the filters and inside good. It goes off when the unit is screwed back in and turned back on
Nov 15, 2008 | Oreck XL Professional Air Purifier
The blue light on my ionic breeze is blinking.
The ionizers were recalled by Sharper Image due to a lawsuit that they lost forcing the company into chapter 11.
There is a thread on this website with further details.
Sep 13, 2008 | Sharper Image Professional Plus Ionic...
SHARPER IMAGE AIR CLEANER HAS STOPPED WORKING, NO BREEZE COMING FROM UNIT AND BLADES ARE NEVER DIRTY. THE "ON" LIGHT IS ON.
Sharper Image no longer supports Ionic Breeze machines. They recalled them a few months back since Consumer Reports and the EPA has determined that they weren't working and can even cause health hazards during usage. Sharper Image sued an lost forcing the company in bankruptcy.
The Consumer Products Safety Commission is going to make a decision on sales of all ionizers in the U.S. by the end of the year. It's looking like you won't be seeing these around much longer.
Jul 06, 2008 | Sharper Image Ionic Breeze Air Freshener...
Blinking blue light on ionic breeze s1871
Wher can you return it? Does anyone have and address? My Dads unit has a blinking blue light and the folks at sharper image say to bad so sad only after 2 months out of warrenty. Is there any one out there that can help? I am done buying things from Sharper Image with their attitude! hlaytos@aol.com
Mar 22, 2008 | Sharper Image Ionic Breeze GP SI730 Air...
Blue lights are blinking
I have the small version Quatra our older unit finnally died so sharper image sent us this smaller version. This will be the 2nd or 3rd replacement with in a week of getting a repalcement everytime the light starts blinking before it can even get dirty.
Mar 20, 2008 | Sharper Image (V23145) Air Purifier
Blinking blue lights on top
OK so after a bit of investigating there is still HOPE!
There are no details about the blinking light except that the unit is "broken". Mine appears to still be somewhat functioning as I smell ionized air.
As you all know, Sharper Image is Bankrupt and their stores have all closed. Here's where the ray of sunshine comes in:
If you purchased the extended warranty all you have to do is call 1-866-686-2463 24 Hours 7 days a week. The gentleman who helped me confirmed the information on my original receipt so there must be some database I am registered under. I will be receiving a replacement within a week.
I will take mine apart to see if I can repair the broken unit and if I find out the problem I will post up.
Here is something for you to try...Unplug the unit and plug it back in while holding down the boost button. This seems to trigger some form of diagnostic. On Low the clean light is red and then amber in the other positions. The boost button flashes. It may do something different for you that is why I bring this up.
Dec 12, 2007 | Sharper Image (SI871 GP) Air Purifier
Sharper Image Ionic Breeze 3.0 Air Purifier Logo
222 people viewed this question
Top Sharper Image Air Purifiers Experts
Daniel Dollive
Daniel Dollive
Jay Finke
Jay Finke
Are you a Sharper Image Air Purifier Expert? Answer questions, earn points and help others
