Question about Vizio L32 32 in. LCD HDTV
Need color settings for 32" lcd vizio
My tv color has alot of brown and yellow i need the correct settings for my color.
SOURCE: LG tv color problem
i had the same problems, called LG customer service, advise to check components cable, and make sure they were all blugged in correctly, ans sure engough, the red cable was discontected ,and after correcting that, the problem was solved
Posted on Oct 01, 2007
SOURCE: Power board for 32 in. Vizio
http://www.vancebaldwin.com/
Posted on Dec 21, 2007
SOURCE: Vizio LCD Green Pixels
call tech support and send it back to them. it is a defective tv. im having the same issues
Posted on Apr 09, 2008
SOURCE: code for Vizio tv
The code for Visio L32 for cable or satelite remote is 0178 or 1758 for 4 digit and 10178 for 5 digit.
Posted on Oct 20, 2008
  • 395 Answers
SOURCE: Vizio 32 inch now shows mostly only green and red colors
Please try to reset all setting and then to see if the problem is solved. 1. Press the Menu on your Remote Control;
2. choose Set up on the OSD;
3. then choose Reset All settings;
4. Press the Exit on your Remote Control to remove the OSD
Posted on Nov 30, 2008
The colors are going out in Vizio E320VL. Can I fix this by replacing the main board or is there another solution?
Sounds like a faulty Timing Control board, I had the same problem except yellows showed up green.
Apr 03, 2013 | Vizio E320VL 32 in. HD Ready LCD TV
55" LCD TV NS-L55X-10A HOW
hopefully your backlight isnt going out. but it sounds like you need to reset your saturation and coloring its in the menu feature also check your contrast settings. let me know if this helped.
Mar 17, 2011 | Insignia Televison & Video
I switched out backlights on my 32" vizio E class
If the boards are not the same then this is your problem, u need the correct inverter board. and yes ground has alot to do with voltages working properly. what causes a white or light screen mostly is the t-conn board this is usually a small board at the top under a shield, if this set has one then it will be worth checking out too.
Jan 26, 2011 | Vizio VW32L 32 in. LCD HDTV
Amber light issue vw32l lcd Vizio
Its easier to open up your tv, look at the mainboard id number. Then do a search on google or ebay for the parts. Its alot easier then trying to troubleshoot the actual circuit board, unless your an electronic engineer.
Jul 11, 2009 | Vizio L32 32 in. LCD HDTV
My Vizio has no green color. Other color are very
What type of connection are you using? if you're using component, make sure all the red, blue and green matches. If all is correct, go to menu, picture and all your color setting is there
Jun 10, 2009 | Vizio L32 32 in. LCD HDTV
Change in color, computer problem inside TV
For "thechances", The LVDS cable has gone bad. This cable connect between the mainboard and the panel. The replace the cable will fix the problem.
Feb 17, 2009 | Vizio L32 32 in. LCD HDTV
Vizio 32 does not turn on
The tv not not power 0n dead set,1 ic blown out stby sw,how I can fix the board.Thank you.
Jun 21, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
211 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
