Question about Kenmore 44932 Front Load Washer
Error F-H scrolling?
I'm getting this error measage in the middle of the cycle. The unit is a Kenmore model #110.44936200 front loader cloths washer.
Any advice would be greatly appreciated.
Thanks, Jim
  • Wizard27 Nov 05, 2007
    Attention: Remt23c
    I've had some communication problems with my e-mail account and missed you last response. In regards to the Kenmore washer. I've replace the pressure switch and verified the hose is in good working condition. It is properly conected at both the switch and tub. Drain is working properly. I'm still getting the F/H scrolling error. Its intermitant, one failed cycle out of every 7 or 8. Any other advice. Thanks Jim (wizard27)
    F/H:
    Condition
    No water detected entering machine or Pressure switch trip not detected.
    If there is water in the unit:
    1. Verify Drain pump operation
    2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
    Verify there is not a siphon problem
    Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
    Check all hoses for possible leaks
    Verify pressure switch operation
    Verify flow meter operation
    Verify CCU operation
    mainly caused by low water pressure into the water from the customers water supply, or clogged inlet water valve screens.
    Make sure you don't have any duct tape or something around your drain pipe, it needs that air gap to prevent siphoning.
  • 78 Answers
F/H:
Condition
Posted on Oct 22, 2007
5d error code kenmore he2plus
Here's a video prem mathew suggested as a solution to your problem from YouTube:
Kenmore He2 washing machine washer drain problem fixed
Apr 26, 2013 | Kenmore Washing Machines
Push Start button on our kenmore front loader washer model# 41744082400 and get error code 33.
F33 error code indicates Pump drive system error. Try running the unit empty, set to a cold/cold cycle. If this does not help, you will need to have the unit checked by a service technician.
thank You
Sep 10, 2010 | Kenmore Front Load Washer
Gorenje washing machine wa 72145 washing clothes but doesnt spin keeps comimg up child lock
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 13, 2010 | LG WM2301H Washer
Kenmore washer 3.5 super capacity. Machine spins
It sounds like your tub bearing is bad or going bad. It could be the adjustment on your spin cycle. Does your unit allow you to adjust this. Also are you overloading. Can you send me the brand and model of your unit and I help you more.
JimmyC
Oct 05, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Code error problem
THIS IS TEMPORARY FIX, NOT A TOTAL SOLUTION. jUST TO GET WATER TO DRAIN AND RESET WASHER. , WITH WASHER POWERED OFF, PUSH AND HOLD START BUTTON FOR 4 SECONDS, RELEASE FOR 4, PUSH FOR 4 RELEASE FOR 4 UNTIL THE FRONT ALL LIGHTS UP AND DISPLAYS 88. sOON YOU WILL SEE YOUR CODES FLASHING, PRESS START BUTTON AS MANY TIMES NEEDED TIL NO MORE CODES FLASHING. tHEN WASHER WILL GO INTO DIAGNOSTIC TEST. aFTER THAT I DO NOT KNOW, BUT YOU CAN WASH 1 LOAD OF CLOTHES AND THEN PERFORM DIAGNOSTIC TEST AGAIN. THAT IS WHAT I AM DOING JUST TO HAVE A WORKING WASHER TOO MUCH TO FIX FROM WHAT I AM READING, SO GOING TO BU A NEW ONE ANYTHING BUT KENMORE. gOOD LUCK, HOPE THIS HELPS FOR IMMEDIATE RESCUE.
Jul 24, 2009 | Kenmore HE2 Plus Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Front loader will not spin out cloths. Flashes errors sometimes.
Without the error codes in question it is impossible to help you.
May 07, 2009 | Kenmore Washing Machines
Kenmore front load HE2 plus
I have a F01 error message on my Kenmore He2t washer. I tried to add clothes to a wash and restart and continue to get the message. Please help
Jun 14, 2008 | Kenmore 46462 Front Load Washer
Kenmore HE front loading washing machine
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
May 15, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 44932 Front Load Washer Logo
118 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
