Question about Dell Latitude D505 Notebook
Hard drive died & replaced with a new hd
Used system cd to install Windows XP on new hd. Message say No Bootable Devices found. Boot device sequence is CD, FDD, HD. Any suggestions?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Press F2 to go back into the BIOS and load defaults, then save changes and exit and see what happens.
    Scholar:
  • 106 Answers
Make sure your pc is recognizing the drive before installing any program. If the drive is recognized but is still not booting, then reset your pc as soon as the pops up press f12 which will show a list of the booting order you of course will want to select cd drive or you can enter f2 and make the booting configuation changes thru your BIOS in the Booting Sequence. change the order or replace the drive or drivers and Voila Your good to go, Hope this helps
Good Luck =)
Posted on May 30, 2009
WHAT IS .NTLDR .WIN XP HOME
NTLDR is the file that loads the OS. (It expands to NT Loader - all versions of Windows from WIN NT (Win2K) through XP used this file.) The message could indicate the ntdetect.com is damaged.
First make sure that you do not have a non-boot disc in the floppy or CD drive. Similarly, if your computer can boot from a USB device, unplug flash drives or other USB drives. Make sure that your boot device order is accurate (your C: drive should be first) in the BIOS. (Accessing the BIOS depends on your computer, often you need to repeatedly press F1, Esc, Del, or F10 after turning on the computer. There should be a screen that shows you the correct key.) While you are in the BIOS, make sure that your hard drive is recognized by the machine. If your hard drive isn't recognized, try replacing the data cable with a new cable and switching power connection cable with another from the power supply.
If the hard drive is present, the first solution is to get a bootable CD and copy the files back to your C: drive. You can use a Windows XP install or upgrade disk. For this type of source. Boot to the CD (press any key) and then enter the Repair option (R). Choose your Windows installation and enter your administrator password. Then copy i386ntldr and i386ntdetect.com from the CD (D: or E: drive) to the C: drive. (for example: type "copy d:i386ntldr c:" without the quotes )
The boot information (MBR) could be damaged. In that case, the you'll need the Windows CD to run fixboot and fixmbr from the Recovery Console.
If the above doesn't work, you should try a new hard drive and copy the files to it. Make sure that you format the drive to create a bootable disc. (Use a bootable diskette, if needed.)
I hope this helps.
Oct 28, 2013 | Computers & Internet
The power light is on, but the monitor is off
This error can be caused by one or more of the below possibilities.
Floppy or CD that is not bootable is cur...
BIOS or CMOS setup is not setup properly...
Hard disk drive does not have bootable f...
The hard disk drive is bad or not connec...
Solution: Floppy or CD that is not bootable is currently in the computer Verify that no floppy diskette or CD is currently in the computer. If a diskette or CD is in the computer that is not bootable your computer may attempt to boot from that diskette or CD causing this error message.
BIOS is not setup properly Additional information and help with getting into BIOS or CMOS setup can be found on http://www.computerhope.com/issues/ch000...
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected ....
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
 - Floppy drive
 - CD drive
 - Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Hard disk drive does not have bootable files on it It is possible that command.com or another bootable file may be missing from the hard disk drive. Follow the below steps to possible resolve your issue.
Windows 95, Windows 98, and Windows ME users
Boot from a bootable floppy diskette.
At the A:\> type fdisk <press enter>
If you receive a message no fixed disk present, read Hard Disk drive is bad or not connected ....
If you are able to get into fdisk, choose option 4 to display the partition information. In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined, no information is on your hard disk drive and you will need to create a new partition. See our fdisk page for additional information.
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:\>
Once at the A:\> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
This should return a message 'System Transferred', if you receive bad command or file name and have verified you have typed the command properly, you will need to obtain a bootable diskette with the file sys.com on it.
If system was transferred successfully, reboot the computer and issue should be resolved.
Windows 2000 and Windows XP users
Boot from either your ERD, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
All users
If your operating system is not listed above or the above steps did not resolve your issue you can also try erasing the hard disk drive and starting over.The hard disk drive is bad or not connected properly
If you have attempted all above suggestions and you are still encountering the same issues, verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
Unfortunately, if all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Or:
Cause:
This is an expected operation. In the Boot Device priority setting in BIOS, you will see Removable Dev. (floppy), Hard Drive, ATAPI CD-ROM, and typically last is Intel® UNDI PXE 2.0. This setting will attempt to boot off a remote agent using the onboard NIC. By seeing this message it means the PC cannot find a boot partition on the floppy disk, hard drive or the CD ROM to load the operating system. Solution:
Install an operating system or put in a bootable device into the floppy or CDROM. If you do not plan to boot to a remote boot host, you may disable the Intel® UNDI PXE 2.0 option from the BIOS setup utility boot order. Relevant Information: No operating system installed
C drive does not have an operating system loaded
No bootable floppy diskette in diskette drive This applies to: Intel® Desktop Board CA810E
Intel® Desktop Board D810E2CA3
Intel® Desktop Board D810E2CB
Intel® Desktop Board D815EEA/D815EPEA
Intel® Desktop Board D815EEA2/D815EPEA2
Intel® Desktop Board D815EFV/D815EPFV
Intel® Desktop Board D820LP
Intel® Desktop Board VC820
End of Interactive Support Announcement
These products are no longer being manufactured by Intel. Additionally, Intel no longer provides interactive support for these products via telephone or e-mail, nor will Intel provide any future software updates to support new operating systems or improve compatibility with third party devices and software products.
THESE DOCUMENTS ARE PROVIDED FOR HISTORICAL REFERENCE PURPOSES ONLY AND ARE SUBJECT TO THE TERMS SET FORTH IN THE "LEGAL INFORMATION" LINK BELOW.For information on currently available Intel products, please see www.compaq.com and/or developer.qompaq.com
Comment by Beni S-P, posted on Oct 26, 2007
And i forgot :
check power suplay and ram???Let me know if u get help???
Oct 30, 2007 | HP Compaq Business nx7010 Notebook
My Acer Aspire T650 Computer came with Windows XP Home Edition installed on it. However, viruses invested the operating system and I had to do a fresh installation. Because the computer did not come with...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 26, 2011 | Acer Aspire T650 (AST650UC3601) PC Desktop
Emachine NAV51 won't start up. It keeps showing this: Intel UNDI PXE_2.1 (Build 082)_Copyright(c) 1997-2000 Intel Corporation_For Atheros PCIE Ethernet Controller_V2.0.0.9 (05/08/09)_Check cable...
Long answer:
Your computer tries to "boot" from various devices:
* the 'A:' diskette drive
* the CD-ROM drive
* a bootable image on a USB memory-stick
* via the network-adapter, if there is a "boot-server" somewhere on your local network.
So, enter BIOS SETUP, and check that your disk-drive is one of "enabled" boot devices. Also, check that the disk-drive is "detected" by the BIOS.
If your disk-drive is not connected, or not responding, and there is nothing in the 'A:' drive and nothing in the CD-ROM drive, then the PXE (Pre eXecution Environment) will try to "talk" to a boot-server on your network. If no such server is found, you get the "check cable connection" message, and you are prompted to put some "bootable" media into the 'A:' drive or the CD-ROM drive.
Short answer: your disk-drive has "died". You need to replace it, and to install Windows onto the new disk-drive.
I hope that you recently made a good "backup" of all your data files!
Oct 20, 2010 | E-Machines eMachines Desktop PC
No boot sector on hard disk - No bootable devices - strike F1 to
AFAIK all XP disks were bootable so maybe check your bios options.
If they are correct and it still does not boot them goto bootdisk.com and download the floppy setup disks for XP. You could then set your laptop to boot from floppy and install xp from there.
Aug 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Just bought a laptop cheap as on trade me for extra battery was told that it was broken but fired it up and works but is asking me for a user name and password to log on to windows. can i over ride it or...
keep the laptop, hope it got a working cd-rom/dvd-drive !(if not, take-out /replace the harddisk)
-win xp has to be removed from harddisk,
the hd must be formatted so you got a blank hd to set up your new system
you'll need :
- antoher PC with internet connection and cd/dvd-burner
- a win98 installation cd or bootable savecopy of it,
- a new win-xp install cd plus cd-key
- a program called PC Wizard(download)
and a bit of time...(one night or two:-)
follow instructions:
if you can enter bios (press F1 or F2 or Del)
during booting), youre lucky...
enter bios while booting, in the menu look for boot otions or devices, change order of boot devices, so that cd/dvd-drive is 1st, then save and exit (F10)
insert win98-CD, boot from cd, try to setup win98, you'll be asked to erase/ format all data/installations/partitions
on the harddisk (drive c:,probably), do so, format the drive using the FAT32-file system,
then end installation without fully setting up win 98.
now you should have a blank disk witout any operation system on it.
now put in win xp cd, go through the whole installation process
install and run pc wizard(it'll tell you all hardware devices of the laptop)
get the proper drivers for the notebook for win-xp from the net(google might be helpful)
install them.
happy computing!
if all this did not work, remove the harddisk,(you'll have to unscrew a lot of the laptop)
replace it by a new s-ata ide-drive()and..
erh.. come again then, this is a long process as well
Jul 23, 2009 | Microsoft Windows XP Professional SP2 Full...
Hard Drive Prevents any other windows device from loading
Hi, Mark Here.
Yes the setup on the xp install puts drivers into memory, but being an older version of windows B4 sta was out it does not have drivers to support it.
You could go to Microsoft & search for a new version of setup install drivers that includes sta, & download to thumb.
Really typical Windows Failure (driver not available freeze up or blue screen).
Mar 22, 2009 | Computers & Internet
No bootable devices
go to BIOS MENU by pressing Del or F2 while booting...then check the boot priority and first boot device..change it to hard disk...if then same problem occur then your hard disk might have some problem...
Jan 23, 2009 | Dell Inspiron 2200 Notebook
Dell Latitude D505 Notebook Logo
154 people viewed this question
Alun Cox
