Question about Sony Playstation 3 (PS3) Console
Playstation 3 turns off immediately after turning on power
When the Playstation 3 system is turned on, it immediately turns off and the red light begins blinking until you hit the power button again.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Try this, turn on the ps3 but as you do, hold the power button down for 5 seconds, this will do a reset. Let go and see if you get video.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 64 Answers
From my experience this usually means that your console is not recognizing the HDD (hard drive) for what ever reason. A PS3 will not turn on if it thinks further damage will occur. Here are two things you can do;
1. Try accessing the repair menu. Here's how you do this: With a solid red light showing, hold down both the power & eject buttons. You're going to hear a single beep, then a double beep. Once you hear the double beep, release both buttons. You'll get a message on your TV saying "connect your controller using USB". Following all the instructions will lead you to a 6 item menu. You are going to choose number 3. If that option doesn't work, pick number 6. BE WARNED!!! Number 6 will delete ALL of your saved memory! I know that really sucks, but this may be the only way to save your console short of repair. You can "back-up" your saved data using a "USB storage device" Like a memory stick or even your iPod.
If none of this works, or the console won't let you do the "double button" thing, it'll need to be repaired. You can contact PSR repairs at www.psr1.com. They are really great! They do both warranty & non-warranty repair work for a very decent price. I hope I helped. Good luck, FAMILIA!
p.s. My mom's name is Garcia, also. So you know I won't steer you wrong, carnal!
Posted on May 30, 2009
When i turn my PS3 on the light goes from red to green but nothing else happens, the discs load and eject thats it. You cannot turn the system off without turning the power off at the wall.
This is a problem with the Playstation 3 software becoming corrupt. It is very easy to fix if you follow my simple steps.
Please note, this method will erase your hard drive so any save games you had will be lost. All your online trophies will be preserved.
Step 1.
Turn your Playstation 3 off into standby mode (red light on)
Step 2.
Press and hold the power button. The Playstation 3 will beep when you first press it, then beep again 5 seconds later and then beep once more and turn off back into standby mode (red light on). You must now release the power button.
Step 3.
Press and hold the power again. The Playstation 3 will beep when you first press it, beep again 5 seconds later then there will be 2 quick beeps together. When you hear these 2 quick beeps release the power button.
Step 4.
Your Playstation 3 will now start up with a screen asking you to connect a controller via USB. Connect your controller and then press the PS button.
Step 5.
A menu will now be displayed on screen. Select option 5 "Restore PS3 System". This will then ask you to confirm that you wish to go ahead with the system restore. Accept whatever the Playstation 3 says.
The Playstation 3 will now go through the system restore process and re-install the system software back to out of the box status. You will have to set your user name, date and time and network settings again.
Once you have completed the above, the Playstation 3 will restart and spring back to life again!
I hope this helps all of those out there who are suffering this problem
Jan 01, 2011 | Sony Playstation 3 (PS3) Console
When entering a game I hear sound but no picture. Plugged in correctly and TV set to HDM11.
If you are sure that you have your TV on the correct input, you can try resetting the PS3's video settings using the following procedure:
  1. Before changing cables, make sure the PlayStation 3 is turned off using the main power switch on the back of the PlayStation 3 (the 0 side is pressed down).
  2. Unplug the power cord of the PlayStation 3 and television (or display) from the wall socket.
  3. Make sure the HDMI cable is connected to the [HDMI OUT] port on the back of the PlayStation 3 system.
  4. Connect the other end of the HDMI cable into the [HDMI Input] port of the TV or display monitor.
  5. Plug the PlayStation 3 and television (or display) back in to the wall socket.
  6. Turn the main power switch on the back of the PlayStation 3 back on (the line on the power button is now pressed).
  7. While the PlayStation 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  8. Turn ON the PlayStation 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
If that does not resolve your issue, try the other steps here:
http://us.playstation.com/support/answer/index.htm?a_id=262
Oct 25, 2010 | Sony Playstation 3 (PS3) Console
My ps3 is dead!!!. flashing red light
Follow the procedure below to fix the problem on your ps3,
1. Turn off Playstation®3.
2. Hold the power button down; the system will turn on and turn off once again.
3. Once the System has been shutdown, re-press you finger until you hear 2 consecutive beeps
4. When you hear the 2 beeps take finger off power button.
5. You will be prompted to plug in your controller via USB and then hit the PS button
6. The Recovery menu will pop up.
The current Recovery Menu supports:
• Restart System: Restarts the PLAYSTATION®3 System.
• Restore Default Settings: Reset all system settings back to default.
• Restore File System: Checks for corrupt/missing system files.
• Rebuild Database: Rebuilds the OS for the PLAYSTATION®3.
• Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
• System Update: Update the PLAYSTATION®3 System.
Take care.
Jul 20, 2010 | Sony Playstation 3 (PS3) Console
My PS turns on Green light and all, but my television screen is showing only all black. . .what is the problem?
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor)..
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
My ps3 screen wont show when i turn the ps3 on.
Jun 28, 2010 | Sony PlayStation 3 40GB System
Everything is hooked up and the ps3 turns on but it doesn't show up on the T.V
Jun 27, 2010 | Sony Playstation 3 (PS3) Console
Playstation 3 power issue
Your system has overheated. If it doesn't get on at all anymore, you should get it fixed in the place you bought it from. That happened to me.
Feb 14, 2010 | Sony Playstation 3 (PS3) Console
My dad cant hook mine up for some reason
Ok
First, Turn your T.V. on and go to the input mode on the t.v.
Second, there should be two cords in the back of your playstation3.
The power cord and the input cord. These are the two basic cords to turn your playstation on.
Once you have them plugged in, on the back of your playstation 3 there should be a power switch right above the power cord. Click it on so that the I is down and the O is up. In the front of your Playstation, a red light will appear indicating that the Playstation is ready to be turned on. Tap the red light until it turns green ( this should only be tapped once) When it is green the system will go to the start-up menu and enjoy your Playstation 3
Jan 15, 2010 | Sony Playstation 3 (PS3) Console
While on vacation switched to 1080 now home and have regular tv now cant see to get back to regular. Im to the far right of menue. Need to know many to go right, down, button to hit to enter and then how...
Try resetting the video output. Follow the steps below:
  1. Before changing cables, make sure the PLAYSTATION 3 is turned off using the main power switch on the back of the PLAYSTATION 3 (the 0 side is pressed down).
  2. Unplug the power cord of the PLAYSTATION 3 and television (or display) from the wall socket.
  3. Make sure the AVI cable is connected to the [AVI OUT] port on the back of the PLAYSTATION 3 system.
  4. Connect the other end of the AVI cable into the [AVI Input] port of the TV or display monitor.
  5. Plug the PLAYSTATION 3 and television (or display) back in to the wall socket.
  6. Turn the main power switch on the back of the PLAYSTATION 3 back on (the line on the power button is now pressed).
  7. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the On/Off button long enough to reset the Video Output Settings.
  8. Turn ON the PLAYSTATION 3 and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Thank you for using fixya!
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
9,698 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
