I have damage in my screen and i think if some new version available which more clear so i dont know the items number or i buy the basic one
please advice
SOURCE: Update to flickering screen on Toshiba 42H81
How did the repairman prove the blue CRT is bad ? Did he cover
the CRT leaving a good red & green video with no flickering or did
he cover the red & green and observe the flickering in blue...?
Did he discuss the hyper module with you ?.........T.
SOURCE: Where can i get a Screen for toshiba 42pw33p model ??
The model number 42pw33p is not a valid Toshiba model number. However, 42H81 is a valid number. The listing below is for model 42H81 ONLY! Double check you number before purchasing.
There are 3 screens that make up the screen assembly The inner screen is the Fresnal Screen. The middle screen is the Lenticular Screen and the outer screen is the Protective Screen. Please click on the links below to purchase these items.
Fresnal Screen
Lenticular Screen
Protective Screen
SOURCE: Cracked screen
rmaura,
My Toshiba TE55T11 also has a broken screen. I contacted the Toshiba hot line in Australia and they said that they don't make screens for this TV anymore. so i just got a new Toshiba 72CM9UA.
I hope this info is useful!
SOURCE: Toshiba 46In HD Rear projection TV Vertical lines on screen
We also have vertical lines with our JVC 62"... turning it off and letting it cool down is the only solution. For us, we know it's a problem with heat. We simply are wits end on fixing it. added two additional fans, a exterior fan to blow heat away from the back of the tv, pulled everything else away, etc.... Anyway, goodluck.
SOURCE: my toshiba big screen tv is shaky and blurry
most likley your problems are on the hyper board in the set
it will sorta dance at the top and be shaking back and forth at a fast rate
it would require the hyper board being repaired or exchanged
you would most likley wont to locate a professional in your area to assist with this repair
average repair is 280 to 320 in my area
