Question about Siemens Dishwashers
Have installed fully intergrated dishwasher during install have lost two screws that tension door
  • pont56 May 29, 2009
    I live in Launceston Tasmania Aust. need to know closest connact or service agent to get these screws? Thank you.
  • Siemens Master
  • 19,396 Answers
If you have lost small parts they may not be listed online.
Better contacting Siemens Appliances and asking replacement screws, or finding a local part seller.
Tell me your location or Put ' Siemens Appliances ' in Google to find the contact , then give me the ring.
If you tell me where you are based I can give you more contacts.
Thanks.
Also let me now if they do no ship in your location, I will find more sellers.
Posted on May 29, 2009
My dishwasher door will not stay up unless locked. I have installed new springs, to no avail
Might help with solution if you provide make and model number of dishwasher.
Sometimes the solution is a simple as ensuring the dishwasher is level so that the door shuts. The spring tension may need adjustment and usually there are a few screws at the top of dishwasher panel. Depends on make and model.
Jan 05, 2013 | Dishwashers
ADJUST TENSION DOOR
Just below dish loading door there is a panel. Remove screws (if applicable) to find tension adjustment. Turn screw to the left to loosen or opposite lifting door open or closed untill happy with tension. Some washers have no adjustment, I suggest opening door fully and pulling out bottom load tray, loading and then top tray or rack, pushing top in first then bottom rack. Use a glass fry pan cover or fry pan for weight on door while filling soap. Good luck, best regards
Jan 31, 2011 | LG 24 in. LDF 7811 Built-in Dishwasher
How do i change the door panel on an intergrated neff dishwasher
check out www.applianceart.com./ You may not need to change the panel just cover it. They have hundreds of designs and colors and even a stainless steel option
Apr 09, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
After installation my new dishwasher is leaking around the door. My dishwasher is a FDB1100RHC2 TH94532456
Improper installation - either the legs are not leveled properly, the tub is "twisted"by tension made by wrong screw placement on the top, or the door is rubbing the top or one of the sides. The worst case scenario would be a damaged dishwasher frame, but it's rare.
Dec 17, 2009 | Frigidaire 24 in. PLD2850 Built-in...
How do I take the intergrated door of a busted whirlpool ADG 7540
open the door and inside you will see some screws, some of these screws hold the dishwasher door together and some (about 4) hold the integrated kitchen unit door on, trial and error
Apr 05, 2009 | Whirlpool 24 in. ADG7540 Built-in...
I have neff intergrated dishwasher, but the door does not seem to stay on. It has two fixings at the bottom and two at the top. Any ideas?
When you open the dishwasher door you will see three screws along each edge. You need to remove the middle screws and replace them with longer ones that will go into the door front as well.
Feb 17, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
Hotpoint LFT114 Fully intergrated dishwasher. Hi I've just installed this machine and I find it very noisy compared to our old one. Everything seems to be working OK and dishes come out clean but can't...
Hi! noises can be very elusive, but some more info might give me enough to narrow down your search or figure out if what you are hearing is normal. First, what dishwasher did you have before? The noise that you are hearing, is it during the fill cycle, the wash cycle , drain cycle or just overall noisier than your old one
Nov 05, 2008 | Dishwashers
Dishwasher Door Tension Adjust on Electrolux EDW5500DSS
I just adjusted my Electrolux DW springs. The springs are on the bottom sides near the back. They pull on cables that hold the door (via pulleys). The springs can be moved to five different holes to change the tension, but I needed to pull the DW about 2/3 out for side access.
Oct 26, 2008 | Dishwashers
I have a Ignis by Whirlpool ADL 349 A/1 fully intergrated dishwasher which has not been used yet, but the door tension is really bad you cannot keep the door fully open to load or unload as it springs back...
I also have the same problem so i rung customer care & they said it is not a fault just the spring is working too good. Said it will settle down after a while.I keep pullig door down & up just to see if it settles down. Will let you know in a week or so if there is any change
Hope this helps regards Ray.
Mar 17, 2008 | Whirlpool Dishwashers
Adjusting the door on a neff dishwasher
I have the same problem with my newly installed Miele integrated dishwasher. The door does not stay open when you are trying to load dishes. I heard that there is an adjustable internal mechanism to adjust the tension on the door. But, I am still working on solving my problem.
Mar 16, 2008 | Neff 18 in. S5943 Slim-Line Built-in...
Dishwashers Logo
43 people viewed this question
Top Siemens Dishwashers Experts
aliasger yq
Mike
Are you a Siemens Dishwasher Expert? Answer questions, earn points and help others
