Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Grinder setting i
Is 0 the finest? or all the way up to 18.. something is up with my saeco vienna super automatica.  Coffee is too weak! Recently removed the bean hopper assembly cleaned and put back. (2 screws) did I mess it up?
0 is the finest setting. If you read the manual, it advises to adjust your grinder ONLY when the grinder is actually working. Also, you should only adjust it gradually from one setting to the next (ei. from 2 to 3), and wait about 5 cups before adjusting the setting again.
Posted on Nov 15, 2007
SOURCE:
Why does it brew weak coffee?
can depends many factors, try to grind finer coffe powder and warm well the machine before starting to brew coffee. If the grinder does not make finer coffe powder then you must contact the service, check if blades are in place before calling them...
Jan 19, 2016 | Saeco Vienna SuperAutomatica Coffee...
Weak coffee saeco vienna "not digital "
Hi
Has the size of you ground coffee changed? If it is not the size of granulated sugar then its your grinder. Check ebay completed listings. Saw one there couple weeks ago.
Nov 24, 2009 | Saeco Vienna Digital Coffee Maker,...
WEAK espresso from Saeco Vienna!
Well, when you set it that low it allows the water to pass very quickly and if the water passes very quickly there may not be sufficient time to absorb the coffee; hence weak coffee. The setting should be reset to the middle, at 10, and tried again. Then, if you want to change it move it only one or two numbers for enough cups to see if there is any change before you move it a large number. Going higher or lower makes it pass more or less quickly with results accordingly.
You may also have the dose set too low and you may want to set it higher increasing the amount of coffee in each dose.
Then again, since it was used, you don't know if the machine was taken apart by someone who reinstalled the machine with the dials you are using out of whack with where they should be set.
George W Conrad.
Apr 02, 2009 | Saeco Vienna Espresso Machine
Coffee dispenses extremely slow
try to change the grinder to little more coars, if it not help then i think it can be something with the printed circuit card.
Best regards
/Mirran
Sep 21, 2008 | Saeco Vienna Espresso Machine
Saeco De Luxe Coarse Grind
You could have knocked it out of its shaft or worse, Cracked the shaft itself.
Settings could be off too, It fairly common. Recheck the chamber, and make sure the plastic casing isn't cracked and the grinder doesn't wabble at all. It should be fairly firm.
If it isn't firm, bad news, cracked shaft.
May 08, 2008 | Saeco Vienna De Luxe Espresso Machine
Coarse Grind
il y a de l'eau qui passe en dessous du plateau avec du café moulu
Can't make coffee
Try to open the steam knob and make a cup of water.
Dec 30, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
488 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
