Question about 1995-1997 Chevy Tahoe Ignition Starter Alarm Switch
Keep blowing fuses under hood.
Hey, I keep blowing the 50 amp fuse that controls my radio, wipers, and power windows. this is a fuse thats located under my hood. how is the best way to search for this short?
  • 462 Answers
REMOVE THE FUSES ONE AT A TIME FOR EACH ITEM ON THE 50 AMP CIRCUIT. I WOULD START WITH THE POWER WINDOW FUSE FIRST. IT WOULD BE THE MOST LIKELY SOURCE OF A HIGH VOLTAGE DRAW. THEN GO ON TO THE WIPERS AND SO FORTH.
Posted on May 31, 2009
Looking for the fuse boxes for windshield wipers on 2011 malibu
Fuse # 14 - 25 amp. location - under hood fuse box . Plus there are two relays - WPR 1 relay # 39 WPR2 relay #40 . location - under hood fuse / relay box .
Fuse for the wiper switch 10amp fuse - located in the BCM - body control module .
Jun 09, 2017 | Cars & Trucks
Ignition fuse keeps blowing. Engine will not start. Starter will not engage to start the engine. I have a 93' Lincoln town car.
You a short to ground on the electrical circuit ! You need to find out what all is on that circuit ! Which fuse ? # fuse how many amp .
I see to fuse that supply B+ power to ignition switch , located in the under hood fuse box ! a 25 amp & a 50 amp . There are videos on youtube on short detection .
Dec 01, 2016 | Lincoln Town Car Cars & Trucks
Why does wiper fuse keep blowing?
short circuit on that wire to wiper motor.
Nov 27, 2015 | 2003 Kia Sorento
What fuse do i replace to make my windshield wipers work Chrysler 300
Highly doubt the fuse being the problem . If the fuse is blown ,that circuit has a problem , short to ground , wiper motor drawing to much amprage . Fuse's do not blow for no reason . Fuse # 18 -30 amp . under hood fuse box . There is also a relay , wiper on/off relay in same under hood fuse box . Also wiper hi/low relay ! There is also alot of electronics involved . integrated power module , front control module , plus C.A.N bus network . How to Diagnose Controller Area Network CAN . Could be wiper / washer switch , wiper motor , communication problem , module problems , Relay problem . Google chrysler intergrated power module . they have had a lot of problems with that thing .
Oct 12, 2015 | 2006 Chrysler 300
Where is the fuse for the windows on a 1992 Mazda 929 located
Fuse 14 (60 Amp - yellow) - Underhood fuse block:
Wipers & Washer, Sun Roof, Turn Signals, Air Conditioning, Radio, Cassette Player, Cigarette Lighter, Power Windows, Seat Warmer
Apr 16, 2015 | 1992 Mazda 929
Where is the fuse for the windshield wipers on a 1999 Saturn SL?
It is located on the fuse panel on the Passenger side.
Look for the removable panel that is located below the radio/center bezel on the right side (passenger side). It's not part of the center shifter console, but just forward of it. Remove the panel marked "Fuses"! You will find the Wiper Fuse in this panel along with the fuses for the Radio, Accessory Power Plug/Lighter, Power Door Lock & Window Relays, Fuel Pump Relay, Cruise Control fuse, exc......
Hope this info helps!
Jul 25, 2014 | 1999 Saturn SL
The ac. wipers signals radio ligter went off in my 1988 jeep cherokee the fuses are ok. relays too.
Lets Look at the fuses once more the # 2 threw 5 i have seen the fuse be good but it had loss contact in the fuse box, remove the fuse and install them to see if this helps
Also at the battery there is a fuse link check here to see if this has blown or loss contact,, a new one can be spliced in if needs replacemint
CIRCUIT INFORMATION
(What the fuse is for.) 1 25 Amp Rear washer / wiper - Located just right of top center in fuse bank. 2 15 Amp Radio, Cigarette lighter 3 25 Amp Heater blower motor - (* - if this keeps blowing or you only have heat on one speed check your blower motor resistor pack.) 4 20 Amp Turn signal, Back-up lights, Rear window defogger relay 5 10 Amp Dome light, Courtesy lights, Glove box light, Cargo light, Radio memory, Power mirrors, Teltak connector (For old analog "bag" cell phones, I think.) 6 15 Amp Hazard warning lights, Brake / Stop lights 7 10 Amp Parking lights, Headlight Warning Chime/Buzzer, Instrument panel light dimmer 8 7.5 Amp Gauges, Instrument cluster, Seat belt warning, Headlight delay, Chime module, Overhead console 9 5 Amp Instrument panel illumination 10 25 Amp Rear window defogger 11 30 Amp
Circuit Breaker Power door locks, Power seats, Trailer towing wiring harness 12 10 Amp ETR (Delco OEM) radio, Power antenna 13
(1984 - 1987) - - - Spare Fuse (GM automatics and manual transmissions.) 13
(1988) 7.5 Amp Transmission control unit (For AW4 automatic transmissions) 14 25 Amp Headlight delay, Horns, Security alarm 15 5.5 Amp
Circuit Breaker Front windshield wipers 16 30 Amp
Circuit Breaker Power Windows 17 10 Amp Clock, Security alarm (Ignition)
Jul 15, 2010 | 1988 Jeep Cherokee
Hey there 306 d turbo wipers wont work?
fuse will be located under the hood in a fuse box near the firewall....
Sep 09, 2009 | 1990 Peugeot 405
2002 F150 SuperCab Power Windows via 5A radio fuse. Wierd!
The location for the circuit breaker is in the fuse box under your hood number 601. Its a 30a CB.
Aug 09, 2009 | 2002 Ford F150 Regular Cab
Changed battery cable now radio will not even come on.
When you said inline fuse I get the idea that this is not the original radio. Do you have power on the inline fuse? The 50 amp fuse you checked is a bit much for a radio. There may be a smaller fuse in another fuse area of what car type you have. If you do not have power at the inline fuse find some where you do have power (12vdc) and connect to it. If you have power at the in line fuse check the ground wire. If you have a test light or someway of checking for power test all fuses everywhere. If you have a fuse location guide for this vehicle look for the fuse for radio. If it was a add on or after market radio they probably caught power from the original source That is fused under the dash.
Jan 13, 2009 | Alpine CDM-9821 CD Player
1995-1997 Chevy Tahoe Ignition Starter Alarm Switch Logo
473 people viewed this question
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Mike
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
