Question about Proview PL926WBi 19" LCD Monitor
Has lines on screen and power ligth on
It turns on but only has lines
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Do you have a picture of what the screen looks like that you can show me?
    Sergeant:
    Champion:
  • 225 Answers
Probably there's an internal hardware electronic part/s of your monitor that is cold soldered / defective. I recommend to bring the unit to an authorized service center to fix the problem. regards
Posted on May 30, 2009
Lc32le10m showing only standby ligth no ligth on the screen
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 22, 2015 | Televison & Video
When I press the power on the on ligth does not come on,and the dryer does not come on,befor when i press the power on the ligth blink for a secon and go out, and now when i press the power on nothing
The first think you need to do is check the circuit breaker. If the breaker is off, turn it all the way off and then to the on position. If it trips off again, you have a short in the wire. DO NOT plug anything into the outlet. It is a 220 line and you can be seriously injured.
Another issue could be the circuit board is faulty and the machine will prevent itself from turning on. If the breaker is good and the machine still does not remain on, you will need to call a service technician for the dryer. Good Luck!!
Dec 13, 2014 | Dryers
Sony experia mt27i hangs
download firmware&drivers fastboot& flashboot
download flashtool for xperia
In program choose unlock bootloader
last flash your firmware
(fastboot vol up+power blue ligth)
(flashboot vol down+power green ligth)
Jan 17, 2013 | Sony Mobile Phone XPERIA Sola MT27i White
My samsung RV511 laptop won't boot and the monitor keep on flashing on and off but the power indicator still ligths on
The monitor keeps flashing on and off? Or does your system keeps trying to reboot which causes the monitor to go on and off. Does the screen turn Blue before it goes off?
Apr 10, 2012 | Computers & Internet
My Toshiba power light blinks only when I try power on. The ligth blinks 5 times, 2 times and 5 times again. The batery light turn off after power on. When i connect the power cord, the power ligth is...
you should check this thread out http://www.hardwareanalysis.com/content/topic/51345/
also if you need to convert from binary to hex use this link
http://easycalculation.com/hex-converter.php
Mar 21, 2011 | Toshiba Satellite 2400-S251 Notebook
Nintendo charges but doesn't turn on and both screens are ok
whats happening when you connect to a charger? if red ligth flashes that mean you have a blown fuse , if its solid red ligth that mean had a water damage or droppend , you will need to open up and put the loose part on the sopt , usually L1 next to power switch , REgards
Dec 08, 2009 | Nintendo DS Lite Console
HP vs17X monitor blue power ligth blinking, nothing on screen
Sounds like a power surge fried the electrical connections inside.
Jul 14, 2009 | HP Pavilion dv9000z Notebook
No run, only on the front ligths (bluetooth and wifi ligths)
does your acer still underwarranty..? if yes, then return it to the store where you bought and let them fix it.. i think there's something wrong with your LCD screen...
Apr 24, 2009 | Computers & Internet
My nec vt46 does not want to turn on
You need to check the manual. It will tell you at the rear what the different lights mean.
Apr 13, 2009 | NEC VT460 Multimedia Projector
I have a Flat screen TV Proton 42'' only 1 year 1/2 old
Protron PLTV 4250- wont turn on-
Had the same problem with one here- The 110v end of the power supply board was found damaged, The following items may need to be replaced:
Fuse F1 (soldered in) . 6.5a @250v time delay
Mouser 576- 021506.3HXP – note this style is for a fuse holder instead of solder in- I added a fuse holder on the board
RT4 & RT5 inrush surge suppressors - I used shintron 8d-18 power suppressing thermistors
BD1 bridge rectifier - Mouser 627-D15 XB 60H Shindengen
If you want a little more protection modify the board as follows:
1.replace only RT5 in its original location & move RT4 into the other ac input line in front of the bridge rectifier. (cut trace & drill solder holes)
2. Add: MOV (metal oxide varistor) across ac inputs of bridge rectifier.
Maida mdc-z481-8oul or D69 ZOV 481 RA 105
This arrangment is copied from a samsung power supply.
Be careful when plugging in the I/O box on the outside cover, if any pins are inadvertantly bend loss of picture will result.
I have pics if anyone needs them .
Nov 17, 2008 | Protron PLTV-4250 42 in. LCD Television
Proview PL926WBi 19" LCD Monitor Logo
102 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
