I need to get a plug connector of a ribbon cable for tecnics hi fi model sl eh 760
SOURCE: How old is my Technics SL 1210 Mk2
Here's some information for you. Since your unit is a SL1210MK2, it may be harder to determine the age of the unit:
It is possible to tell the year (and the month) when the SL-1200 was
manufactured from the serial number on the back or bottom of the
turntable. SL-1200 serial numbers are in two different formats,
depending on the date of manufacture. It isn't exactly possible to
determine the decade in which the SL-1200 in question was manufactured,
as the serial number contains only the last digit of the year. If the
year digit is 8, the turntable may have been manufactured in 1978, 1988
or 1998. If the year digit is 0, the turntable may have been
manufactured in 1980, 1990 or 2000. One rule of thumb is that
old-format serial numbers belong to SL-1200s manufactured during the
1970s and 1980s, while new-format serial numbers belong to SL-1200s
manufactured during the 1990s and beyond.
Old-format serial number: NHOJF20765 (SL-1200 manufactured 1982)
The first digit shows the year when the SL-1200 was manufactured. These
serial numbers contain no indication of the month of manufacture. It
should be noted that serial numbers in this format contain no letters
following digits.
New-format serial number: GE4FB001154 (SL-1200 manufactured June 2004)
The first digit shows the year when the SL-1200 was manufactured, while
the month of manufacture is indicated by the letter following it.
Months are coded as letters between A and L inclusive; A indicates
January, B indicates February, and so on.
In addition to the above, all the SL-1200MK2s from the 70's and
early 80's have a 4 inch diameter plate where the RCA and ground wires
enter the chassis in the rubber base of the unit. The later models have
a smaller hole through which the wires enter the unit.
TWEAK A/V LAB
www.DJPROLAB.com
SOURCE: Technic Turntable repair
You can visit our Do-It-Yourself repair video site:
djprolab.com - for Technics Repairs
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
SOURCE: new cartridge for Technics SL -BD22D
the prestige gold might be a little bit of overkill for this turntable meaning the turntable is middle of the road and the cartridge is hi-end.
To get a closer match for your TT try a yahoo search for "AT3482P-DE" (with the quotes) and the result will be the closest match to what this turntable is designed for. also you can find your TT's owner manual here
http://www.vinylengine.com/library/technics/sl-bd22d.shtml but you will have to register to download the free manual. in that manual you will find the shape of the drawings for the cartridge is the same. both made by audio technica
