Question about Bosch SHU43C05 Stainless Steel Built-in Dishwasher
Dishwasher keeps running I have a Bosche dishwasher and the water keeps running. As long as we run it and don't stop it, the pump will continue to drain about every 3 minutes. The water just keeps running though. If we open it to empty the dishes, the cycle will stop. But the water keeps running, filling the tub, and then overflows, flooding the kitchen and drains through our wood floors to the basement below. Our ASKO seems to have a similar problem. I started the dishwasher, and the water kept filling. Opening the door didn't stop it, and eventually it was overflowing. We had to cut off the water to stop it. Any ideas?
    Problem Solver:
  • 9 Answers
Open up the door, get out the control unit. Pry open the unit's plastic case and look at the board. Burnt spot? If so, the heater circuit burnt out (happens a lot on Bosches) and the control is waiting for the water temp to rise, but of course it dosn't. Thus- long wash times.
Posted on Sep 19, 2012
  • 27 Answers
Sounds like a problem with the pressure chamber. you better have a appliance tech come out to fix it.
Posted on May 30, 2009
2 Suggested Answers
Nzero
  • 78 Answers
SOURCE: Asko dishwasher D1876
unblock your filter. unplug all hoses and electrical cords. tip unit up and clean the filter out. should stop all your problems
Posted on Sep 01, 2008
Dishwasher wont fill up with water
When you start the dishwasher you have probably noticed that it first drains water and is very important to hear that drain pump running all the time or stops after a while? Why?
If the drain pump runs constantly then the fault is in the phase of "drain water" or is activated anti-flood system. Reset point of pressostat is not reached after max. 120secs. Programme stop and can be continued after error remedy by pressing the programme key.
If the pump is running for a while and then stops, then the fault is in phase "fill up water". Switchpoint of pressostat is not reached
after max. 60 secs.
Usually built-in dishwashers has anti-flood system that responds in the event of water in the bottom of the dishwasher. Such a case, find and repair water leaks.
Dado
Aug 06, 2014 | Electrolux 23 in. ESI6104 Built-in...
Siemens Dishwasher Fault
there is a water level sensor in the bottom of the machine if this is faulty and stays on, this will indicate to the pump there is water still in the machine. I would check this sensor it might be blocked with debris and has blocked in the closed position. that woudl be the best start for this issue.
i hope this was useful.
Feb 15, 2013 | Dishwashers
Our SHE33M02UC dishwasher won't stop pumping and won't continue to the drying part of the cycle.
Hello Frank,
The reason the pump continues to run and no other function will work is because the flood leak detecter has been tripped and thusly their is water in the base frame and until time their is no more water in the base frame the pump will keep running. The things that could cause water to be in the base are;Oversuddings so suds have entered base a drain problem so to much water was in tub causing some of it to enter from vent into tuba leak in any of the components or hoses in the basea overfill so again water entered the base through the vent
In an case the service panel below the main door panel can be removed and water sopped up with rags/towels/sponges ect and when water is out the dishwasher will operate normally.....if soon it only starts pumping only the reason why water is in the base would need to be determined
Good luck,GENE
Sep 25, 2011 | Bosch Evolution 300 SHE33M02UC Built-in...
I have a ASKO D3111/8 dishwasher that will not stop pumping unless i turn it off at the power?
Hi alan gorman1,
I believe the Float Switch has been activated, do the following:
- Tilt the dishwasher back 35 Degrees.
- Keep it there until water stops running out the side (If any)
- Then tilt the dishwasher forward 35 Degrees
This should empty water trapped in the lower part of the Dishwasher, and deactivate the float switch.
Kind Regards
Jedemeyer1
* Hope this solution helped you, if it did, please rate it.
Jun 10, 2011 | Dishwashers
Bosche dishwasher serial no, SGS 456 . The machine won't admit water, but it makes all the washing sounds
Are you please able to provide the actual model no. of the bosch dishwasher. The serial no. is not much help.
The reason it may not be admitting water is because the flood switch may be triggered. This means it will not take any more water and the sound you hear is the pump running to empty the dishwasher. YOu will have to find why the flood switch is turning on. Are you using the AquaSafe circuit in the dishwasher inlet circuit? If water is leaking then this circuit will trigger and stop water from coming through inlet. But then you should also get some alarms on the display.
Please provide the model no.
Sep 30, 2010 | Bosch Dishwashers
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
What is causing the drain pump to continue running
C1 - Partially Blocked Drain - This error will occur when dishwasher was unable to pump out water in less than 95 seconds. Check drain line for debris and blockage. If clear, check for a restricted drain valve in the pump. Check the pressure sensor for correct operation as it sounds like it may be defective and thinks that the machine is still full of water after it has emptied.
Oct 30, 2009 | Dishwashers
Drain pump runs continuously. Nothing else happens!
Water had accumulated in the sump - a plastic tray at the bottom of the dishwasher which catches any leaked water. This operates a float switch which makes the drain pump run all the time. The fix was to tilt the dishwasher backwards to drain away the water. It isn't filling up again, so I'm not sure where the water came from, but I'll keep an eye on it!
May 17, 2009 | Bosch Dishwashers
I have a Bosch Exxcel Dishwasher, stuck at 1 minute to go
Make sure the drain pump is clear of any blockages and obstructions and that the drain hose wasn't kinked when you re-installed it.
Sep 04, 2017 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
943 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
