Question about Sony VAIO PCG-K35 Notebook
Upgrade memory - computer now won't turn on or boot
What do I need to do to upgrade the memory. what screw do I need to remove on my sony vaio pcg-k315b laptop I have a client who did this and now laptop no longer works, charging light comes on blinking and the green power comes on BRIEFLY and goes out, computer will not boot with old memory or new memory, anyone know what is wrong? Is there a reset for CMOS or did he fry it? Thanks, Steven
    Sergeant:
  • 157 Answers
Follow this link to do it,
http://support.vaio.sony.co.uk/tutorials/memory/memory.asp?m=2108&site=voe_en_GB_cons
Hope this helps
TC and Cheers!!!!!!!!!!!!!
Posted on May 29, 2009
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
HOW TO UPGRADE RAM ON VAIO VPCM121AX LAPTOP
Memory Upgrade for Sony VAIO VPCM121AX Netbook Laptop, the Sony VAIO VPCM121AX Netbook Laptop takes the PC2-6400 DDR2 SDRAM SODIMM 200pin memory Memory Type, and comes installed with 1GB (Removable) of Memory.
You can upgrade your Sony VAIO VPCM121AX Netbook Laptop to up to a maximum of 2GB Memory, the system has 1 Socket to install Memory, already with 1GB (Removable) standard Memory installed.
For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line
from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
Power off the computer, and unplug it from the power source. Close the computer and turn it over.
Slide off the battery cover and remove the battery.
Locate the memory bay and remove the screws in the cover.
Remove your old RAM board(s) by pushing the metal clips and holding it down and outwards until the RAM board pops up. Then pull it out at a 30-degree angle. (If you only need to add more RAM to your existing RAM and you have enough available empty RAM slots, you will not need to remove the RAM.)
5
Insert the new RAM board into an empty slot at a 30-degree angle until you hear it click. Then push it flat down into the slot.
6
Replace the cover and screw it back in.
Upgrade the Sony VAIO Hard Drive
7
Locate the hard drive bay and remove the screws from the cover. Then slide the cover off.
8
Pull the hard drive out of the bay.
9
Remove the screw securing the hard drive with the magnetic screwdriver.
10
Pull the hard drive out of the bay by the black tab connected to it.
11
Re-insert your new hard drive into the bay and replace the cover.
hope it helps
Jul 15, 2012 | HP Pavilion dv7 Keyboard (483275-001)
How do I open my sony pcv-v1
1. Ground Yourself
2. Unplug everything and press the power button for 10 sec to
discharge any residual power.
3. Place PC face down on bench with base over edge.
4. Swing PC unit forward and unscrew the case retaining screw on both
sides of the PC unit, swing unit other way and remove other two
screws.
5. Case can be loosened, pull large cover up and remove both sides.
Parts are then exposed.
6. A shiny metal box covers the memory on the left side of the PC unit. 7. Remove tape that retains it,slide and lift off from the edge facing you.
8. Memory slots are then exposed....insert and reassemble PC.
Good Luck!
May 14, 2012 | Sony VAIO PCV-RX403N PC Desktop
I need to insatll a new memory card in my sony VGC-V517G computer how do I open it up?
Sony eSupport>VAIO VGC-V517G>Manuals,
http://esupport.sony.com/US/perl/model-documents.pl?mdl=VGCV517G
On this page l would like you to left-click on - VAIO User Guide, under the Manuals heading.
A small window will pop up on the left side of the screen. It took almost 30 seconds before I saw the first page. The screen was white in the meantime.
(PDF file is downloading in the background)
In the Bookmarks to the left, scroll down to -
Upgrading and Maintaining Your VAIO Computer, and left-click on the + sign to expand the file.
Left-click on Installing Memory.
(Page 91)
Page 92 has details, and illustrations, on removing the computer back cover.
Barring something prevents you from downloading this PDF file;
1) Computer off, and unplugged from power.
2) Observe Anti-Static precautions
[Anti-Static Precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit), the hardware components inside a computer.
Computer unplugged from power, computer on a table, computer case open, TOUCH an unpainted surface of the metal frame.
This will relieve your body of Static.
Should you get up, and walk away in the middle of working on your computer, upon your return Touch the metal frame again ]
3) Disconnect any Peripheral devices connected to your computer.
Advise lay a clean towel on the table.
Gently lay the computer down on the towel, LCD screen face down.
4) Slide the back cover towards the top of the LCD screen.
It will only slide up so far, then the top of the back cover, is tilted towards the back of the computer, and lifted off.
Set the back cover aside.
5) Back of the computer towards you, the Ram Memory Cover is on the Right side.
The cover looks like a panel. It is rectangular shaped. There are two screws holding the cover on. Remove these two screws, lift the Memory Cover off.
The Ram Memory modules are right there.
Need further guidance in removing and installing ram memory modules, state in a Comment.
(Believe upper right of your page is the Comment button)
Jun 14, 2010 | Sony VAIO VGC-V517G PC Desktop
How to upgrade RAM memory what to buy and is anything else be upgraded before this
It is a very simple thing to upgrade your Ram which is a great idea since you have only 512 MB. I suggest you buy at least 1 GB or more if you can afford it. Go to the link I am posting and let them scan your computer. They will tell you exactly what you can install and the price. This is a reputable site I use all the time. This will require a download of the scanner tool which is perfectly safe. http://www.crucial.com/
Nov 05, 2009 | Sony VIAO P4 PCV-RS712 3.0GHz 512MB 200GB...
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Upgrade memory
all u need to do is that go to this website and follow the steps....
Sony’s esupport site
http://esupport.sony.com/perl/model-documents.pl?mdl=PCGZ1RA
or if this doesnt work then try this website
http://www.memorystock.com/support.htm
OR
on the bottom of the laptopThere is a panel with 2 screws in it. normally this panel will have a picture of ram on it or will denote it somehow. after the two screws are removed the panel can be removed and you will see the 2 SODIMM slots one will be occupied and you can place your module in the second one.
good luck...
Jan 26, 2009 | Sony VAIO PCG-K35 Notebook
SONY VAIO PCV V1G
Model:PCV-V1/G
Unplug everthing and place PC face down on bench with base over edge. Earth yourself.
Swing pc unit forward and unscrew the case retaining screw on both sides of the pc unit, swing unit other way and remove other two screws. Case can be loosened, pull large cover up and remove both sides. Parts are then exposed. A shiny metal box covers the memory on the left side of the PC unit. Remove tape that retains it,slide and lift off from the edge facing you.
Ten minutes tops....good luck, much better performance.
Apr 03, 2008 | Sony VAIO PCV-V100G (PCVV100GKIT1) PC...
Sony VAIO PCG-K35 Notebook Logo
186 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
