Question about Ryobi Garden
Blower won't start i empty the fuel and put in fresh fuel what else needs to be check or cleaned
  • KEN LaPOINT
    KEN LaPOINT May 11, 2010
    pull the spark plug and clean it off with spray carb cleaner.
    pull the motor thru with the plug out...
    Reinstall the plug,
    if the unit has a primer bulb, be sure to clean the fuel out of that as well.
    Clean the air cleaner element... a dirty air cleaner will cause the engine to **** too much fuel as well.
    Let me know if these help your start..
    k
  • 15 Answers
As Smart suggested, and add in:
Checking your muffler exhaust port screen. They give TONS of trouble on a 2-Stroke.
(Simple: Pull your muffler, you should see the screen in the muffler. They usually get fouled BADLY over time, and provide such high back pressure, she won't start/run. In some, you pull the muffler, and then pull the screen from insided the muffler, held in place. That's part of the fun of 2-stroke work, you never know!)
Posted on May 29, 2009
My weed eater lower start reasonably well, but shuts down after running less than a minute
SOUNDS LIKE YOUR MAGNETO IS BAD,, TO FIND IT JUST FOLLOW THE SPARK PLUG WIRE THERE IT IS,, HOPE THIS HELP
Oct 17, 2013 | Weedeater 25cc Gas Blower ()
Won stay running
Check carburetor & air filter. Clean off all dirt and clean air filter. check age of gas. Cannot be more than 30 days old. Make sure to use fresh gas w/synthetic 2-cycle oil @ 40:1 ratio (1 gal.) Gas to 3.2 oz. Oil). Do not use old or stale oil/gas mixture. Before putting in fresh fuel, press the primer several times. A small amount of gas might show up in the fuel tank. Remove fuel. With carburetor cleaner, spray carburetor. Put in small amount of fresh fuel. Just enough to cover the fuel filter. Then press primer with fuel cap off, and watch to see if fuel is flowing smoothly. If not or if plastic primer bubble does not come back to original shape after pressing, then you have to take carburetor apart and clean or get new carburetor.
Sep 05, 2013 | Weedeater Gas Blower
Tries to start for a few seconds then dies
Aug 16, 2013 | Craftsman Garden
It won't start.
Give the machine a proper service and clean out the carbs. Petrol goes off and a part of it evaporates leaving a nasty sludge behind. This will cause bits to block the jets. It is also worth emptying the fuel tank and flushing it out with a little bit of fresh fuel. Then refill with fresh fuel.
May 10, 2013 | Motorcycles
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 | Garden
My echo packpack blower won't start
How long has it been since its been started? If its been a while go to Home Depot and get some fuel stabilizer follow the instructions - if it hasn't been to long go to home depot and get a new spark plug and replace the old one as well as clean the filter -make sure to put fresh oil/gas ratio in the tank - use stabilizer if needed
Oct 25, 2012 | Echo 50.8cc Backpack Blower
Primer bulb on Yardboss blower will not **** fuel from tank. Blower will run if primed manually.
remove your carb and clean it and replace diaphram's and needle , they tend to swell up from ethanol that is used in the gas now a days, and the diaphrams turn stiff and won't pump fuel. then put fresh gas in when you are done and also replace fuel lines and filter too., probably primer to because once it is hit with carb clean it just crumbles, good luck
Jul 31, 2011 | Homelite Consumer Products MightyLite...
Kawasaki KRB750 B: Won't start. Have spark,
Check your off/on switch you can test it with an ohm meter to see if you are getting a open curcuit
Mar 12, 2010 | kawasaki Krb750b Backpack Leaf Blower
I can't start my craftsman leaf blower 8 months. what could be wrong.
empty the gas out, put in fresh mix , clean the plug or replace it , clean the air filter. and if it still doesnt start use some starting fluid in the intake. then let me know if it starts
Mar 20, 2009 | Craftsman Garden
Wont start
Start with emptying the gas tank totally. Refill with fresh gas/oil mix. Todays gasoline ain't that great.
Also after putting in fresh gas and priming if it doesn't fire at all pull the spark plug and if it is dry, pour a about a tbsp. of mix gas in the plug hole. put the spark plug back in and see if it will fire.
Phil
Dec 07, 2008 | Garden
Garden Logo
135 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
