Squeaks when drum rotates; both ways
SOURCE: Fisher Paykel dryer
buzzing sound generally come from the motor assy, not necessarily a bad motor however. try opening the front door and along the inside of the top of opening is 2 phillips screws the top will tip back and then removing 2 5/16 screws from inside the font panel will remove giving you access to the motor blower assy.. it is possible that something( baby sock, small undergarment) has fallen inti the blower preventing free spin also resulting in a buzzing noise, if so simply remove debris and reassemble.
SOURCE: fisher and paykel dryer
The Fisher and Paykel people suggest a reset.
The safest way is from your fuse box.
If this doesn't fix your problem, let me know. I've got a contact now.
Hope this helps
Mike
hi
is the filter clean and is there air coming out of dryer if all tis is ok it could be heating element or timer
cheers grant
SOURCE: Fisher & Paykel GWL11US washer
Hi The issue is with the clutch assembly that is bad and should
be replaced, you can try lubrication though with the washer. The squeal that
you hear from the dryer is with a worn out/bad belt that should be replaced. Hope
this helps...please post back for further assistance. Daniel
SOURCE: Repairing & refitting a new Dryer Timer for Fisher & Paykel AD53-K
Without a schematic or service manual it would be a guessing game at best. I would go onto the internet and just enter "need service manual for [make, model,etc] and you should be able to find a free download of the service manual from several sources. One of them will more than likely have the information you need on it. I wouldn't try guessing you can find it on the internet somewhere. Most of the time you can download an entire service manual and print it out for free.
Gillight
