Question about Water Pik Gas Valve, Esc Nat.250,325,400 R0099400
My lp gas pool heater has in line valve that is stuck in off position is this a safety feature ive tried pushing pulling ect im somewhat mechnicly inclined but know nothing about gas ,pool he
My on/off gas line vavle is stuck in off position can not turn it back to on for pool heater lp gas
  • 323 Answers
Get a can of penetrating oil and spray the valve, pipe all around, everything. Let it set awhile and do it again. Use a big pipe wrench, with a pipe on the end of the handle if you need it to give you the leverage and it will definitely open.
Posted on May 29, 2009
250 lp heater stops and starts
standing pilot heater or electronic ignition???? could be a result of many diff things......gas valve coils could be shorting out....an electrical short somewhere.....safety is opening/closing
Nov 25, 2013 | Pentair Pool & Spa
Thermocouple
Is the gas line primed? could be just air coming out?
Otherwise, your gas valve is failing?
Oct 16, 2013 | Blue Rhino LP Gas Outdoor Fire Pit with...
Can Mini max ch 250 M be converted to LP
not advisable safety orfices nad gas valve and regulator to be changed then mark unit propane
Jun 15, 2012 | Pentair Minimax Ch 250,000 Btu Natural Gas...
The valve on my Thermoheat heater RMC FA50 will turn from the off position therefore I can not light or start the heater. It is stuck in the off position.
I'm assuming this is a gas heater valve? Typically, one must slightly depress the valve in order to turn it to pilot or on--a safety feature of nearly all gas appliances...
Jan 19, 2011 | Heating & Cooling
We have a laars lite 2 pool heater , the pilot is lit but the unit will not fire up
With these pool heaters, there are a couple of things that you can try before you call a pro. First, make sure that your gas valve knob is turned to the on position. Secondly, you could have air in your gas line. Cycle the ignition sequence until all air is out of the line. It could also be that your gas valve is malfunctioning and needs to be replaced.
May 20, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Laars Lite 2 Coversion to LP Gas
Hi you will need a gas fitter to do this and set it up
Jun 02, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
My baby q is sick
Since 1995 all regulators (the part that attaches to the gas tank to regulate the flow of gas) have included a safety device that restricts the flow of gas in the event of a gas leak. This safety device can be inadvertently activated in two ways, putting the grill into what is commonly called “bypass”. The first way for the device to be activated is to leave one or more burner control knobs in the “ON” position when the LP cylinder valve is opened. The second is not to wait long enough to “start” the grill after opening the LP cylinder valve. The safety device in the regulator is activated each time that the LP cylinder valve is opened. The device resets itself when the gas pressure equalizes between the closed burner control valve and the regulator, through the hose. If a burner control knob is turned on before the gas pressure can equalize, the device will remain in “bypass”. The length of time necessary to wait to “start” the grill after turning on the LP cylinder valve is dependent on the length of the hose and outside air temperature. It is always good practice to wait a few seconds after opening the LP cylinder valve before turning on the burner control knob to start the grill.
Keep in mind that the safety device reacts to a gas leak. If a grill is in bypass, the gas connections and hose should be tested for leaks with a soap and water solution.
If the grill is in bypass, after checking for gas leaks do the following to get the grill out of bypass:
To reset the gas safety device:
Open the barbecue lid.
1. Close the LP tank valve.
2. Turn your burner control knob to the OFF position.
3. Wait at least 5 minutes if the barbecue had been lit, then
4. Disconnect the hose from the LP tank.
5. Turn your burner control knob to the HIGH position.
6. Wait at least 2 minutes, and then turn the burner control knob to the OFF position.
7. Re-connect the hose to the LP tank.
Re-lighting the barbecue:
1. Open the barbecue lid.
2. SLOWLY open the LP tank valve all the way and wait 1 minute.
3. With the lid open, turn the burner control knob to the HIGH position.
4. Ignite the grill by pushing the crossover ignition button.
5. Close the barbecue lid.
6. The barbecue should reach 500 to 550 degrees in 10-15 minutes.
When you are done grilling:
1. Turn all burner control knobs to the OFF position
2. Turn off the LP tank valve last.
* Always follow the re-lighting instructions whenever you use the adapter hose and larger tank.
Feb 16, 2008 | Weber Q Grill
Pro com ql300tyla propane heater
There is a safety built into the gas valve that will not allow you to turn the know to the "ON" setting until after 3 minutes of cooling. Sounds like it is stuck not allowing you to turn it on even after more than that. Other than a solid rap on the gas valve to see if it pops back, you will need to replace the gas valve. Even if you get it to reset, you may be facing this again so replace the valve. Make sure you get a valve designed for the correct gas (L.P. or Natural Gas) because the gas valve is not convertable.
Dec 04, 2007 | Procom QL300TYLA Heater
Water Pik Gas Valve, Esc Nat.250,325,400 R0099400 Logo
260 people viewed this question
Top Water Pik Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Water Pik Pool and Spa Expert? Answer questions, earn points and help others
