Question about Homelite 'Yard Broom' Leaf Blower
Just bought a used leaf blower, homelite, gas leaks out of the gas tank, where the gas tube fits into it.
I bought a used homelite "yard broom" gas leaf blower/vac. The first time i used it, I notice that on top of the gas tank where the gas tube fits into the tank, that it does not seal and gas leaks out. The gas tank sits at an angle when the machine is set down and the gas leaks out. How do I solve that problem
  • 1 more comment
  • stfitch May 29, 2009
    I know the difference between the gas cap and the gas line. the leak is where the gas line goes into the tank, not at the gas cap.
  • Harold Brown
    Harold Brown Nov 12, 2013
    The hose needs replacing there are no seals only the diameter of the hose seals it.
  • Anonymous Mar 20, 2014
    The gas cap on this BL30 repeatedly leaks gasoline. The cap goes tight then releases. Even when tight leaks fluid. it is either the cap or the tank
    President:
  • 1,489 Answers
"top of the gas tank where the gas tube fits into the tank"
I assume you're describing the gas tank cap. if so, the o-ring is missing from the gas tank cap. You can find those at hardware stores.
Posted on May 29, 2009
  • Samuel Charles Spriggs May 29, 2009
    I'm sorry I insulted you -- just trying to help.
    When you wrote the top of the tank, I couldn''t visualize the fuel line going into the top -- oh, well.
Homelite yard broom II fuel tank removal
look up the unit on the Homelite web site, download the manual, it explains all the steps.
Apr 28, 2014 | Homelite 'Yard Broom' Leaf Blower
Are all homelite yard brooms gas n oil mix?
All teh ones i ever seen were two cycle engines which takes mixed gas........Hope this helps.
May 20, 2011 | Homelite 'Yard Broom' Leaf Blower
I have a Homelite YARD BROOM II 170 mph Blower.what is the oil to gas ratio?
I usually mix at 50:1 useing klotz two stroke oil,or 44:1,klotz is high performance zynthetic oil,also has nice sweet smell when running,keeps the neighbors from complaints on bad smell.
Feb 11, 2011 | Homelite 'Yard Broom' Leaf Blower
Need to know the oil and gas mixture for a homelite yard broom II
The manual probably says 40:1 (3.2oz.oil to 1 gal gas) but if you use a good modern 2 cycle oil,50:1(2.6oz .oil to 1 gal gas) will suffice.
Jan 31, 2011 | Homelite 'Yard Broom' Leaf Blower
What fuel does the homelite yard broom 2 take
depends if its 2 or 4 stroke if its 4 stroke the just regular gas if its two stroke then mixed gas and the ratio is 32:1
Jan 20, 2011 | Homelite 'Yard Broom' Leaf Blower
Yard broom leaf blower will not stay running I
It seems that the carb is not getting fuel. It could be a cracked fuel line. The fuel priming bulb could also be cracked/dry rotted. Possibly the fuel pump in the carb is bad. The carb is rather intricate and not something anyone without training should try to repair. The overhaul kit will cost $15 to $20. I suggest you take the blower to a repair shop.
Apr 19, 2010 | Homelite 'Yard Broom' Leaf Blower
I have borrowed a small Homelite leaf blower with
If you go about 32:1 you will be OK. It may be a 40:1 unit, but better safe than sorry if you are not certain.
Mar 07, 2010 | Homelite 'Yard Broom' Leaf Blower
Gas/oil ratio for a Homlite UT 08026H blower?
I USE SOME STUFF CALLED OPTI THAT WAY YOU ONE CAN FOR ALL YOUR 2 CYL STUFF ITS GOOD STUFF
Sep 29, 2009 | Homelite 'Yard Broom' Leaf Blower
Mine leaks from the gas tank,
go to partstree.com you might can fine one there.let me know.ok
Jul 20, 2009 | Homelite 'Yard Broom' Leaf Blower
Husqvarna 145 bt gas leak
the fuel line is cheaper to replace than the tank the most common problem with weed trimmers & blowers is the fuel lines will rot & leak if there is a small hole in the line on top of the tank it will poor out if i can futher help e-mail me @ wadembly@aol.com thanks , wade
Jun 08, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite 'Yard Broom' Leaf Blower Logo
1,151 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
