Question about LG WM-2277HW Front Load Washer
Lg washer bleach dispenser leaks onto the front of washer down to the floor
  • 2 more comments
  • jbluscombe Nov 03, 2007
    bleach runs out the front an the floor
  • Anonymous Nov 07, 2007
    I have the same problem. It looks like the dispenser is leaking out of the back--maybe a hairline crack. Is it possible to replace the dispenser?
  • mhaymore Jan 01, 2008
    I have the same problem with my LG. I have found that if I let the entire dispenser drawer dry out completely (remove drawer from unit and air dry) that the bleach dispenser works perfectly. My theory is that once water is in the siphon tube it mixes with the bleach you're adding and starts the siphon (dispensing) process prematurely. I consider this a design flaw.
  • Donnie Gilbert
    Donnie Gilbert Feb 11, 2012
    I had this problem and checked for build-up on the dispensers as recommended by LG, but no build-up. I believe the problem is casued by the front of the dispenser drawer tipping down when extended to add bleach. I stopped this by holding it level as I added bleach and pushed the drawer back into place. So you need to add detergent first then lift the front of drawer to level it then add bleach. When the drawer is extended and tips down the bleach drains from it's compartment and should run into the machine but since the drawer is tipped the bleach runs out the back and dribbles to the front of the drawer. It is a problem with their design there should be a rubber flap or something to assure this does not occur.
  • 156 Answers
Make sure your machine is lavel and just a little higher in the front about 1/16 in and do not fill all the way to line just under line
Posted on Feb 25, 2008
DO NOT overfill the bleach dispenser. The first time it happened to me, I knew I had put a little too much bleach in. When I turned the machine on, it ran out and down the front of the machine into a puddle on the floor. I did it once again, and the same thing happened. Now that I'm aware of it, it hasn't happened since.
Posted on Jun 14, 2008
SOURCE:
I have LG wm-2277HW Front Load Washer, when I pour bleach into the bleach dispenser I see it disappearing as fast as I pour it in,and I see it coming out the front bottom the washer (the same side) where...
Remove the screws on the back of the top and lift the top off. Pour water into the bleach dispenser and watch to see where the leak is coming from. Post back your findings.
Dec 07, 2012 | LG WM-2277HW Front Load Washer
My new LG washer always has water in the soap dispenser, bleach dispenser, and fabric softener dispenser after the cycle has finished. Is this normal?
Mine too!! Very annoying, especially since the water then drains down onto to floor and has actually made the door hinges stiff! I just use powdered bleach now.
Aug 22, 2010 | LG Washing Machines
Bleach leaking out bottom of washer.
Not sure what model yu have since there is none posted but sounds like the hose from the bleach reservoir has come loose.
Eric
Sep 15, 2009 | Kenmore Washing Machines
Bleach remains in bleach dispenser after washing and even after extra rinse cycle
I put the bleach in with the load right on top of the whites, so I dont have bleach left in the dispenser for the next load. Seems to work okay.
Jun 02, 2009 | LG WM-2277HW Front Load Washer
Over-filled bleach dispenser
hi ..well theres no electrical parts under bleach dispencer,,your problem lies somewhere else..the most 3 cups will do is bleach your floor...now first try and change outlet...if you need to you can remove three screws on top rear,,unplug first..and do a little blow drying ...also check for any burnt or grounded connection,,
Jan 04, 2009 | LG WM-2277HW Front Load Washer
Bleach leaking on floor
hiya was a bit puzzled at this one ? but will try to help not certain re your machine about bleach in dispensor but consulted the wife about bleach in our machine and no where in the manual does it mention use of bleach only softeners ? however you mention dispensor does not dispense ? try this? remove/pull out drawer and clean out the machine where drawer fits of any residue powder alsi the softener dispensor remove from drawer and ensure the cap is good fit on the dispensor tube ? if loose? then the dispensor will not work as it is emptied of softener//bleach by syphon effect ie as like toilet flush? as water enters rises to tor of tube then the fluid in compartment is syphoned along with water that is entering on rinse? cycle so if no syphon? water will o/flow/fill the drawer on l/h side and may o/flow leak from drawer ?? hope this helps? and you understand the syphon effect for using softeners ? ps i may be mistaken about use of bleach but prior apologies if iam wrong
Oct 20, 2008 | LG WM-2277HW Front Load Washer
Bleach not always being emptied, bleach marks on clothes, bleach sometimes runs right out when you fill it.
The dispenser works on a siphon principal. If you over fill the cup it will start the siphon and empty before it should. If that's happening you're using way too much. You only need about a tablespoon of soap, softner and bleach for a full load.
Aug 11, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG washer leaking problem
You may be using too much detergent.  Use only 2 tablespoons of detergent in your wash.  Using too much will oversud the machine causing the suds to go out the back vent and on to the floor giving the sense of a leak.
On the dispenser, make sure that the containers are clean and free of any debris.
Jul 16, 2008 | LG WM1814CW Front Load Washer
Lg wm1812cw front load washer
We had the same problem- for us it was because we were mixing laundry booster (Oxyclean) with liquid soap in the dispenser. It seems the water running through the tray had insufficient pressure to properly flush the tray out, so residue accumulated on the back & underside of the tray. Our water pressure is good here, and we don't use a water softener or filters that can reduce the pressure. Unfortunately it seems to just be a bad design of the soap dispenser tray.
We also had a problem with water/bleach leaking from our soap dispenser- when we used the bleach compartment in the dispenser we got leaks dripping onto the floor from behind the front cover of the washing machine. It was running down the front of the washer behind the front cover & coming out onto the floor. The repair guy said this was because the dispenser tray was pulled out too far, but the reason we were pulling the soap tray out so far was because the bleach compartment was too far back in the tray to use if we didn't. Now we just leave the drawer partially closed & pour the bleach directly into the soap compartment along with the soap.
Jan 16, 2008 | LG WM1814CW Front Load Washer
LG WM-2277HW Front Load Washer Logo
749 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
