Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
System not flushing and motor cut out.
Have model 003. System started repeatedly grinding - or trying to grind about 10 times before finally stopping. Motor sounded like it was struggling. Now it's just stopped completely and it's not flushing at all. Electric is ok.
    President:
  • 3,433 Answers
Motor may have been jammed and notw burned out.
Posted on Jun 01, 2009
Cub cadet rzt 50 making grinding noise when starting after it starts still making noise sounds like coming from fly wheel. any suggestions thanks
The shaft that the solenoid pushes the gear up needs lubrication. If it's been grinding too long, the bearing in the starter is worn letting the armature to rub on the field frame. Might be time for a starter motor.
Oct 02, 2016 | Cub Cadet Garden
My Ryobi 10" chop saw was stopping mid-cut. Why is it making an awful noise now?
The nut that holds the blade on May gave come loose. Or motor is shot
May 02, 2015 | Saws
Machine grinds and grinds but never brews
Want serial number and activation code of mavis beacon deluxe 17
Dec 09, 2013 | Saeco Vienna De Luxe Espresso Machine
Run and stop
if it has a briggs and Stratton motor the problem they suffered most was stretching valve stems which reduced the tappet clearance when hot to a point where the valves were held open. If ohv unit reset the tappet clearance about .003" bigger and the problem should be fixed. If a side valve you will have to remove the head and valves and grind the end of the stems a fraction
Jun 15, 2013 | Mtd Drive Belt 42"
I purchased a GE Coffee Grinder Model number 111338 54, but there wasn't an owner's manual with it, and the first time we plugged it in it doesn't work. We just wanted to make sure we were operating...
I'm on my second grinder of this model.......... in the past 2 months. The first stopped working so I just took it back and replaced it. The second time it quit working I removed the cup with the grinded coffee and noticed smoke wafting up from the unit. Both times it quick working I was grinding 12 cups of beans (12 cups of brewed coffee, not 12 cups of actual beans). The unit shouldn't have a setting to grind that much coffee if it burns the motor out, which is what happened.
Oct 30, 2010 | Coffee Makers & Espresso Machines
Jura E8 beans will not pass through grinder resulting in "Fill Beans" error message. Saw reference to Kaffeestudio.com for dissasembly instructions but that link no longer works. I assume that the chute...
It seems withthis model you have a 1 year or 4000 cups warranty with this.
If you are within this, then give them a call - here is the Manual if you don't have it -
MANUAL -
I suggest you start by removing the beans in the hopper and wiping around to remove oils.
Then refill with fresh dry beans.
Plug in and set up as normal
Set to brew a standard large cup - and adjust grinder to coarse setting while grinding.
Do not adjust with grinder quiet - it must be done while rotating.
Make at least 10 cups this way at the coarse setting.
I think what has happened is that damp beans (frozen or cold) have entered the unit and caused the coffee to gum up at the top of the burr.
This will just push fresh beans out of the way instead of starting to grind them.
If you use dry (light loast) beans, it doesn't seem to happen as much.
Just ake sure you refrigerate most of your stocks, but keep a small stock at room temperature in an airtight tin to prevent this kind of thing.
You can actually push down on the bean stack slightly with a wooden object while the grinder is running if nothing moves on the coarse setting to get things moving.
Feb 10, 2010 | Microwave Ovens
Cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind & Brew not using all the water in the reservoir
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
Jan 10, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
488 people viewed this question
Top Saniflo Home Experts
Paul Carew
Donni Steen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
