Question about Samsung CLP-510 Laser Printer
Samsung CLP-510 not printing?
My samsung CLP-510 seems to operate fine, but when I print nothing is printed to the paper.  Toner is near full.  Any ideas?
  • Anonymous Jul 11, 2008
  • 161 Answers
Most probably you are using an USB cable that is either too thin (cheap cable) or too long (beyond 6ft.).
Posted on Nov 02, 2007
SOURCE:
My Samsung clp 510 printer won't print in color. How can I fix it??? I just installed a new black ink toner cartridge and now it's not letting me print in color. About a month ago I replaced the color...
I had a similar issue with my 510. My printer would only print in b&w regardless of my settings in the printer setup. I uninstalled my printer driver and reinstalled a fresh one from disk. This cleared up my issue.
Mar 26, 2010 | Samsung CLP-510 Laser Printer
The red light has come on - mid-way through printing, and nothing I do seems to rectify the problem. It won't print. Just got the blue and red lights on all the time
Many things can cause that, toner box full, fuser not heating, paper empty, toner empty, paper scraps inside, imaging belt used up, If the owners manual doesn't help you locate the problem you may need a shop. Samsung customer support can help too, you'll find their number on line.
Jan 25, 2010 | Samsung CLP-315W Laser Color Printer
"invalid toner cartridge" message remains
Try this
Turn the printer off hold down the menu button turn the printer back on while continuing to hold down the the menu, when you get a green light your ready to print
Feb 18, 2009 | Samsung CLP-510 Laser Printer
Samsung clp-510 blotchy print-out
Some types of paper can contaminate the image drum, suggest you clean it.
Dec 01, 2008 | Samsung CLP-510 Laser Printer
Noisy operation and black marks on left side of printed paper
vacuum out the waste toner passages that lead from the drum and transfer belt to the waste toner container. Toner is building up inside the transfer belt and/or drum and has no place to go except onto your paper.
Nov 06, 2008 | Samsung CLP-510 Laser Printer
Samsung clp-510n
there are ways to reset the counters on the toner so that you can continue to print.
See:
http://www.dunfield.com/clp510/
Oct 28, 2008 | Samsung CLP-510 Laser Printer
Samsung clp-510
may be the drum of your laser cartridge must be end of its life orwaste toner collection unit must be full.
Aug 07, 2008 | Samsung CLP-510 Laser Printer
Ink issues Samsung CLP-510
Some paper tints can cause problems with color images, so make sure that you're using plain white paper, not another color such as beige, yellow, or blue. Even an off-white shade can affect your colors.
In addition, paper type can slightly influence your ink color. Highly absorbent papers can draw in the ink so quickly that the printed image may seem dull or a little washed out. If this is the case, try a coated paper that is specifically intended for color printing. If you're printing those important family vacation photos, use a good-quality glossy paper.
If your colors are way off, you may be running out of one or more ink colors. For example, blue and yellow are mixed to make green, so if your grass seems blue rather than green, you may be running out of yellow. Check your ink cartridges and replace any that are low or exhausted.
Thank you, & post back if you still need assistance.
May 07, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Toner Bleed
The following can cause bands (vertical on a normal page)
Faulty Toner cartridge
Faulty Drum Unit
Faulty Transfer Belt
Contaminated Fuser
Damaged or dirty LSU glass
Jan 09, 2008 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Print Quality problem
Faulty Drum Unit
Contaminated Fuser
I've also seen this sort of thing caused by a crusty build-up of toner on a wiiper blade on the Transfer Belt, and or Drum.
Dec 01, 2007 | Samsung CLP-510 Laser Printer
Samsung CLP-510 Laser Printer Logo
226 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
Steve Allison
Steve Allison
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
