Question about Whirlpool Dryers
Dryer cycles hi i have the whirlpool frontloader dryer and i can not use the controls for heavy duty normarl etc. i have to use the timed cycle. any suggestions
  • 6,784 Answers
  • HI, this specific sector of the timer you speak of has been damaged. you will need to replaced the timer/control module in this case. the replacement of the timer/control module will fix this issue.
Posted on May 29, 2009
Whirlpool duet dryer model number gga9200lw2 says control lock how to fix problem
follow this steps and fix it. God bless you
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Oct 05, 2012 | Washing Machines
Dryer won't dry clothes
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
Admiral heavy duty super capacity 5 cycle 3 temperature only heats some time
susara awz 7457 ne greje koji sum moguci kvarovi jel moye iko da mi pomogne..unapred hvala
Nov 28, 2011 | Whirlpool LER5636P Electric Dryer
Whirlpool estate electric dryer takes three full cycles to dry. Not sure if it is the heating element or the thermal fuse? This dryer is a 1/3 HP motor large capacity, heavy duty dryer.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 19, 2011 | Whirlpool Dryers
The beep that signals load is done sounds prematurely for about a minute ,the dryer continues until load is dry then shuts off
On this dryer each of the seven automatic cycles listed on your machine perform different functions based on fabrics, load size or variables. In essence the first four settings (Heavy Duty to Delicate) relate to your desired drying temperatures of high, medium, low or extra-low respectively. The moisture level of the load is determined by the dryer's sensor system and the machine will set the drying time to an optimal level.
Whirlpool added a WRINKLE FREE feature or what one might describe as an extended intermittent tumbling time. This added cycle helps reduce wrinkling when you may not be able to unload the dryer immediately after the end of the cycle when the buzzer goes off. Starting this setting is a simple one button operation at the control panel. TheWrinkle Shield™ Plus Feature is preset to on during the permanent press cycle.
Jan 30, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool GGW9250PW Automatic Cycle not working
We are sorry to hear of the problem with your Whirlpool dryer. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your refrigerator.
Apr 04, 2017 | Whirlpool GGW9250PL Gas Dryer
Dryer knob does not control times or cycles
i can be either the timer , control board or check to see if there is a wire brush runing on the drum this is a sensor and if it is worn down it give funny readings
Jul 29, 2009 | Whirlpool LAB2700ML Pedestal Drawer for...
Heavy duty cycle no heat
IF there is heat on every other cycle you have a bad timer. Replace the timer and that should fix ya up.
Nov 16, 2008 | Whirlpool LER5636P Electric Dryer
Dryers Logo
47 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
