Question about KitchenAid KESC300 Electric Kitchen Range
KERC600GWH1 glass control panel is cracked.
Glass control panel on my Kitchenaid KERC600GWH1 range cracked - how easily are they replaced? Can I do it myself?
  • 196 Answers
Replacing the Ceramic top is not difficult. Just remember to be careful. There should be 2-to-5 screws holding the top to the front support. Removing these screws will allow the top to be tilted up and back. Depending on the style you may have to remove the burner plates from the top. Remember to disconnect the power before attempting any repair
Posted on Dec 30, 2007
The stovetop glass has cracked on my KESH307 Superba Electric Range. How do I replace this?
The price to replace is very high that is the problem with having a bunch of new age products there is no cheap way out ect ford motor part vs a Kia part f
Sep 25, 2012 | KitchenAid KESC307 Electric Kitchen Range
How do i remove the glass top to replace a burner?? it is to a kitchenaid electric range suberba, model KESC307HBS0. Thanks!! this parts breakdown gives you an idea of what pieces you need to remove to get to the burners. Start off by removed the trim pieces (careful they scratch easily). Then you should be able to raise remove the glass top - careful that you secure it somewhere that it doesn't fall over and break.
Jul 02, 2011 | KitchenAid KESC307 Electric Kitchen Range
Model:KERI500. The glass in oven door has cracked and pieces of glass has fallen out in the oven. What in the heck is going on?? Purchased on 1999 and have loved the range, but this is shocking.
Every now and then I have seen glass breaking on oven doors and cooktops. Unfortunately this just happens sometimes. You will have to get a replacement glass from the manufacturer or go to a glass specialist and buy a piece of tempered glass.
Feb 11, 2011 | KitchenAid Kitchen Ranges
Cracked inner oven glass window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
Jan 16, 2011 | KitchenAid Ovens
Interior door glass cracked on my KitchenAid oven
thers the inner most glass then some inner glass packs then the outer determine waht u need take ur model and go to go to there parts direct or parts research link lookup ur model find the part number and a normal price ........anyways u are gonna have to take the door off and replace it, kinda hard to describr just have to get acesss inside and replace the glass... might need service might be cheaper if u have a local repair shop for u to take the door off and bring it in to them... to get that dooor off most have lil flappers or metal locks open the door fully inspect down by the hinge pulll those flappers back towards glass then move door to brooil position 3/4 way closed and lift striaght up... hope this helps reply or rate me if posible k thanks
Jan 27, 2010 | KitchenAid KGST307 Gas Kitchen Range
Kitchenaide gas range inner door part number 9781721 is cracked.
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Here the part Inner Door Glass
Mar 24, 2009 | KitchenAid KGST307 Gas Kitchen Range
GE oven - cracked inside window
solved. replacement glass was about $50 and repair time was a few screws and 20 minutes.
Jan 05, 2009 | KitchenAid KGRT607 Gas Kitchen Range
Broken inside glass door on my electric KitcherAid glass top range
sounds like you may have thermal breakage. does your oven have the self-clean option? you can have the glass replaced easily. i wouldn't use the self-clean option for now.
Aug 02, 2008 | KitchenAid KGST307 Gas Kitchen Range
Broken inner glass on kitchaid range how to remove the door
screws near the hinge, make sure to get oven/tempered glass sometimes the screws are located in the crack between the oven and door on the bottom
Jun 12, 2008 | KitchenAid KGST307 Gas Kitchen Range
Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
KitchenAid KESC300 Electric Kitchen Range Logo
357 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
