Question about Dell Inspiron 1526 Notebook
WATER DAMAGE DELL 1526 HOW TO DISASSEMBLE TO DRY
I spilled water on my Dell I1526 notebook. Can you tell me how to disassemble it to dry? Thanks.
  • Dell Master
  • 13,433 Answers
Hey
heres the service manual for that unit.
http://support.dell.com/support/edocs/systems/ins1525/en/SM/index.htm
I think you will find all the instructions you need inside of it.
thanks,
Ekse
Posted on May 29, 2009
Acer laptop doesn't power up after water spill
As I'm sure you are now aware , electronics and water do not mix. That said, Remove ALL power IMMEDIATELY if you get water in /on a laptop. If the power is removed , battery, AC, you can try and dry out the spill, otherwise the damage is done. How much damage I can't say, only a qualified computer tech can ascertain that.
Nov 22, 2012 | Acer Aspire 3502WLCi Notebook
My inspiron mini 1018 notebook's keyboard is not working properly. The left shift key appears to be stuck and I really having a hard time using the whole keyboard. I remember having spilled a few drops...
When water spills into a notebook, you should fully disassemble the notebook & thoroughly inspect its inside. Look for any traces of liquid on the circuit boards & on other components. On circuit boards, liquid damage appears in the form of whitish traces. These needs to be wiped off. This can be done using a tooth brush moistened with few drops of hand sanitizer liquid.
Check all internal connectors & make sure that no liquid seeped into them. Dry them if needed.
When you are done, re-assemble back the notebook.
If the liquid fell on the keyboard & you found out that the keyboard is no longer working, then you might have to replace the keyboard.
May 23, 2011 | Dell Inspiron Mini 1012 Netbook...
Spilled a little coffee on macbook--not even a 1/ 4 cup, dried off immediately-- on keyboard, then took battery out and back in and two keys not working so took battery out rinsed around those keys very...
After liquid spill the laptop has to be disassemble and the motherboard inspected for liquid damage. In some cases cleaning the motherboard might fix the laptop.
Check out this guide for troubleshooting Mac laptop liquid spills.
Nov 15, 2010 | Apple MacBook Housing, Top Case with...
Spilled coffee on D600 notebook, power supply turns off when plugged in after had the notebook cleaned. is my notebook not fixable?
When the power supply turns off when plugged into the laptop it is indicating that there is a short. Remove your battery and try connecting the power adapter again. If the problem persists your motherboard will most likely need to be replaced.
There are companies out there that will repair motherboards however if the laptop was on when the spill occurred there is little to know chance that the motherboard is repairable.
Mar 16, 2010 | Dell Latitude D600 Notebook
Inspiron 1525 laptop keyboard stuck
if you think thats the cause of the problem.... then you should clean it before it will cause more damage.
clean it with water and let it dry.
Feb 15, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
Water spilled into my laptop Dell Latitude D600. what do i do
  1. Disconnect any power and remove the battery
  2. Tilt the system in various angles to drain as much of the water from the system as possible.
  3. Let the system dry for several days, (I'd say a minimum of 4) is a relatively warm place
  4. Insert Battery, see if system will power on.
If the system was powered on when the spill occurred and turned off by itself during the spill, then the motherboard has most likely been damaged and will need replacement. ($100 or so on EBay)
If the system will not power on after drying, you might consider replacement rather than repair as the cost of fixing it could exceed the replacement cost. (Dell has portables starting around $399)
http://www.dell.com/us/en/home/notebooks/laptop-inspiron-1545/pd.aspx?refid=laptop-inspiron-1545&s=dhs&cs=19
Dec 24, 2009 | Dell Latitude D600: Pentium M 1.6GHz,...
Milk spilled on tv remote controller
Remove batteries from remote, to avoid further damage caused from liquid on powered circuits.
Allow the remote with the cover opened to dry for few days. Ideally the remote should be disassembled and the internal parts treated with cleaning solution, or 70% isopropyl alcohol and water. If you do not want to disassemble just let it there to dry up.
If the remote does not work after that , it means that the liquid had damaged circuits.
In that case get a replacement remote.
Replacement Remotes
1-800-Remotes
TV Remote Controls - UK Replacement Remote
Aug 26, 2009 | Televison & Video
Water spill on laptop
You need to take it to a professional for repair.
if you know how to take a laptop apart, you could do it yourself.
Dry the parts, might need to replace the broken parts.
Aug 23, 2008 | Dell Latitude C640 Notebook
Dell d600
I would completely disassemble it (it really isn't that hard), let it dry out, then put it back together and see what happens.
May 03, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Water damage
Hey there Barbie,
I found a very helpful solution to this problem here: http://www.fixya.com/support/t163746-water_macbook_pro
(In general, this solution explains how to dry your laptop for a few days.)
I hope it helps you!
Dec 19, 2007 | Apple iBook Mac Notebook
Dell Inspiron 1526 Notebook Logo
549 people viewed this question
Alun Cox
