Question about Toshiba Satellite P35-S611 Notebook
Psp sound is not working
When i put my psp volume up all the way on full blast no sound comes out of it at all i checked the sound settings and checked if everything was right and still no sound.
    Problem Solver:
  • 6 Answers
Did you forget to plug in the speakers or did you blow them up
Posted on May 30, 2009
Tip
How to fix Volume issues in PSP Portable
How to Fix a PSP Volume Button through Software
Check to be sure that your PlayStation Portable's AVLS (Automatic Volume Limiter System) is turned off.
Start your PSP without a game in it. Choose "Settings," then select "Sound Settings." If the AVLS option is "ON," turn it "OFF."
Check to see that your memory stick is inserted properly if the sound still does not work. This often interferes with the volume control. Remove the memory stick and reinsert it.
Perform a hard reset of your PSP if the volume still does not work. To do this, first unplug your PSP and remove any games or memory sticks. Then remove the battery from its cavity on the back. Press and hold any button for five seconds, then reinstall your battery.
Move on to hardware solutions if none of the above options work
How to Fix a PSP Volume Button through Hardware
Remove your PlayStation Portable's battery pack, any games and memory sticks. Unplug it.
Unscrew all five screws that hold the faceplate onto your PSP. The fifth is hard to locate, so find it just below the screen on the bottom edge.
Clean the button heads underneath the volume buttons with a small cloth. You should also clean the Home button nearby as this often interferes with the volume button.
Return the faceplate and screws, and test your PSP.
on Feb 13, 2010 | Video Game Consoles & Games
My PSP 3000s sound system is alweys on full volume and I cant control the volume on it. it wont let me
Try going to sound settings and go to dynamic normalizer and if its off turn it on if you want to listen to your music you might also want to check by that i mean take the cover off the psp unscrew it Look at the place were the button for volume + - are and see if its jamed if you want to mute your psp hold the sound logo down untill you can't hear anything
Aug 24, 2010 | Sony PlayStation Portable (PSP) Console
The volume button of my psp does not work
I think your volume button is broken because I had a similar problem with my psp My WiFi switch wont work when I had it checked the switch was detached from the command it was assigned to
May 20, 2009 | Sony PlayStation Portable (PSP) Console
We are having trouble witholumne play back wheen tv is up full blast and
check cables get new ones. and check the DVD volume is up
Apr 13, 2009 | Televison & Video
Hear sound but cant get any real volume even at full blast
I was playing around with my Sherwood RD 6513 and adjust the the output level to its maximum, amongst other settings. This limited my output on the amp to a maximum volume of 65 not 90+.. Anyway i pluged in the microphone and done another 'auto setup' of the volume levels and distances, and this allowed the volume to exceed 65 again!
Also if you have an external source such as a DVD player - i would assume you have already checked its output volume setting?
Nov 23, 2008 | Sherwood RD-6500 Receiver
The vol. is not working on my psp
Make sure the volume is not set to zero. Try raising the volume using the volume buttons located on the front of the PSP.
Make sure the mute setting is not on. Press the (Music Note), third one from the right, located on the front of the PSP® to clear the mute setting.
If headphones are inserted, the PSP will not send any sound through the speakers. To check that the speakers work, unplug the headphones.
Hope that will Fix Ya!
Jul 12, 2008 | Sony PlayStation Portable (PSP) Console
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Psp keys
It sounds like the pc board that the volume buttons are in is damaged or coming loose. Aany repair shop that services PSP's should be able to fix that.
Sep 12, 2007 | Sony PlayStation Portable (PSP) Console
Toshiba Satellite P35-S611 Notebook Logo
71 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
