Question about Vizio VW32L 32 in. LCD HDTV
Vizio 32" Channel Scan Issue
Help, I have a Vizio 32" Model # VW32LHDTV40A I purchased it from Dell. The Tv Works fine, But out of the box I did channel scan and had no problems. But everytime I turn off the TV, I have to do channel scan search again in order to change channels. I turn it off and it seems if forgets the setting. I turn it back on and the channel up and down will not work on the remote or tv, Unless I redo the channelscan. I cannot view unless I punch in the actual channel only.
Thanks,Isaac
    Sergeant:
  • Vizio Expert
  • 329 Answers
The problem is a defective main board, the EEPROM on the board is defective.
Posted on Jun 02, 2017
  • 139 Answers
SOURCE: Vizio VW32L HDTV10A stopped responding with Vizio
Change the batteries in your remote. If your cat was laying on a button it could have drained them.
Here's tip - you can use your camera on your cell phone to see the IR signal coming out of your remote. Point the remote at your cam and press "On" or any button. You should see a bright flash with every key stroke.
Posted on Mar 06, 2009
  • 718 Answers
SOURCE: Tv won't stop changing channels
You need to isolate the problem.
1) Unplug the set for a few seconds then plug it in.
2) Operate the TV with the control/buttons on the TV. (Channels etc)
If the TV operates correctly then do the following.
3) Try operating with the remote unit. If the problem returns then it's the remote failing.
Sometime remotes can be reset.
Try this;
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Try it again. If the problem is still there then the remote is bad.
Since this is a new TV you should use your warranty to replace any bad parts.
Posted on Mar 16, 2009
  • 42 Answers
SOURCE: 32 Vizio
I'm not sure: on the Y-sus board there are 3 small power supplies. ( 3 small transformers standing together. They supply 15 volts each.) One of them supplies the 15 volts for the z-sus board this one might be defective. Replace the Elco's on this one by ordenary elco's (low -ones) in stead of the smd- elco's .
This might solve the problem. On the other hand you should realy measure this one out...
Posted on Jul 07, 2009
maatmartin7
  • 1213 Answers
SOURCE: CUSTOMER WITH A BRAND NEW VIZIO VA 320M KEEPS SHOWING SIDEBARS
The signal board is bad. Replace this board, its the one with the rca jacks and rf connectors. Warranty work will cover this repair. As we say in Nebraska.......Getter Done!!!!!
Posted on Aug 12, 2009
SOURCE: Vizio channel up/down doesn't work on the remote or the TV.
do the automatic channel scanning, it will work
Posted on Sep 12, 2009
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
Stuck on one channel
Is it the tv's remote? Change the batteries
are you on a cable box? You need to use the providers channel changer. Tv is made to stay on one channel like channel 3 and the cable box runs the different channels.
Dec 01, 2015 | Vizio L32 32 in. LCD HDTV
MMy Vizio 32" tv only gets 16 channels
If your Vizio TV has a built-in HD converter, 16 channels is what you can expect. If the channels are identified with decimals such as 10.1, 10.2, etc. they are HD. The cable connection you refer to must be connected to an antenna, otherwise you would have a cable box and a monthly bill from some cable company
Dec 04, 2012 | Vizio E322VL 32 in. LCD TV
Tv screen blue but audio vizio vw32lhdtv40a
my vizio 32in tv has sound but the picture is dark blue
May 03, 2010 | Vizio L32 32 in. LCD HDTV
My Vizio turns itself off on a certain channel (ch 17-1 Phila)
I have this same problem with channel 5-1 Los Angeles anyone have any advice?
Aug 29, 2009 | Vizio VW32L 32 in. LCD HDTV
Aug 12, 2009 | Vizio L32 32 in. LCD HDTV
I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Jun 20, 2009 | Vizio L32 32 in. LCD HDTV
Vizio 32lcd turns itself off on certain station
Do a full channel scan again. It should solve that problem.
Jun 14, 2009 | Vizio VW32L 32 in. LCD HDTV
Vizio VW32L 32 in. LCD HDTV Logo
3,738 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
