Question about Archos 605 Wifi Portable Multimedia Player
Battery drains in 15 minutes
My Archoso 605 Wifi's battery drains after about 15 minutes of playback.
  • wallace2121 May 30, 2009
    I purchased it in December 2007. I use it alot and normally I can watch for 2 hours. Within the last 2 weeks, the battery will not let me go 15 minutes before it turns off. BTW it is an ARCHOS 605 WiFi 30 GB, not 120 GB.
  • 68 Answers
Is it an old device? because it is powered with lithium-ion batteries, meaning the power degrades over time. if its old, then that will be the reason
Posted on May 29, 2009
  • Sasha Groves
    Sasha Groves May 31, 2009
    oh, if you give me about a day, i will do my best to find a solution for you
Can I change the battery on my archos 605
You can get a replacement battery here.
http://www.newmp3technology.com/605-battery.htm
By the looks of it, your need to open it up and unsolder the battery contacts and then resolder them.
If you don't feel up to doing it yourself, then try anywhere that repaires PC, laptop and such.
Check if they will do it and buy the battery yourself, might be cheeper that way.
Also check ebay incase it's cheeper there.
Aug 23, 2012 | Archos 605 Wifi Portable Multimedia Player
Archos 605 battery replacement
replacing the internal battery needs a service manual sir.
and the service manuals can be got from the company or other site for some small amount sir.
Aug 02, 2008 | Archos 605 WiFi Digital Media Player
HAVE HYUNDAI ACCENT.FAILED 2011 EMISSION NOx TEST RESULT ARE AS FOLLOWS: 2003 2005 2007 2009 2011 LIMITSppm 695 605 605 605 605 obtained 25 ...
Clean the MAF sensor and the IAC valve with MAF cleaner only...change your oil and filter, put correct air in tires and disconnect battery cable....wait 10 minutes, reconnect battery, turn off all accessories, lights, wipers, radio etc...put key in ignition and turn to the on position, BUT do not start...wait 1minute then turn off...turn on again and start car...do not rev, let car idle for 15 minutes, then go for a 20 minute drive. Before you take the car for another test, drive it for approximately 1 hour, both in the city and on the highway so the sensors can readjust....do not race or over rev the car...drive normally....cheers.
Feb 06, 2018 | Hyundai Accent Cars & Trucks
Where are local repair shops please need to replace 605 wifi 160 gb battery please help
heres what you do you shove it up ure *** and ask it to give u directions it helps 2 out of 3 times
Jan 20, 2011 | Archos 605 WiFi Digital Media Player
My Archos 605 will turn on for a second and then turns itself off
Sounds like the battery is fried or that the system has interpreted that the battery is fried.. Have you tried a 15 second reset. Stick a pin in the reset hole along the bottom for 15 secs (or longer) to allow full discharge and reset. Recharge immediately for about 4 hours with the system completely shut down (press on/off button 15 seconds until blank). If there is still a problem try for a long reset again. If it does boot check the battery condition and how long it takes to die. Once a battery decides its had enough they can go quite quickly and die completely. Do you run the Archos whist it is in the dock or while the charger is plugged in it, I have found that running current through the battery like this can shorten the battery life considerably. I tend to charge fully and then discharge fully, for some reason this keeps the battery fit and allows the system that monitors the battery to have an accurate appraisal of it's true condition.
Apr 16, 2010 | Archos 605 WiFi Digital Media Player
Battery is not holding a charge for no longer then 10 minutes, since the day i have bouhgt this thing I did not have chance to watch a complete movie, because the battery always rus out in the middle of...
Make sure you have downloaded most up to date firmware (2.1.04 - Menu: Settings: Firmware and Plugins: click on 'Online Firmware Update'). Put pin in reset hole at bottom left side. If the battery is new it should last at least 3+ hours on video playback. The battery monitoring system can get out of touch and so the reset may help.
Apr 13, 2010 | Archos 605 WiFi Digital Media Player
I can't find the model number on my Archos 605 wifi 160gb - can anyone tell me where it is?
serial number or model number - isn't archos 605 is the model number? serial numbers are usually written inside battery compartment or battery cover and rarely displayed via settings/information menu
Sep 01, 2009 | Archos 605 Wifi Portable Multimedia Player
I dropped my archos 605 in water the screen went a blue colour before dying on me.is it a goner.
probably...especially if the battery is still powering the device when you dropped it. remove the battery right away and have the water drained. You can try to dry it in an airconditioned room for several days but not under the sun or inside the refrigerator :-)
Try to power it after several days or weeks..goodluck!
Aug 10, 2009 | Archos 605 WiFi Digital Media Player
Archos 605 wifi broken screen
I have a similar problem. I received my Archos 605 two weeks ago and thought the product was awesome. However, I had to call customer service for the plug-ins I was supposed to receive free. I was dropped twice after waiting for 12 - 15 minutes each time. On my third call, I finally received customer service after waiting an additional 12 minutes. The woman was very nice where she finally got me 6 of the 7 the rebate specified.
Today, 09/14/09, I had to call Archos for the broken screen which was a 20 minute wait. It is NOT under warranty and will cost me $155.00 plus shipping. I paid $154.99 total for the unit brand new.
Customer service stated sorry. DO NOT PURCHASE AN ARCHOS -- BY A IPOD. I HAVE LEARNED!
Jun 24, 2009 | Archos 605 WiFi Digital Media Player
Archos 605wifi not switching on
Hi, my Archos 605 160GB is doing the same, Sorry to say the battery has gone.
2 options
1. Back to Archos
2. Replace the battery yourself I ordered mine from HK from the web site BatteryUpgrade. co. uk for about £24 - If you search on Utube there is a video showing you how to change the battery on smaller 605's
Jan 09, 2009 | Archos 605 WiFi Digital Media Player
Archos 605 Wifi Portable Multimedia Player Logo
185 people viewed this question
Top Archos Audio Players & Recorders Experts
kaiserh1
 Grubhead
Grubhead
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
