Question about Bosch 24 in. SHU5305UC Built-in Dishwasher
Dishwasher shu5305uc My diswasher goes on with the time and everything but does not take the water anymore? What sould I do?
  • 76 Answers
This could be many things, firstly turn of the main feed hose, disconect one end and reconnect it and turn it back on. see if this solves your problem.
Posted on Oct 23, 2007
Diswasher water isn't draining?
It is most likely the drain pump. If the drain pump passes a tech's test ok, have the drain passage checked for clogs.
Apr 17, 2012 | Dishwashers
I have Frigidaire FDB956RBC1 diswasher. I have to turn off the water to fix the faucet. When I turned the water back on, water did not go to the diswasher when I used it. The diswasher runs normal except...
FRIDG... EXPERT HERE
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 19, 2011 | Frigidaire FDB956RB Built-in Dishwasher
GE Nautilus built-in dishwasher suddenly won't spray
micro switch at the door lock has failed. it just happened to me.
I wired it direct and it worked. just dont open the door until you get a new switch. it wont shut off
Jul 11, 2010 | GE Nautilus 24" Built-in Dishwasher
Will not pump out water
ck your drain hose going to sink take lose make sure its not plug up even look where it goes in the garbage dis. or take cover of in botton diswasher, some time it get cloged.
Apr 11, 2010 | Frigidaire 18 in. FDR252RB Built-in...
Electrolux dishwasher error code 01
I found the error codes in the owners manual, (01) is a leak. I called customer service (no wait time) and they said there is pan under the tub that will contain and detect water if it leaks. They said I could wait for it to dry out. They said there could be a hose that became loose or had a pin hole in it. After I hung up with customer service I did my own problem solving. The diswasher washing cycle was just started. Then then the door was opened 5 to 6 times to add more utensils and dishes while the the machine was running. Then the error code came on. this was the first time this had happened. I beleive water seeped doen through the hinges and the seal into the pan. I unpluged the dishwasher and disconnected the water line and pulled it from under the counter. Then lifted the diswasher onto 4 inch blocks of wood placed under the feet. This made it easier to access the pan. It had 2 screws inthe front and 1 in the rear with 3 clips. I removed the pan and dried it. Inspected the hoses under the unit and determined none of them had appeared to be leaking. I positioned a fan to blow under the unit to speed up the dry time, about 1/2 an hour. Put everything back together and ran a high pressure hot water cycle and found no leakes, so far.
Jan 11, 2010 | Electrolux Dishwashers
Miele Incognito G843SCVi Plus diswasher will not drain
if the timer is in good condition (no wires burned off)  then it must be the pump itself that need replacing  dishwashers need the drain hose to rise to the counter and then fall again to siphon and make the pump work easier  also it helps keep water in it to stop the plastic parts in it from overheating    if the hose doesn't rise and fall  it may have led to your failure
Nov 07, 2009 | Miele 24 in. Incognito G843SCVi Built-In...
Bosch diswasher SGS5942 does not heat up
this is a common problem with dishwashers.the thermostats are faulty and be replaced by someone who knows what they are doing.
Oct 24, 2009 | Dishwashers
Loud humming noise when dishwasher is filling with water
sounds like it could be furring in your water piping. may need a plumber to check it out.
Mar 16, 2009 | Dishwashers
Diswasher doesn't clean
your water heater is set too low in temp.
you can turn up the heat or get an on demand heater under your sink for the dishwasher. you get a tax rebate too.
the heater in the new washers are too small to effectively heat the water to hot.
and always add a bit of bleach to your wash. the hot water will neutralize it.
or get an old dishwasher.
Mar 24, 2008 | Kenmore Elite 45986 Front Load Washer
Describe your Bosch 24 in. SHU5305UC
please post me your email i can send you in PDF format the manual so you can fix it yourself. There are prem chat avib but this part is free but you have to do the work If you want us to give you step by step instructions on how to fix it you will have to pay
Oct 22, 2007 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Bosch 24 in. SHU5305UC Built-in Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
